![](/i/fill.gif) |
Any ideas on how to make those rust-icicles you see on the wrek of the
Titanic, and other ship wrecks?
Some ideas:
Blobs: Probably most realistic. However, would have to do some coding to
get them randomized, and I am not a coding kind of person...
Heightfields: Good to get more complex shapes, and cover large areas at
one time. However, very hard to look anywhere near realistic...
Media: Some kind of media, in cylinders or cones? I know nothing about
the intracies of the field, so I'll leave this one out, for now...
Any other ideas?
Simon
http://home.istar.ca/~sdevet
![](/i/fill.gif) |
![](/i/fill.gif) |
Lance Birch wrote:
> Blobs as you suggested are a good start. You may also want to try extruded
> polygon cones with a 3D noise function... but this is going to require a
> fair bit of coding.
Yeah.. seing as I'm a Moray man, I tihnk I'll just make, say, 10 different
rusticles, then apply them to the hull, semi-randomly rotated, and scaled, to
look different....
However, the extruded cone is interesting.. something I could do manually with
spatch, no problem... have to give it a try.. see how it looks.
Simon
![](/i/fill.gif) |
![](/i/fill.gif) |
Hello Simon
Try this :
#macro MakeIcicle(n,rad,qrad,rs)
// n : elements
// rad : radius
// qrad : decrease radius
// rs : seed
#declare rd=seed(rs);
blob{
threshold 0.6
#local i=0;
#local ys=0;
#while (i<n)
#local rx=(0.5-rand(rd))*rad*1.5;
#local rz=(0.5-rand(rd))*rad*1.5;
sphere{0,rad,1 scale
<2,1+qrad*(i+1),2>*<1+rand(rd)*0.5,1,1+rand(rd)*0.5> translate <rx,ys,rz>}
sphere{0,rad*1.3,1 translate <rx*2,ys-rand(rd),0> rotate
y*360*rand(rd)}
y*360*rand(rd)}
y*360*rand(rd)}
#local rad=rad*qrad;
#local ys=ys-qrad*1.5;
#local i=i+1;
// creates a row of 20 icicles
#declare i=0;
#declare rd=seed(456);
union{
#while (i<20)
#declare rs=i;
#declare sc=0.5+2*rand(rd);
object{MakeIcicle(20,1,0.9,rs) scale sc translate x*i*8}
#local i=i+1;
pigment{rgb<1,0.3,0.1>}
Gilles Tran
> Some ideas:
> Any other ideas?
> Simon
![](/i/fill.gif) |
![](/i/fill.gif) |
Gilles Tran wrote:
> Hello Simon
> Try this :
<snip blobs>
I think I've found my solution, to use random blobs, and keep with Moray.
I finally have the liquid spray plugin working, and it produces exactly the
effect I was hoping for. Can be implemented, and randomized very easily.
Wheee!
Still want to figure out the code, sometime
Simon
![](/i/fill.gif) |
