POV-Ray : Newsgroups : povray.general : Optimizing windows/povray. (my own written howto guide) Server Time
24 Jun 2026 00:55:46 EDT (-0400)
  Optimizing windows/povray. (my own written howto guide) (Message 1 to 10 of 11)
Subject: Optimizing windows/povray. (my own written howto guide)
Date: 7 May 1999 04:04:40
Message: <373290F8.5955C954@telebot.net>
First off,  standard disclaimer.  You ARE NOT going to find me liable for ANY
use/misuse
of ANYTHING found in this document.  If you follow these instructions either IN whole
or
part,  and something goes wrong,  (for instance a rip in the fabric of space-time,  or
by
using this information you somehow create the dreaded,  infamous, crazed, screaming
chicken virus,  and this same crazed chicken appears on your screen,  reaches out from
the
monitor and strangles you) don't come looking for ME!
   Your mileage will vary.
Anyways,  I think everyone should get the point by now.....
(The following pertains to windows 95/98, and in some circumstances,  NT ONLY.  The
information contained here is designed to be a brute force approach to getting the
most
when you need it.  Removing some hardware dependant drivers could very possibly
disable
the entire computer.  It is intended for and BY povray users.  Users who need,  "just
one
more kilobyte" to get that certain scene rendered.  This document is not intended as
an
overall performance enhancement guide.
First thing we'll consider is speed.
Let's think about "background processes"....  Just because the taskbar shows
the only program currently running is Povray for Windows... doesn't mean that Povray
for
Windows is the ONLY program running.
As proof of such,  close everything so that the taskbar is completely emtpy and the
only
thing you see is the start button.  Now,  please do the three finger,  nothing left to
lose,  windows puked again,  salute.  (Control-Alt-Delete)  There should appear a box
in
the center of the screen.
Look at what is listed in that box.  Each item that appears is a thread/program of
some
sort.  These NEED to be closed/terminated.  If you think for one instant that these
background threads/programs are inconsequential,  Montey is going to inform you that
you
JUST missed "computer trivia" for 500,  and that you just lost the double jeopardy
round.
(note:  for the plain-jane,  vanilla windows setups,  it may be possible that NOTHING
appears in the box with the exception of one or two items.)
Although a complete list of threads that you may find is completely beyond anything I
would dare to write,  I will however list a few that can (somewhat) safely be
terminated.
     ==============           ONES TO KILL        ===================
findfast:  This is installed and runs/loads EVERYTIME you start windows.
           Microsoft word, or works installs this.
ltstart:   This comes from Lotus Smartsuite,  and possibly a few
other Lotus products.
prttest:   This comes with some installations of scanners.
porttst:   Same as above.
realaud:   Real Audio player.  This one sits running minimized in the
taskbar as a small icon on the lower right corner.
opware16
opware32
===============  ONES that MUST stay running  (don't touch!)  ===========
explorer
systray
 When killing off these unwanted threads,  understand that the benefit of doing so is
actually twofold.  One,  it's simply one less process that windows has to contend
with.
(and thus alot cpu time)  Secondly,  when stopping them dead in their tracks such as I
have described above....  the memory that these programs once consumed,  are released,
and given back to windows.  (i.e  so that it can be alloted to other programs such as
Povray when/if needed)  The final word on this is rather simple.  The fewer the
processes/threads/programs,  the better.  Plain and simple.  It is to your benefit to
experiment with this.  Try killing each process you find listed in the dialog box and
see
what happens.  Please note that it's normal to see some disk activity when doing this.
 There is also "overclocking".  I'm not going to elaborate on this other than a strict
definition.  Overclocking is simply the act of driving the CPU and/or Bus at a faster
speed than it was intended.  There are arguments for and against this.  And you must
make
the decision yourself as to whether you want to delve into this black art.  I have
included some links so that you may read more about this subject.
http://www.overclockers.com     Good info on overclocking. Interesting page     of
results
for various week/country      processors.
http://www.anandtech.com -  Lots of hardware info (not just about
overclocking).
http://sdw.pair.com             Interesting site with a page devoted to
overclocking
results by processor/Mboard/etc.
http://www.cpu-central.com      Lots of detailed info
http://www2.tomshardware.com    One of the best hardware sites on the web.     Lots of
info on overclocking and hardware
    in general.
MEMORY CONSIDERATIONS
 Have a look at your autoexec.bat and config.sys
There are a few things that can be removed here.  (probably) Is there a CDROM driver
statement?  Possibly something that looks like, VIDE-CD.SYS ??  You can keep this from
being loaded by simply putting a ':' or a "REM"  at the beginning of the statement.
Please note that removing/editing/deleting any statements within your startup
configuration files could potentialy disable the entire machine,  and/or peripheral
devices such as the mouse,  scanner,  CDROM, TAPEdrive, ZIPdrive,  etc.  Again,  your
mileage will vary.   One common myth is that these "drivers" loaded from autoexec.bat
and
config.sys play no part until you see the black&white C:\ prompt.  In otherwords,  a
DOS
prompt.  And if you believe that,  Monty just informed you that you have just lost the
bonus round as well.  It is usually best to disable EVERYTHING in your startup
configuration if you can get by with it.  The advantages are several.  One,  again is,
memory requirements.  The drivers/programs are NOT dynamically loaded.  Meaning they
do
not release themselves from memory as needed.  No,  they are static,  and are ALWAYS
there
eating up one resource after another.
 Of the things I would suggest removing,  (if only for a particularly LONG rendering
session) would be,  EMM386.EXE  Windows itself does NOT need it to run.  Period.  next
in
order would be CD-ROM drivers.  Almost from a sheer memory conservation standpoint,
SMARTDRV.EXE is a LARGE memory eater.  I can think of NO reason why this should even
exist
these days.  Windows doesn't need it,  nor use it.  It's really nothing more than a
disk-caching program left over from the win 3.1 - 3.11-workgroup days.  Again,  final
word
is simply,  LESS/NONE is better!
(Wallpaper/background images/desktop)
 There is also the problem of the cutesy wallpaper most of us see these days gracing
every
computer desktop.  What a large majority of people don't realize is that the memory
consumption of these totally groovy pictures is REALLY high.  Let's consider the
average
computer desktop resolution of 800x600 at 24-bit color.  (povray users will often
times
have a much higher setting)  It stands to reason that this picture of whatever must be
stored and loaded into SOME place.  It is a common misconception that wallpaper
consumes
no memory.  (Monty is getting upset with you now)  The normal bitmap image at the
above
resolution on average consumes over 1 megabyte of physical memory.  ONE MEGABYTE
FOLKS!
And that 1 meg is consumed ALL the time.  Not just when windows tasks have been
minimized,  and the desktop finally comes to the foreground.  Bottom line,  load a
800x600
image as windows wallpaper, say goodbye to 1 meg.  GONE!
DOUBLESPACE/DRVSPACE
(Before reading any further,  it is imperative that you determine whether the disk
compression program(s)  DriveSpace OR DoubleSpace is currently being used.  If you
know
for certain that they are not,  please continue.)
 By opening windows-explorer and going to the root of drive C:  You will find a file
named,  "MSDOS.SYS"  By adding two simple lines,  it may be possible to save yourself
SOME
cpu cycles,  and memory as well.
Apparently,  regardless of whether either one of the mentioned Disk compression
programs
are in use,  Windows-95 loads BOTH of these drivers at startup.  This is a thorough
waste.  After opening MSDOS.SYS (use notepad to open it with!)  scroll down to the
[Options] menu and insert the following two lines:
DblSpace=0
DrvSpace=0
Your MSDOS.SYS file should now looking something similiar to this:
[Options]
DblSpace=0
DrvSpace=0
DoubleBuffer=0
LoadTop=0
BootWarn=1
BootDelay=0
Logo=0
BootMulti=1
BootGUI=1
Network=1
 I have been informed that this "flaw" and the above two mentioned lines are no longer
needed for users of WINDOWS-98.  And that the disk compression drivers aren't loaded
unless REALLY needed.  However,  I have not been able to confirm this myself.
This is a work in progress.  If you know of any errors,  or would like to contribute
anything,  please write to:
joh### [at] netjavacom
When confirmed,  your contributions will be added,  and you'll even get your name
mentioned here!  (great huh ?)
This is all I have for now.  I'll add more to this at a later date.  I sincerely hope
that
somewhere this was useful to someone in the povray community.  I think if only one
person
out there applies JUST ONE thing  I have written here,  and finds it useful... it was
worth it.
Goodbye for now.
Subject: Re: Optimizing windows/povray. (my own written howto guide)
Date: 7 May 1999 09:06:58
Message: <3732d762.0@news.povray.org>
Hi
i just wanted to say that you don't need those two threads too,
but you have to change your shell from the explorer to povray,
you can do that with utilitys, like shellselect ( don't ask me were i got
it, it was mentiond in this group some time ago ) or you can change it
manualy, i think in the system.ini.
When you do that only povray is running, nothing else ( you have no
start button and so on ), and if you wan't to use the explorer for file
browsing, or wan't to reboot without the go down in the ctrl-alt-del menu.
you can adjust the tools menu, and put an explorer and so there.
( And i am also not responsible for any damage occured thru my tip )
>explorer
>systray
Date: 7 May 1999 15:35:15
Message: <37333263.0@news.povray.org>
personnally when i want to ensure my PC is giving POVray all it has, i run
the dos version, it really does make a difference.
Date: 7 May 1999 18:03:05
Message: <37335509.0@news.povray.org>
I've heard that so much that I just had to try it. So I installed
POV for
ms-dos and ran the "skyvase.pov" benchmark from booting into ms-dos.
Results : 203 seconds. I ran it twice more checking that all the options
were
there as recommended : same thing. Now, in Win98, with nothing else
running and the recommended options set it renders in 101-102 seconds
(not quite as consistent). The margin is very significant. So, what am I
doing wrong ?
        My machine is new, a Celeron 366A non-overclocked with 128 Meg RAM.
such a difference... I just can't explain it otherwise but that there was a
lot of swapping
through the HD ?
        JM
>Rick
Date: 7 May 1999 18:06:38
Message: <37335484.48F1B98B@bahnhof.se>
Guilty as charged.
I was the one with the link to shell select. I can dig it up and post it here,
or a link.
What happends is that:
The shell program (litestep, explorer, evwm, reveal) reads from the registry and
autostart menus, then launch theese programs.
If you use another program as shell, then it wiill not launch theese processes.
Therefore, it is adviceableto run POV as a shell if you want the total cpu
speed.
no, this won't cause much trouble. If you double click the background, you will
get the old "task-manager" launched. from this you can access the "run.." and
"shutdown" menus.
Here is the address to shell selector:
http://www.v-active.com/shellselect/
(15k download)
"Lars W." wrote:
> Hi
> >explorer
> >systray
//Spider    --  [ spi### [at] bahnhofse ]-[ http://www.bahnhof.se/~spider/ ]
And the meek'll inherit what they damn well please
	Get ahead, go figure, go ahead and pull the trigger
		Everything under the gun
			--"Sisters Of Mercy" -- "Under The Gun"
Date: 7 May 1999 18:30:45
Message: <37335b85.0@news.povray.org>
I did the same thing and got the same results, and came to the conclusion
that I needed to haul out my old memory management 'config.sys' thingies so
I could take advantage of the 128 MB of RAM.
Never did bother doing that though.
Jean Montambeault <jrm### [at] videotronca> wrote in message
news:37335509.0@news.povray.org...
> POV for
> were
> doing wrong ?
RAM.
a
> lot of swapping
> through the HD ?
>         JM
run
> >Rick
Date: 7 May 1999 18:51:57
Message: <3733607d.0@news.povray.org>
...and if you can get it, won't you tell me how-wow ?
           Well, since I ran the msdos version from inside Windoze :
 100 seconds flat. Pfff!
        JM
>> POV for
Date: 8 May 1999 00:09:18
Message: <3733AA43.C097CBB4@pacbell.net>
> explorer
> systray
For the record I shut down systray frequently and suffer no loss of
operating ability. It's mostly just another controller for background
utilities that are not necessary for the system to run properly.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 10 May 1999 09:24:23
Message: <3736cff7.0@news.povray.org>
"Rick (Kitty5)" <kit### [at] dialpipexcom> wrote:
: personnally when i want to ensure my PC is giving POVray all it has, i run
: the dos version, it really does make a difference.
  Not anymore with msvc 3.1e. See my speed comparison in this newsgroup or
povray.msdos.
Date: 8 Jul 1999 01:53:36
Message: <37843ce0@news.povray.org>
Jean Montambeault wrote in message <37335509.0@news.povray.org>...
>POV for
>were
>doing wrong ?
One possibility:  on my 400Mhz AMD K6, if I tell Windoze 98 to 'restart in
dos mode', for unknown reasons the computer runs so slowly, it feels like a
486/33!  The fix:  when turning on the computer, press F8 (I think) to start
up in true DOS.
Mark
