POV-Ray : Newsgroups : povray.general : Terrain on a sphere Server Time
27 Nov 2025 11:02:08 EST (-0500)
  Terrain on a sphere (Message 1 to 3 of 3)
Subject: Terrain on a sphere
Date: 3 Jul 1998 09:14:42
Message: <359D6502.1520@netvision.net.il>
I've recently compiled a small program that generates a sphere made of
triangles which's surface is modified to create an earth-like texture.
This produces a triangle mesh of a planet.
So, does anyone think that this is in any way useful? Because you could
probably do the same by creating a texture on a sphere, then rendering
it with a cylindrical camera and using is as a height-field and pass it
through John Beale's orb program.
If anyone thinks it might be useful I might add craters and such.
Guy
Subject: Re: Terrain on a sphere
Date: 3 Jul 1998 12:44:48
Message: <359CEE5F.71FD2324@pacbell.net>
Can this program be use to generate other surface profiles
or were you only concerned with earths topography ?
Guy Rauscher wrote:
> Hi,
> Guy
Date: 3 Jul 1998 12:55:53
Message: <359D98D9.55@netvision.net.il>
If I used a larger extrusion amount and added some craters and used a
solid color (instead of using blue for the sea in the lower areas) it
could easily be an asteroid. At least so I would like to believe.
Guy
> Guy Rauscher wrote:
> > Hi,
> > Guy
