POV-Ray : Newsgroups : povray.general : Error? Server Time
29 Dec 2025 09:22:41 EST (-0500)
  Error? (Message 1 to 5 of 5)
Subject: Error?
Date: 11 Jul 2002 17:04:42
Message: <110720021604089456%reu1000@chorus.net>
Here's the error I've been getting every now and then:
   #declare vpmtemp = array[4][vpmS]
   # <----ERROR
   memory macro:64: error:  Attempt to malloc zero size block
(File:TOKENIZE.C Line: 4451).
I have no idea what this means, but it seems to be some kind of a
problem in defining variables when using one macro within another. (?)
The only way I have been able to fix this is by doing this the long way
around and by trial and error since I have no idea what it means!  Any
help or suggestions would be greatly appreciated.
 - Ricky
Subject: Re: Error?
Date: 11 Jul 2002 19:22:25
Message: <3d2e1331@news.povray.org>
I cannot say for absolute certain without seeing the source code for POVray,
but I know that if vpmS is ever equal to zero, that would likely cause such an
error. "malloc" is the name for the instruction to allocate a block of memory.
When nesting this inside a macro, you may be experiencing a "look-ahead"
problem- the compiler has to evaluate everything before it can get the true
value of vpmS, and it may not do so at a certain nesting depth.
    Just a thought, and it seems that I have seen a similar problem discussed
before.
Cheers!
Chip Shults
Subject: Re: Error?
Date: 12 Jul 2002 13:48:25
Message: <3d2f1669$1@news.povray.org>
In article <110720021604089456%reu### [at] chorusnet> , Reusser
>    # <----ERROR
Make sure vpmS is _not_ less or equal to zero!
    Thorsten
e-mail: tho### [at] trfde
Subject: Re: Error?
Date: 13 Jul 2002 11:33:55
Message: <130720021033236861%reu1000@chorus.net>
In article <3d2f1669$1@news.povray.org>, Thorsten Froehlich
DUMB MISTAKE on my part.  I accidentally had the dimension_size
operator looking at the wrong (non-existent) dimension of an array, so
it returned a zero instead.  I guess it makes perfect sense now...
Thanks!
 - Ricky
Subject: Re: Error?
Date: 14 Jul 2002 11:28:38
Message: <3d3198a5@news.povray.org>
> Thanks!
  Of course the error message could be clearer...
