POV-Ray : Newsgroups : povray.general : POV 3.5 ideas Server Time
28 Mar 2026 07:26:42 EDT (-0400)
  POV 3.5 ideas (Message 1 to 10 of 24)
Subject: POV 3.5 ideas
Date: 27 May 1999 17:42:01
Message: <374DAEED.D03C1587@compuserve.com>
Just thought I would put some of my ideas for POV-Ray 3.5 down, any
suggestions? Have the final features of this version been decided yet?
Definitely needs a double_illuminate keyword, so you can make both sides
of a surface be illuminated.
There should be an internal_reflection keyword, to toggle whether the
inside of an object reflects. This could be used with a clipped plane to
make one-way mirrors.
The unlimited light option would be nice, as I understand it, this light
won't fade when it passes through media, but will still interact with
it.
And of course, angle dependant reflection(maybe refraction too?),
blurred reflection and refraction, and even though I have heard it is
not planned, Photon Mapping! It should probably only be added as an
"experimental feature" like atmosphere and halo were.
Subject: Re: POV 3.5 ideas
Date: 28 May 1999 12:20:34
Message: <374eb442.0@news.povray.org>
I would like to see a 'highlightless' keyword so that you could type:
light_source
{ <10,20,30> rgb 1
  shadowless
  highlightless off
  This way you could make shadowless lights which cause highlights on
objects. You could also make regulars lights which don't cause highligths:
light_source
{ <10,20,30> rgb 1
  highlightless
but I think that the latter is not so useful as the first one.
Date: 28 May 1999 12:44:11
Message: <374eb9cb.0@news.povray.org>
May I suggest that the keyword be "highlight" instead of "highlightless"?
I think it's easier to wrap your brain around "highlight on" than the
equivalent "highlightless off"
Date: 28 May 1999 13:04:47
Message: <374EBD06.EE24F6E9@aol.com>
How about phongless? :)
-mike
Date: 28 May 1999 13:11:53
Message: <374EBFEA.757473CD@pacbell.net>
> -mike
What if it has metallic or specular highlighting ?
Would this keyword also affect the way reflection is calculated ?
Ken Tyler
mailto://tylereng@pacbell.net
Date: 28 May 1999 13:24:24
Message: <374EC19C.39285F01@aol.com>
Personally, I'd rather have it handled differently.  Since the idea, to my
way of thinking, is to simulate translucency, it would be better to have a
more thorough treatment of it.  Both color_maps and image_maps should be
available to adjust the amount illumination that shows through and also
effect the coloration.
And since we're on wish lists, I'd really like to see some improvements to
bicubic patch.  The most important one is to do away with u and v steps and
handle the subdivision based on the output resolution.  This is the only way
I know of to insure perfect results.
These things are on my to-do list if I can find time 'to do' them.
-Mike
Date: 28 May 1999 13:30:17
Message: <374EC43B.DEC46452@pacbell.net>
> it.
  Add to the media features wish list a selectable sampling method that
can or will produce smoother media with improved speed results. I can
dream can't I ?
Ken Tyler
Date: 28 May 1999 17:59:14
Message: <374F0479.1827A958@compuserve.com>
Well translucency is a great idea(one I had thought of and forgot), but
I still think having control of double-illumination would be good. Both
of them, not either-or.
Date: 28 May 1999 18:05:04
Message: <374f0500.0@news.povray.org>
Ken asks:
> I can
> dream can't I ?
    Well in that case I want a reality_dream setting that when it's value is
above zero it gives that nice, soft, fuzzy around the edges wavering that
dreams have and when the value is below zero it has the black iron claws
that seem to reach for me out of every shadow.
Date: 28 May 1999 18:11:50
Message: <374F063A.B469A850@pacbell.net>
Bill DeWitt wrote:
> Ken asks:
> > I can
> > dream can't I ?
Well it was made as a serious comment that I believe is echoed by many but
if it helps you achieve this in your work as a side effect then I am for
that too.
Ken Tyler
