POV-Ray : Newsgroups : povray.general : #while loops and staggered offsets ? Server Time
30 Apr 2026 05:25:16 EDT (-0400)
  #while loops and staggered offsets ? (Message 1 to 6 of 6)
Subject: #while loops and staggered offsets ?
Date: 4 Nov 1998 16:50:09
Message: <3640CBD5.70F83EFB@pacbell.net>
Greetings people!
I can creat a 100 object matrix by using a while loop as follows:
#declare x1 =  0;
#while  (x1 < 10)
#declare z1 =  0;
#while  (z1 < 10)
object{Obj translate <x1,0,z1>}
#declare z1 = z1 + 1;
#declare x1 = x1 + 1;
How would I create the same sort of grid where evey other
row in the z direction is offset by 0.5 in the x direction.
My intention is easying the pain of placing shingles on a
roof where it is important that the cracks of overlapping
rows do not line up while back filling the spaces that would
be left by doing so.
Any suggestions ?
Ken Tyler
Subject: Re: #while loops and staggered offsets ?
Date: 4 Nov 1998 17:06:01
Message: <3640cfc9.0@news.povray.org>
//I switched your loops around so you won't have as many calculations.
#declare x2 =  0;
#declare z1 =  0;
#while  (z1 < 10)
  #declare x1 =  0;
  #while  (x1 < 10)
    object{Obj translate <x1+x2,0,z1>}
  #declare x2 = 0.5 - x2;
Date: 4 Nov 1998 17:14:27
Message: <3640D188.6A14DB43@pacbell.net>
I'll try it out. Thank you Ron.
Ken Tyler
> #declare x2 =  0;
> #declare z1 =  0;
> #while  (z1 < 10)
>   #declare x1 =  0;
>   #while  (x1 < 10)
>   #end
> #end
Date: 4 Nov 1998 20:49:19
Message: <364103BC.FD928188@pacbell.net>
For my next trick....
How would I go about getting each horizontal row to rise
0.2 in the y direction. I attempted the following and ended
up with a slope that should be equivelant to -x -y to +x +y
instead of a uniform -x +x -y to -x +x +y. I hope that made
since.
Perhaps this is a good graphic example of what happened.
#declare Obj = box{-1,1 scale<.9,.2,1.5>pigment{rgb 1}}
#declare x2 =  0;
#declare z1 =  0;
#while  (z1 < 10)
  #declare x1 =  0;
  #while  (x1 < 10)
    object{Obj translate <x1+x2,x1*.2,z1>}
Thanks again.
Ken Tyler
> #declare x2 =  0;
> #declare z1 =  0;
> #while  (z1 < 10)
>   #declare x1 =  0;
>   #while  (x1 < 10)
>   #end
> #end
Date: 5 Nov 1998 02:18:56
Message: <3641514E.3E5A0B81@peak.edu.ee>
x1 goes from 0 to 10 each row, that's why you get this effect when using it for
Y position. Try this:
#declare x2 =  0;
#declare y1 =  0;
#declare z1 =  0;
#while  (z1 < 10)
	#declare x1 =  0;
	#while  (x1 < 10)
	object{Obj translate <x1+x2,y1,z1>}
#declare x2 = 0.5 - x;
#declare y1 = y1 + .2
Date: 5 Nov 1998 02:21:03
Message: <364151A7.9B5E9B8E@pacbell.net>
Thank you very much.
Ken Tyler
> #declare x2 =  0;
> #declare y1 =  0;
> #declare z1 =  0;
> #while  (z1 < 10)
>         #declare x1 =  0;
>         #while  (x1 < 10)
> #end
> #end
