POV-Ray : Newsgroups : povray.general : CSG with planes Server Time
1 Mar 2026 15:28:11 EST (-0500)
  CSG with planes (Message 1 to 4 of 4)
Subject: CSG with planes
Date: 14 Jan 1999 10:03:04
Message: <369e0728.0@news.povray.org>
If I am making a CSG object by using intersections of a bunch of planes
through say a box, my final CSG object will be hollow.  Is there an easy way
to make my CSG object solid using this method, or an easier method perhaps
than cutting with boxes using a difference?
Mike Metheny
lon### [at] vtedu
http://loneshepherd.ml.org/
"When one's words are no better than silence, one should keep silent."
Subject: Re: CSG with planes
Date: 14 Jan 1999 10:10:56
Message: <369e0900.0@news.povray.org>
First, what do you mean by hollow?
If you mean "you'll be able to see the inside from the outside", then this
is not true if you intersect or difference with a plane, only if you clip
with a plane.  You might get this if you have "coincident surfaces", which
have been known to mess up the logic used by intersection.  If this is the
case, move the planes a miniscule amount in either direction and the
problem will go away.
If you mean "You can't use it in CSG", as with a mesh, that's not true
either.  Planes are solid objects, with the inside defined as "everything
on the side of the plane opposite the direction of the normal vector"
If you mean "You can use media in it", the statement isn't true unless
you explicitly say "hollow".  So you probably didn't mean that.
If you mean "When I put my camera in it, I see the inside walls", that's
true of every object in POV.
If you explain what you're seeing, with perhaps a short snippet of sample
code, maybe we can more effectively help you solve your problem.
Date: 14 Jan 1999 13:21:21
Message: <369e35a1.0@news.povray.org>
There's no difference between a regular box and one made by intersecting
six planes.
  Except that the latter will render a lot slower.
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp. -*/
Date: 16 Jan 1999 17:55:40
Message: <36A11A53.D370C74D@bahnhof.se>
Hm, I might be adding a bit here...
I made a #macro for this some time ago...
get it at http://www.bahnhof.se/~spider/
at least, if yoyu have a javascript capable browser...
Sorry, I'm doing a rewrite on the site to get rid of the JS and add some more
frameset's... (Lot o' files)
//Spider
> Mike Metheny
> lon### [at] vtedu
