POV-Ray : Newsgroups : povray.general : Help needed with 'media' Server Time
23 Jul 2026 20:13:28 EDT (-0400)
  Help needed with 'media' (Message 1 to 7 of 7)
Subject: Help needed with 'media'
Date: 30 Nov 1998 14:18:05
Message: <3662ef6d.0@news.povray.org>
    Please help me with this annoying problem.
    I have created a union of a sphere ( at origin, radius 1,textured mainly
Red, but with Clear patches), a light_source, (also at origin
media_attenuation on), and a final sphere ( also at origin, radius 2}.
    How do I add media to the larger sphere, so that the shafts of light
coming from within the smaller sphere are visible? I've tried following the
documentation, but the outer sphere is invisible.
    Here's my code ( it's messy, I know).
Thanks in advance.
Andy C.
// ==== Standard POV-Ray Includes ====
#include "colors.inc" // Standard Color definitions
#include "textures.inc" // Standard Texture definitions
camera
  location  <0.0 , 4.0 ,-8.0>
  look_at   <0.0 , 0.0 , 0.0>
light_source
  0*x
  color red 1.0  green 1.0  blue 1.0
  translate <-20, 40, -20>
media_attenuation off
union {
sphere {<0,0,0>,1 texture
    pigment
    spotted color_map {
                [0 Red][.6 Red][.61 Clear][.9 Clear][.91 Red][1 Red]}
                scale .2}
light_source
{  0*x   color red 1.0  green 1.0  blue 1.0
  translate <0, 0, 0>
media_attenuation on}
// Add media
sphere {<0,0,0>,2 pigment {rgbf<1,1,1,1>}
        interior {
        media {
  intervals 40
  scattering {1, rgb 0.02}
  samples 1, 10
  confidence 0.9999
  variance 1/1000
  ratio 0.9
Subject: Re: Help needed with 'media'
Date: 1 Dec 1998 05:26:31
Message: <30BC3542.85199F67@peak.edu.ee>
Only hollow objects can contain a media, i.e. you must add the "hollow"
keyword to the larger sphere. Check the manual for info about hollow and
solid objects.
Margus
Andrew Cocker wrote:
> Hi,
> Thanks in advance.
> Andy C.
Date: 1 Dec 1998 16:39:14
Message: <36646202.0@news.povray.org>
Here's a revamped script:
/* Smoothness factor [1=grainy, 2=rough, 3=default, 4=smooth */
#declare G = 2;
#switch (G)
#case (1)
#declare Granularity = 2;
#break
#case (2)
#declare Granularity = 5;
#break
#case (3)
#declare Granularity = 10;
#break
#case (4)
#declare Granularity = 20;
#break
camera
light_source { 0*x
#declare Red=color red 1;
#declare Clear=color rgbf 1;
union {
sphere {<0,0,0>,1
     spotted color_map {
    scale .2}
     finish {ambient 0 diffuse .5}  //tweaked the sphere
}  //inner sphere
light_source
{  0*x   color rgb<3,2,1> //intense reddish light
  fade_distance 1 fade_power 2  //cause falloff of light
 //neither of these media_ statements are needed unless turning off
// media_attenuation on media_interaction on
// Add media
sphere {<0,0,0>,2
  hollow on  //always use this remember (things do not default to this!)
   interior {
        media {
         absorption <0,.5,1>  //filter out all blue, half green
  intervals Granularity  //smoothness of media
  samples 5, 10     //fair amount of sampling
  confidence 0.95   //better than default 0.9
  variance 1/150    //better than default 1/128
  ratio 1           //ratio of spotlight lit to unlit region for
intervals/samples to calculate
  scattering {1, rgb .1 extinction 0}  //lower extinction brightens
  } //outer sphere
} //union
Don't know why, but your texture and pigment statements were missing their
leading braces. Other than that, only real thing wrong was the hollow keyword
and a need for larger scattering color.
Message <3662ef6d.0@news.povray.org>, Andrew Cocker  typed...
>Hi,
>Thanks in advance.
>Andy C.
>camera
>light_source
>  0*x
>union {
>    pigment
>    spotted color_map {
>                scale .2}
>light_source
>  translate <0, 0, 0>
>// Add media
>        interior {
>        media {
>  intervals 40
>  samples 1, 10
>  confidence 0.9999
>  variance 1/1000
>  ratio 0.9
  http://members.aol.com/inversez/POVring.html
=Bob
Date: 1 Dec 1998 17:55:28
Message: <366473e0.0@news.povray.org>
Thanks Bob and Margus, I've got the hang of it now.
Andy C.
Date: 2 Dec 1998 05:36:16
Message: <36651820.0@news.povray.org>
In article <3662ef6d.0@news.povray.org>, and### [at] acockerfreeservecouk
says...
>Hi,
... snip....
>    spotted color_map {
It's seems that your problem has been solved allready, but here's another
(of topic) little hint : To get a abrubt change (of color) in a colormap, or
any other mapping (texture_map, slope_map, etc) you may replace the above
piece of code with :
   spotted
   color_map {
	[0.0 Red]
	[0.6 Red]
	[0.6 Clear]
	[0.9 Clear]
	[0.9 Red]
	[1.0 Red]
assuming you don't want those small bands of smooth transitions.
Hope this helps somewhere,
	Rick.
Date: 2 Dec 1998 15:33:44
Message: <3665a428.0@news.povray.org>
Thanks Rick. I've been using Pov 2.2 until recently, then I got online and
downloaded 3.1. I'm still trying to adjust, but I'm getting there.
Date: 2 Dec 1998 23:22:27
Message: <36661203.0@news.povray.org>
I just happened to realize a slight mistake in a comment added to the example
scene I posted earlier, shown in part below.
media_interaction is on by default alright; however not so for
media_attenuation, which is needed for light falloff caused by fogs or
atmospheric effects, else it defaults to off.
Message <36646202.0@news.povray.org>, =Bob typed...
>light_source
=Bob
