POV-Ray : Newsgroups : povray.general : Automatic copyright text - need math help Server Time
13 Jan 2026 01:22:31 EST (-0500)
  Automatic copyright text - need math help (Message 1 to 10 of 11)
Subject: Automatic copyright text - need math help
Date: 9 Oct 1998 03:46:03
Message: <361DB143.3DD7389F@usit.net>
Well, I was trying to do this myself, but my math is so weak it'll take
me forever.... :)
Ok. I was trying to make it so that the small text "Copyright 1998 by
Lewis Sellers" would automatically be placed in the bottom left of any
scene I rendered no matter the camera positions. Very handy in
animations, etc.
In the snip of code below, you'll see I declare cam_l for the camera
location value and cam_lat for the camera look_at value. Using those two
positions I try to compute the translate and rotate needed to position
the text properly.
I managed to get the text roughly where it needs to be, but can't figure
out how to rotate it.
If anyone who's mathematically endowed can help, I'd appreciate it. This
could be a neat little piece of code to plug in for everyone to
autoinsert copyrights on our pics during rendering. :-)
--min
#declare cam_l = <125,8,-2>;
#declare cam_lat = <0,0,0>;
    location  cam_l
    look_at cam_lat
    angle 90
#declare camc=vnormalize(cam_lat-cam_l);
//put up the copyright now matter where the darn camera is!
#debug concat(".x :", str(cam_l.x,5,2), "\n")
#debug concat(".y :", str(cam_l.y,5,2), "\n")
#debug concat(".z :", str(cam_l.z,5,2), "\n")
#debug "\n"
#debug concat("camc.x :", str(camc.x,5,2), "\n")
#debug concat("camc.y :", str(camc.y,5,2), "\n")
#debug concat("camc.z :", str(camc.z,5,2), "\n")
#debug "\n"
text {
    ttf "timrom.ttf" "Copyright 1998 by Lewis Sellers" .01, 0
    pigment { rgbt<1,0,0,1> }
    translate cam_l
    translate camc
    rotate<camc.x*360,0,0> //camc.y*360,camc.z*360>
    no_shadow
Lewis A. Sellers: writer and contract Multimedia Website Developer
mailto:lse### [at] usitnet (The Fourth Millennium Foundation)
http://www.public.usit.net/lsellers/ & http://www.intrafoundation.com
http://brain-of-pooh.tech-soft.com/users/critters/bios/sellers_lewis.html
You can bug the living bejesus out of me live on ICQ @ 491461
(If I don't get back to you within a month, I'm out of prozac in some
dark corner somewhere screaming things quite unintelligable but -- most
curiously -- thick with a sumerian accent.)
"The comedy is over" -i pagliacci
Subject: Re: Automatic copyright text - need math help
Date: 9 Oct 1998 14:31:59
Message: <361E486D.78A4FCB8@ltu.edu>
There's actually a LOT of math involved in that, especially if you want to
handle all sorts of sky vectors (rolling the camera).  Luckily for you, the
math has been done already.  I did it for my lens flare include file, and
adapted it for a "background" INC file (yet to be released).
The background.inc file creates a plane with a user-defined texture which is
lined up with the camera's view at a user-defined distance from the camera.
The math would basically be the same for putting everything in foreground, but
the user would specify a much shorter distance and probably want to clip the
plane (or use a different object, like a text object).
I'll post here again when I finish cleaning up the INC files.
-Nathan
> me forever.... :)
> animations, etc.
> the text properly.
> --min
> camera {
>     location  cam_l
>     look_at cam_lat
>     angle 90
> #debug "\n"
> #debug "\n"
> text {
>     translate cam_l
>     translate camc
>     no_shadow
Date: 9 Oct 1998 22:51:47
Message: <361ebdb3.0@news.povray.org>
I have done what you're trying to with Chris Colefax's lens flares include
file. See the thread "animated credits, on-screen display" starting 08/20/98
in povray.animations
Peter
Date: 9 Oct 1998 23:26:11
Message: <361EC5DF.6D1314A@usit.net>
Ah. I haven't looked at any lens flare files yet, but as I was doing the
copyright text thing I was thinking, you know, that might be how they do
those lens flare thingies.... :)
> -Nathan
Looking forward to it. In the meantime I'll see if I can assimilate some
lens flaring code... :)
Date: 10 Oct 1998 14:27:23
Message: <361FA0EC.9C210BC5@erols.kosher.com>
> me forever.... :)
> animations, etc.
#local CamE = <0,0,0>; //where the camera's look_at is
#local CamL = <10,12,1>; //where the camera's location is
#local CamZ = 2; //the amount of camera zoom you want
#local CamD = vnormalize(CamE-CamL);
#local CamR = vnormalize(vcross(y,CamD));
#local CamU = vnormalize(vcross(CamD,CamR));
text { ttf "cyrvetic.ttf","(c) 1998 by Lewis Sellers",.01,0
  texture { YourTexture }
  scale .1
  translate <-.65,-.45,CamZ>
  matrix < CamR.x,CamR.y,CamR.z,
           CamU.x,CamU.y,CamU.z,
           CamD.x,CamD.y,CamD.z,
           CamL.x,CamL.y,CamL.z >
  location CamL
  up CamU
  right CamR*4/3
  direction CamD*CamZ
Hope this helps,
John
"He has the power to rear-project major cities!" -- Mike Nelson
Date: 11 Oct 1998 07:14:15
Message: <3620850F.62B399B4@usit.net>
John VanSickle wrote:
> Hope this helps,
> John
Works nicely in fact.
I had no idea there was a "matrix" keyword until I saw it there. Not
that I would have known what to do with it though. But, I learned
something new today. :)
You should make it a standard .inc file if you haven't already.
danke,
--min
Date: 11 Oct 1998 16:11:24
Message: <36210ACC.159854D7@erols.kosher.com>
> > Hope this helps,
> > John
Well, when a problem calls for a matrix I usually pop out of the
woodwork...
I would, except that the camera definition is an important part of the
code, which means it's not a good candidate for .INC file status.
John
Date: 11 Oct 1998 20:31:49
Message: <36214000.436BEF16@usit.net>
I take it that povray isn't object oriented and you can just read those
things with povray.camera.look_at ? :)
Oh well...
Date: 15 Oct 1998 19:01:54
Message: <36267800.6F6AAC75@erols.com>
> Oh well...
No, at least not yet.
"Have the manners not to be hittin' the man until he's your husband, and
entitled to hit back!"
Date: 16 Oct 1998 12:21:47
Message: <3627644F.A02E0B5C@ltu.edu>
John:
This is great code!!! I'm just now taking a class in linear algebra, so this
really makes sense to me and I've adopted it into my lens flare include file.
I would make one change, though.  In the line that reads:
I would change "y" to the sky vector (the default happens to by "y").
This way, you can use it with scenes from Moray (which uses "z" as the sky
vector) and also with scenes that roll the camera.
-Nathan
> > me forever.... :)
> > animations, etc.
>   scale .1
> camera {
>   location CamL
>   up CamU
>   right CamR*4/3
>   direction CamD*CamZ
> Hope this helps,
> John
