POV-Ray : Newsgroups : povray.general : quadratic spline problem for 3.1e Server Time
19 Mar 2026 04:51:48 EDT (-0400)
  quadratic spline problem for 3.1e (Message 1 to 4 of 4)
Subject: quadratic spline problem for 3.1e
Date: 8 Jun 1999 12:03:12
Message: <375D3EC5.E5FD9BC3@oc.chalmers.se>
Have anyone else had any problems with quadratic spline?
The following code gives me what is going to be a chalice but when I
render the image everything gets 'striped'. The image seems to be
partially rendered.
Some of the problems disapear when I turn off the orthographic feature
of the camera.
I am using povray 3.1e compiled on a SGI O2 running IRIX 6.3
Any help would be appreciated.
Regards
/Johan
#include "textures.inc"
#include "shapes.inc"
        location <0, 6.5, -30>
        look_at <0, 6.5, 0>
        orthographic
light_source {
        <20, 10, -100>
        color White
#declare chal =
lathe {
        quadratic_spline
        8,
        <14, 11>, <8.5, 8.5>,
        <6.5, 4.5>, <6, 0>, <5, -0.5>,
        <3.5, 0>, <2, 0>, <1, 0>
object {
        chal
        pigment { color White }
Subject: Re: quadratic spline problem for 3.1e
Date: 8 Jun 1999 12:31:06
Message: <375D4227.E49D8EDA@pacbell.net>
> Regards
Add the sturm modifier and your problem will go away.
#declare chal =
lathe {
        quadratic_spline
        8,
        <3.5, 0>, <2, 0>, <1, 0>sturm
Ken Tyler
mailto://tylereng@pacbell.net
Date: 8 Jun 1999 13:52:11
Message: <375D5851.A1AD4648@oc.chalmers.se>
> > Regards
> #declare chal =
> lathe {
>         quadratic_spline
>         8,
> Ken Tyler
Excellent!! Thank you very much.
Do you have any idea why sturm makes thing better (I have not read the
user guide that careful).
/Johan
Date: 8 Jun 1999 20:34:16
Message: <375DB32F.B742D2F7@pacbell.net>
> /Johan
 The docs mention that for speed considerations some objects that use high
order math equations to solve them they use less than accurate methods to
find the solution. The sturmian root solver forces Pov to use a more accurate
method to find the solution and there are times you will see an improvement
in the objects appearance as a result.
Ken Tyler
