POV-Ray : Newsgroups : povray.documentation.inbuilt : undocumented feature, two bugs and patch with fix for uv_mapped torus Server Time
13 Feb 2026 20:42:27 EST (-0500)
  undocumented feature, two bugs and patch with fix for uv_mapped torus (Message 1 to 1 of 1)
Subject: undocumented feature, two bugs and patch with fix for uv_mapped torus
Date: 8 Aug 2002 03:35:36
Message: <5n74lu880opvrjcbdarj0dbu2s016uqfu1@4ax.com>
Reading sources I found that torus object has uv mapping defined but it is not
written in documentation. That's probably becouse there are two bugs in
implementation. I have fixed it at http://abx.art.pl/pov/patches/uvtorus.php.
Comments ? Suggestions ?
Follow-up to povray.unofficial.patches.
ABX
Subject: Re: undocumented feature, two bugs and patch with fix for uv_mapped torus
Date: 8 Aug 2002 04:05:37
Message: <3D522650.A4633556@gmx.de>
Hmm, nice.
How about adding uv-mapping for cylinders?
Last updated 03 Aug. 2002 _____./\/^>_*_<^\/\.______
Date: 8 Aug 2002 04:07:21
Message: <vg94lu4s7i29ub34j1vrah0b2qto82pp8l@4ax.com>
On Thu, 08 Aug 2002 10:05:36 +0200, Christoph Hormann <chr### [at] gmxde>
wrote:
> Hmm, nice.
Thanks.
I thought about it and will probably try (including cones).
That's shouldn't be difficoult.
ABX
Date: 8 Aug 2002 17:21:34
Message: <3D52E112.60200@comtrade.ee>
ABX wrote:
 > I thought about it and will probably try (including cones). That's
In this case it would be good, if you use same (or at least as similar
as possible) mapping, as in case of RenderMan. This makes my life easier :-)
RenderMan uv-mapping for quadric primitives is described there:
http://www.pixar.com/renderman/developers_corner/rispec/rispec_3_1/section5.html
Subject: Re: undocumented feature, two bugs and patch with fix for uv_mappedtorus
Date: 9 Aug 2002 04:31:25
Message: <49v6lu41qfbfqogaa1sl32mba58sbqoebg@4ax.com>
On Fri, 09 Aug 2002 00:22:26 +0300, Vahur Krouverk <vkr### [at] comtradeee>
Thanks. I never expected I can make your life easier but I would be proud of
it. I will try but I have long list of patches to do so it will wait for a
moment.
ABX
