POV-Ray : Newsgroups : povray.documentation.inbuilt : Corrections to documented media defaults. Server Time
29 Aug 2025 06:38:10 EDT (-0400)
  Corrections to documented media defaults. (Message 1 to 10 of 13)
Subject: Corrections to documented media defaults.
Date: 15 Feb 2018 13:30:34
Message: <5a85d1ca$1@news.povray.org>
On the page:
http://wiki.povray.org/content/Reference:Media#Index_Entry_media_types
samples      : Min 1, Max 1
should be:
samples      : Min 10, Max 10
given we otherwise have the >=3.5 method 3 defaults documented.
Bill P.
Subject: Re: Corrections to documented media defaults.
Date: 15 Feb 2018 16:03:28
Message: <5a85f5a0$1@news.povray.org>
On 2/15/2018 1:30 PM, William F Pokorny wrote:
> On the page:
> should be:
> Bill P.
Off-topic, but your posts always show up as belonging to clipka in
Thunderbird. I think it is because you both use the same anonymous email
address.
Mike
Date: 15 Feb 2018 16:17:22
Message: <5a85f8e2$1@news.povray.org>
> address.
> Mike
I don't see that. (Thunderbird/Ubuntu).
You likely have anonymous in your address book and it substitutes.
dik
Rendered 920576 of 921600 pixels (99%)
Date: 15 Feb 2018 19:36:03
Message: <5a862773$1@news.povray.org>
Le 18-02-15 à 13:30, William F Pokorny a écrit :
> On the page:
> should be:
> Bill P.
It should be "samples 10"
min and max are only used with method 1 and 2.
Date: 15 Feb 2018 19:38:25
Message: <5a862801$1@news.povray.org>
>> On the page:
>> should be:
>> Bill P.
> address.
> Mike
Show correctly here. Thunderbird under Windows 7.
Date: 15 Feb 2018 23:15:01
Message: <web.5a8659e248f091b8a47873e10@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> On the page:
> should be:
What's also missing from all of the various media wiki references I've looked at
is that, with method 3, a *single* samples value can be used instead...
samples  35
....but even then, it isn't clear if method 3 is the *only* method that can do
that. Do methods 1 and 2 *require* 2 values?
The docs do need updating about this-- but I'm wondering if, sometime within the
v3.5-to-3.7 interval, the default samples value changed more than once(?) In
which case, changing the docs' default to  samples 10 (or 10,10?)  might raise
questions for users of those older versions-- if samples 1,1  as the default
'came and went' with various versions.  (Of course, that predicament cold be
easily solved with an extra note in the docs, about old vs. new behavior.)
Date: 16 Feb 2018 07:56:02
Message: <5a86d4e2$1@news.povray.org>
>> On the page:
>> should be:
>> Bill P.
Understand what you are saying, but here we are documenting what POV-Ray
is setting as the default if the language level seen by the parser is >=
3.5. This override happens on seeing the media keyword. A user can, for
example, still specify method 2 in that media and then knowing that
default max value is 10 matters.
Aside: I'm with you in not understanding why the parser sets the max
value for language level >= 3.5 for method 3, but it does. If it didn't
we'd need to leave Max 1 for the same reason - it helps users understand
what defaults are when those defaults apply to the method they are using.
Bill P.
Date: 16 Feb 2018 08:24:51
Message: <5a86dba3$1@news.povray.org>
> samples  35
Agree further doc updates are needed. As I dig deeper into media I'm
gathering a list of other documentation updates that would be helpful I
think including some of what you discuss. Trying not to go after too
much at once - and some behavior suppose we might change sooner rather
than later.
For example, while I've never made use of photons beyond playing with
the distribution sample scenes, I now know it's "method" for media is
it's own thing. 'Method photons' - suppose I see it as most like method
2 at this point - is not using at all the sample or jitter settings for
example. ...and I think photon jitter put into the photon media
depositing while debugging and got left in accidentally. I can see no
reason to introduce the banding artifact - see our optics.pov scene
(more visible if you reduce the media gather radius but it's there in
the scene we ship). The default jitter should be the full 1.0 always as
far as I can see.
We have this page:
http://wiki.povray.org/content/Reference:Sampling_Parameters_%26_Methods#Index_Entry_method_media
where it might be good to mention the effective method 'photons', how it
is different, how it can and cannot be controlled by media block
settings.  There is limited documentation where the photons feature is
documented.
(Yes, that page lists the default method 3 aa_level as 4 when it's 3 as
indicated on the initial wiki page of this thread.)
Anyway... Also so much of the whole of media behavior I still don't
understand.
Bill P.
Date: 16 Feb 2018 13:15:01
Message: <web.5a871e0048f091b8a47873e10@news.povray.org>
.....and I think photon jitter put into the photon media
> far as I can see.
I agree. Although I haven't used photons in awhile, I noticed a long time ago
that jitter 0.5 wasn't enough to eliminate visible 'rings', especially seen
close-up. I never mentioned it, though :-(  And I no longer have the test
scene that I used. If 0.5 is still the default, it does need reworking for a
smoother more-random appearance.
Date: 16 Feb 2018 13:43:48
Message: <5a872664$1@news.povray.org>
>>> On the page:
>>> should be:
>>> Bill P.
> Bill P.
Then, the various defaults should be given for each sampling methods.
Default :
Sampling method = 3
samples 10 (if you use two values, the second will be silently ignored)
intervals 1 (Don't change as it drastically increase rendering time)
confidance, variance are not used.
Optional methods are 1 and 2. For those the defaults are :
samples min 1 max 1
intervals 10
