POV-Ray : Newsgroups : povray.general : Image Cropping Server Time
28 Mar 2026 11:33:13 EDT (-0400)
  Image Cropping (Message 1 to 6 of 6)
Subject: Image Cropping
Date: 1 May 1999 04:37:46
Message: <372AB0B4.BA95DA98@tiac.net>
Last night I tried out the Partial Output Options to crop the
top and bottom off my render. It worked great,giving the image
that wide-screen effect as it rendered. But I opened the image with
Quick Time and the image was sitting in the top portion of the frame
instead of the middle where it's supposed to be.
My command line setting was: +sr.14 +er.86 (which renders a rough
aspect ratio of 1.85:1) This was applied to a normal 1.33:1 image.
Now how do I keep the image centered?
Subject: Re: Image Cropping
Date: 1 May 1999 09:48:43
Message: <372AF7EE.DB8516B5@aol.com>
Can't be done that way, as the image is readinto a image reader it picks
up on the viewable portion. Some programs can't open a partial render at
all. You're going to have to do the aspect ratio way.
+w400 +h300 in command-line for a up 1*y right 4/3*x in the camera.
> ...coffee?...yes please! extra sugar,extra cream...Thank you.
 mailto://inversez@aol.com?Subject=PoV-News
Date: 1 May 1999 09:54:57
Message: <372AF912.DA338786@pacbell.net>
  You can simply copy the image and paste it into a larger frame with
a black background. PSP will let add boarders to an image uniformaly
or by specifying which side you want it added to.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 1 May 1999 10:11:51
Message: <372cfb46.5930609@news.povray.org>
On Sat, 01 May 1999 03:43:48 -0400, Phil Clute <plc### [at] tiacnet>
Well, suppose you render a 1024x768 image with +sr0.25 +er0.75. This
will yield a 1024x384 image. That's right, POV will not fill the empty
space for you, instead it will render a cropped image. You should tell
your image viewer to center the image, if possible.
Peter Popov
ICQ: 15002700
Date: 1 May 1999 23:07:42
Message: <372BB4D9.DB1A8F44@tiac.net>
I know how to change the aspect ratio by resolution.
But I was hoping the partial output would leave it centered,
I was thinking the black portion was part of the image. Well
the idea started because of mpegs only accepting certain resolution
sizes, I figured I could get away with a wide-screen on a 4/3
resolution that would be accepted.
Oh well,  Thanks.
Date: 2 May 1999 22:17:04
Message: <372CF931.A59496DA@geocities.com>
Just FYI, I have some basic math done for that a while back. Look for
the 'Working size' section at the end of
http://www.geocities.com/SiliconValley/Network/4453/imp/imp_01.htm
You'll probably have to use some post utility to get the size, etc.
The Gimp is working on Win32 now, so that might help.
