POV-Ray : Newsgroups : povray.general : layering transparent surfaces, more than 4? Server Time
10 Jul 2026 15:16:05 EDT (-0400)
  layering transparent surfaces, more than 4? (Message 1 to 5 of 5)
Subject: layering transparent surfaces, more than 4?
Date: 21 Oct 1998 00:44:38
Message: <362D5909.56F8@geocities.com>
It seems as though povray has a hard time layering more than four
transparent surfaces on top of each other.  Am I correct? Is this a
known issue? Or is it my version of Pov? (currently 3.00e, 3.02 won't
run)
Run this source and it should be fine, but change the loop from .4 to .5
and the last layer's transparent color will turn black.
---BEGIN POV FILE---
camera { location -z look_at 0 }
light_source { <0,0,-1> rgb 1 }
light_source { <0,0,1.5> rgb 1 }
#declare c=0
#while (c<.4) /* <-- change this to .5 */
  plane { z,0
    pigment { checker rgb x, rgbt<.5,.5,.5,1> scale .2 }
    translate <0,0,c>
  #declare c=c+.1
plane { z,2 pigment { rgb 1 } }
---END POV FILE---
Maybe I don't know about an option somewhere to increase the depth at
which pov traces through transparent textures, if so please tell me!
Thnks much
-Cedar
Subject: Re: layering transparent surfaces, more than 4?
Date: 21 Oct 1998 01:28:40
Message: <362D6F87.9AA7A234@aol.com>
global_settings {
max_trace_level 5
Increase the integer to increase the number of tranparent surfaces POV will
bother with.
-Mike
> Thnks much
> -Cedar
Date: 21 Oct 1998 01:36:44
Message: <362d64dc.0@news.povray.org>
try setting your max_trace_level higher
Have a good one, Maleko
_______________________________________________________
" If you wanna have fun, and don't need  a reason,
all you need is a gun, it's TOURIST season!"
Bugs Bunny  (modified)
Cedar Cox wrote in message <362### [at] geocitiescom>...
>run)
>#declare c=0
>  plane { z,0
>    translate <0,0,c>
>  #declare c=c+.1
>#end
>---END POV FILE---
>Thnks much
>-Cedar
Date: 21 Oct 1998 01:38:02
Message: <362D658D.7E22@geocities.com>
Mike wrote:
> global_settings {
> max_trace_level 5
> bother with.
> -Mike
Hmm... looks like i'll be spending a lot of time waiting for my image to
trace.  Either that or I'll use a height field. (see my IRTC stills
image if I get around to finishing it)
I knew it was somewhere!, thanks Mike
Date: 21 Oct 1998 05:05:46
Message: <362D9560.822CE640@peak.edu.ee>
> Thnks much
> -Cedar
max_trace_level... The most elusive of POV features ;)
I should  know, I hacked my brains, cursed and RTFM at least 2 times before
I got it.
Perhaps there should be a big notice about it at the POV webpage (well, at
least sth. to this effect), since this question is often asked (and reported
as a bug at least once).
Margus
