POV-Ray : Newsgroups : povray.general : Cmpeg causes nervous breakdown Server Time
22 Jul 2026 10:40:12 EDT (-0400)
  Cmpeg causes nervous breakdown (Message 1 to 10 of 13)
Subject: Cmpeg causes nervous breakdown
Date: 23 Jul 1999 15:20:44
Message: <3798c08c@news.povray.org>
So happy for having found a working download site for cmpeg I wanted to
torus01.tga instead of torus1.tga as first frame. Isolved the problem by
using frame 10 as Initial_frame Is there a different possibility to get
around this? This was only half of the Problem though, because Iget the
Message "16 and 24 bit Targa only" HeHe as far as I know does Povray produce
24-bit targas at least with th +ft switch turned on !
thanks for any help
Matthias
Subject: Re: Cmpeg causes nervous breakdown
Date: 23 Jul 1999 16:38:16
Message: <3798D283.5B12B910@aol.com>
You can get Cmpeg to work best by using the -t0 switch and using a
filename parameter like this for example:
cmpeg -t0 -v0 -f2 ipb.ctl c:\WhereFramesAre\frame%03d.tga
c:\WhereAnimationsAre\animated.mpg
The %03 (d is required) tells it to do a 3 digit set of frame numbers
left padded by zeroes starting with 000, with verbose messaging off,
frame speed 24/sec, and control file ipb.
Output uncompressed targas only from POV-Ray (+FT or
Output_File_Type=T); or  batch convert them if you can, also as
uncompressed (see your options), if you use another format.
The Cmpeg DOC says 15bit or 24bit, not 16bit (typo?). I've always used
24bit.
> thanks for any help
> Matthias
 mailto://inversez@aol.com?Subject=PoV-News
Date: 24 Jul 1999 01:31:36
Message: <37994fb8@news.povray.org>
Bob Hughes wrote in message <3798D283.5B12B910@aol.com>...
>24bit.
I think it also requires that the TGA files be uncompressed.
Mark
Date: 24 Jul 1999 03:59:40
Message: <3799726c@news.povray.org>
Mark Wagner <mar### [at] gtenet> schrieb in im Newsbeitrag:
37994fb8@news.povray.org...
> >24bit.
> Mark
yes thanks Bob for the digits hint. My other Problem still exists. Pov
24 or 16 bit only error. If I convert them to 24bit uncompressed again cmpeg
"god is a computer specialist"
Matthias
Date: 24 Jul 1999 10:34:29
Message: <3799CEC0.860AA89E@aol.com>
Are you using a starting frame number of 0, as in frame000? Cmpeg will
complain if using 001. Set your POV-Ray animation output INI to say
Initial_Frame=0 if not yet done so (and Final_Frame=99 if for 100
frames).
> > >24bit.
> > Mark
> Matthias
Date: 24 Jul 1999 11:35:21
Message: <3799E005.798273E1@erols.com>
> thanks for any help
You can also use a list file to supply the frames, instead of trying the
patterns.  This allows you to start from a frame other than frame 0,
delete frames in the sequence, use frames over and over, etc.
I use it for test renders, for shots mid-way in my animations.
To use it, simply, edit a text file with all of the names of the frame
files in it, such as:
frame001.tga
frame002.tga
frame003.tga
You can use any frames in any order, as long as they are all the same
image size.  This file gets fed to CMPEG like so:
  cmpeg -v1 -f2 ipb.ctl listfile.lst myanim.mpg
Note that the -t0 switch is not used.
Hope this helps,
John
Date: 24 Jul 1999 14:58:16
Message: <379a0cc8@news.povray.org>
Matthias,
My suggestion:
Use Fast Movie Processor from www.gromada.com to compile your stills into an
uncompressed AVI, then use AVI2MPG.EXE to convert to mpeg. Works great.
I've got a copy of AVI2MPG.EXE if you can't find it elswhere.
Andy
Date: 26 Jul 1999 02:37:41
Message: <379c0235@news.povray.org>
I have the same problem with cmpeg not reading my tga's. I hate that.
I have to convert all the images to raw format first.
  Isn't there any better mpeg encoder?
Date: 26 Jul 1999 02:49:10
Message: <379C0458.EE1E0C6F@pacbell.net>
You could of course look to my links page for alternative program options.
I have a few mpeg resources listed in the animation section.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 26 Jul 1999 02:56:49
Message: <379c06b1@news.povray.org>
This must be a VFAQ: How can you answer so fast to the articles?-)
