POV-Ray : Newsgroups : povray.general : paralell lines and fisheyes Server Time
30 Nov 2025 18:19:38 EST (-0500)
  paralell lines and fisheyes (Message 1 to 10 of 12)
Subject: paralell lines and fisheyes
Date: 15 Feb 1999 01:40:21
Message: <36c7c155.0@news.povray.org>
A photograph using a wide angle lens will show distortions, such that
buildings, which are vertical, appear bent.
Yet a POV image with a very wide angle camera (a direction vector of length
0.4) my verticals and horizontals and depth lines are all straight.  depth
lines converge to a vanishing point, but vertical lines stay vertical and
parallel to each other, and horizontal lines stay straight and paralell to
each other.
Why?
--John
Subject: Re: paralell lines and fisheyes
Date: 15 Feb 1999 05:49:03
Message: <36C7FB77.D3C4B4A7@aol.com>
You used the 'fisheye' lens? Or not...?
> each other.
> Why?
> --John
 mailto:inv### [at] aolcom?PoV
Date: 15 Feb 1999 08:17:25
Message: <36c81e65.0@news.povray.org>
Bob Hughes <inv### [at] aolcom> wrote:
: You used the 'fisheye' lens? Or not...?
  Or better the 'ultra_wide_angle'.
  An example of distortion made with the ultra_wide_angle camera can be
found at http://iki.fi/warp/pics/logo5.jpg
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp -*/
Date: 15 Feb 1999 19:51:37
Message: <36c8c119.0@news.povray.org>
Bob Hughes wrote in message <36C7FB77.D3C4B4A7@aol.com>...
Not.
#declare main_camera= camera {
   location  <0, 0, -1*pogsize.z>
   direction <0, 0,  0.4>
   up        <0, 1,  0>
   right   <4/3, 0,  0>
   look_at   <0, 0, 0>
   translate y*0.5
Date: 15 Feb 1999 19:54:17
Message: <36c8c1b9.0@news.povray.org>
Nieminen Mika wrote in message <36c81e65.0@news.povray.org>...
I don't want to duplicate the effect.  I just wonder why the regular
perspective lens doesn't do that.  I thought that effect, which we se in a
camera, is an artifact of the wide perspective.
Date: 15 Feb 1999 20:44:48
Message: <36C8CD3B.FF291F00@pacbell.net>
I have found that the radial distortion you would expect often times
manifests itself more often with camera positions close to objects
and seems to deminish with distance. An example would be a tall object
nearly off screen and near to the camera while the main focus of the
scene is further back. You can really exagerate this (to me unwanted)
effect by adding a little tilt to the camera. Like placing it at y*5
and have your look_at set to y*1.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 16 Feb 1999 02:46:52
Message: <36c9226c.0@news.povray.org>
Ken wrote in message <36C8CD3B.FF291F00@pacbell.net>...
I also find it an unwanted effect for my current effort, and upon studying
the original woodcut I found that the back end appears 1/3 the size of the
front end, and a little geometry told me that the camera needed to be half
that depth away from the front face to get that effect.  Then I "zoomed out"
(reduce the camera length vector) to get the whole scene into view.
When planning it, I thought I might have distortions and was contemplating
ways of dealing with it.  But lo and behold, there is =zero= distortion.  So
my understanding of what causes wide-angle distortion is flawed.
When I get unwanted perspective effects, I get the results I expect by
backing away and zooming in.  So some of it anyway agrees with my mental
model and real-world camera experience.
--John
Date: 16 Feb 1999 14:09:28
Message: <36c9c268.0@news.povray.org>
John M. Dlugosz heeft geschreven in bericht <36c7c155.0@news.povray.org>...
In photography, with good quality lenses and with the film-plane and
object-plane parallel to each other there should be no distortions of the
kind you discribe. As soon as these planes are not parallel, the perspective
changes. Buildings start falling over. ( You can shift, tilt and rotate the
lens-plane any wat you want, it has no influence on the perspective).
When using fish-eye and super wide angle lenses, you wil have bend lines in
your picture. These are not perspective distortions, it is a result of the
central projection. If you watch the picture from the right distance the
perspective will appear normal. The normal viewing distance is the
focaldistance of the lens multiplied by the enlargement of the negative.
This goes for all pictures, not only for wide angle ones.
To prevent building from falling over, instead of tilting the camera, one
should keep the planes parallel and translate the lensplane up. This can be
done with fieldcameras or shift-objectives. In POV it can be done by
shearing the camera.
ingo
Met dank aan de muze met het glazen oog.
Date: 18 Feb 1999 17:33:47
Message: <36CC952C.90EB54DE@aol.com>
I see someone knows a bit of photography here.
I hadn't tried the "shear" you mention (does that work? I'll find out),
in fact I hadn't tried the offset parallel lens -- ie. create lens
object and translate off center of the camera look_at -- kind of thing
yet either. Will have to take a look and see how both these methods look
in POV-Ray. Aside from doing decimal direction perspective before like
John M. D., I haven't done too much camera play since most times I keep
to a usual look in a scene anyhow.
> ingo
Date: 19 Feb 1999 05:08:10
Message: <36cd380a.0@news.povray.org>
Bob Hughes heeft geschreven in bericht <36CC952C.90EB54DE@aol.com>...
An example of camera shearing for perpective correction. Put -uv in the
commandline when transforming the camera.
light_source {
  <500, 500,-500>
  color rgb <1, 1, 1>
#declare Shear= transform {
   matrix <  1,  0,  0,
                   0,  1,  0.3333,
                   0,  0,  1,
                   0,  0,  0 >
  location  <0.0, 0.01,-1.5>
  look_at   <0.0, 0.50, 0.0>
  angle 95
   //    transform Shear
plane
  y, 0
        checker color rgb <1, 1, 1> color rgb <0, 0, 1>
        scale 0.25
box {
  <-0.5,0,-0.5>,<0.5,1,0.5>
  pigment {rgb 1}
box {
  scale 0.5
  translate <0.75,0,-0.5>
  pigment {rgb 1}
