POV-Ray : Newsgroups : povray.general : Can these textures be created in POVRay, or is a patch required? Server Time
28 Dec 2025 16:01:27 EST (-0500)
  Can these textures be created in POVRay, or is a patch required? (Message 1 to 6 of 6)
Subject: Can these textures be created in POVRay, or is a patch required?
Date: 26 Dec 2002 19:14:30
Message: <1373988.gytDmvXUDI@3-e.net>
http://racah.fiz.huji.ac.il/~eldadb/mic-react.html
Microscopic Simulation of Reaction-Diffusion Processes
They describe an entire class of common textures found in natural phenomena,
that seem to be missing from all of the POV work I have seen over the
years, with the exception of a few image maps such as those on G. Tran's
Zebras.
Your connection failed because: Zombie processes detected, machine is
haunted.
Subject: Re: Can these textures be created in POVRay, or is a patch required?
Date: 26 Dec 2002 19:25:27
Message: <2936172.5NhTkAMmrk@3-e.net>
> phenomena, that seem to be missing from all of the POV work I have seen
> over the years, with the exception of a few image maps such as those on G.
> Tran's Zebras.
Ugh! That page is a little old (suffering from link rot).
Here is another,
http://cnls.lanl.gov/~aric/Simulations/Simulations.html
Date: 26 Dec 2002 20:42:44
Message: <chrishuff-306E79.20380326122002@netplex.aussie.org>
In article <293### [at] 3-enet>, Daniel Matthews <dan#@3-e.net>
> > Tran's Zebras.
> Here is another,
These seem to be a bit different from the procedural patterns POV uses.
They look like they have more in common with cellular automata...they
are computed at a grid of points over a limited domain, such as a finite
2D square. They are not ideal for POV patterns, though you could
probably work them into the image_map feature (or possibly the density
file feature for a 3D version). An external program would be better, you
could adjust the pattern more easily and there is no real benefit to
having it part of POV.
It would be interesting to see them "grown" on the surface of an object
instead of a simple plane, but this would probably require tessellating
the object, or otherwise coming up with points on the object and
information about how they are connected by the surface, and I don't
know how you could apply it to the original object.
http://tag.povray.org/
Date: 26 Dec 2002 22:15:53
Message: <61255149.F6zaqS6GMA@3-e.net>
>> > G. Tran's Zebras.
>> Here is another,
Hmmm.. a density file could be generated with these methods
http://www.geocities.com/robisais/3dca.html
Your connection failed because: The data on your hard drive is out of
balance.
Date: 26 Dec 2002 23:01:10
Message: <3532126.DvuYhMxLoT@3-e.net>
I like rule 101
http://kidojo.com/~yebb/cellauto/generate.cgi?rule=101&width=1024&height=768&pixelwidth=1&format=gif&random=1&showimage=true&name=/cellauto_101.gif
Your connection failed because: Lawn mower blade in your fan need sharpening
Date: 27 Dec 2002 11:24:03
Message: <chrishuff-4F2CC9.11192727122002@netplex.aussie.org>
In article <612### [at] 3-enet>,
And you could do the simulations themselves in POV, doing something like
using a box or mesh triangle pair for each pixel. (I have done this, an
extension to use an array as input would make it easier and more
efficicent.)
POV-Script is very slow for heavy simulation though...you will quickly
end up with parse times running far longer than the render time of the
final scene-just for a single image map image. One reason I started
working on Sapphire (originally CSDL, C-like Scene Description Language
and later C-like Simulation Description Language).
For this kind of thing, languages like C/C++/Java have annoying compile
and link stages that slow you down when you are constantly tweaking the
algorithm. It's fine for a final fast version, but a pain while
experimenting. Things like Ruby, Sapphire, even (gag) Python are better
because you just write and run, like you do with POV. Also, Ruby has an
interactive mode, where you work directly with objects, and Sapphire
will have similar features for modifying a running program (I don't know
if Python has these features).
