I've recently compiled a small program that generates a sphere made of
triangles which's surface is modified to create an earth-like texture.
This produces a triangle mesh of a planet.
So, does anyone think that this is in any way useful? Because you could
probably do the same by creating a texture on a sphere, then rendering
it with a cylindrical camera and using is as a height-field and pass it
through John Beale's orb program.
If anyone thinks it might be useful I might add craters and such.
Guy
Can this program be use to generate other surface profiles
or were you only concerned with earths topography ?
Guy Rauscher wrote:
> Hi,>> I've recently compiled a small program that generates a sphere made of> triangles which's surface is modified to create an earth-like texture.> This produces a triangle mesh of a planet.>> So, does anyone think that this is in any way useful? Because you could> probably do the same by creating a texture on a sphere, then rendering> it with a cylindrical camera and using is as a height-field and pass it> through John Beale's orb program.>> If anyone thinks it might be useful I might add craters and such.>> Guy
If I used a larger extrusion amount and added some craters and used a
solid color (instead of using blue for the sea in the lower areas) it
could easily be an asteroid. At least so I would like to believe.
Guy
K. Tyler wrote:
> > Can this program be use to generate other surface profiles> or were you only concerned with earths topography ?> > Guy Rauscher wrote:> > > Hi,> >> > I've recently compiled a small program that generates a sphere made of> > triangles which's surface is modified to create an earth-like texture.> > This produces a triangle mesh of a planet.> >> > So, does anyone think that this is in any way useful? Because you could> > probably do the same by creating a texture on a sphere, then rendering> > it with a cylindrical camera and using is as a height-field and pass it> > through John Beale's orb program.> >> > If anyone thinks it might be useful I might add craters and such.> >> > Guy
