POV-Ray : Newsgroups : povray.documentation.inbuilt : Lathe and Prism updates requested by Christoph. Server Time
20 May 2024 09:58:20 EDT (-0400)
  Lathe and Prism updates requested by Christoph. (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Lathe and Prism updates requested by Christoph.
Date: 26 May 2016 12:26:23
Message: <574723af$1@news.povray.org>
On 5/26/2016 4:56 PM, Le_Forgeron wrote:
> I also want to stress that it is topologically, and logically too, impossible to
define left/right with an alien over a radio link:
This is true but we are not dealing with aliens. (Well there might be
one or two. ;) )
PovRay has a default handiness with Y being up. Why not use that to
define clockwise and anti-clockwise?
Regards
Date: 26 May 2016 15:27:13
Message: <57474e11$1@news.povray.org>
> This is true but we are not dealing with aliens. (Well there might be one or two. ;)
> PovRay has a default handiness with Y being up. Why not use that to define clockwise
and anti-clockwise?
Povray has no default handiness.
There is a bit of usage and samples, but no definite handiness.
Date: 26 May 2016 15:55:34
Message: <574754b6$1@news.povray.org>
Just taking it from:
3.4.2.1.7 Handedness
The right vector also describes the direction to the right of the
camera. It tells POV-Ray where the right side of your screen is. The
sign of the right vector can be used to determine the handedness of the
coordinate system in use.
The default value is: right<1.33,0,0>. This means that the +x-direction
is to the right. It is called a left-handed system
Implied default handiness?
Anyway, if there are problems with nomenclature. Why not define
clockwise when looking from a positive Y-axis position, or whatever?
There is no need (IMO) to make the naming more complicated than the
development. :)
K.I.S.S. ;)
Date: 26 May 2016 19:10:01
Message: <web.574781c09ebd2b235e7df57c0@news.povray.org>
I would say that there is a definite handedness to POV-Ray, given the sign of
different directions on the axes, and the direction of rotation around the axes
in the (+) direction, I'd have to say that there's a default and inherent
chirality.
Left-handed coordinate system, and "left-hand rule" for determining things like
direction of rotation or direction of a normal.
But that's my take as an organic chemist, casual and incidental student of
physics and POV-Ray (l)user.
Date: 26 May 2016 20:04:08
Message: <57478ef8$1@news.povray.org>
On 5/25/2016 6:53 PM, Jim Holsenback wrote:
> On 5/24/2016 9:32 AM, William F Pokorny wrote:
>> Would someone who knows what they are doing wiki-wise - or who has the
>> "create" authority for the reference->object->lathe/prism sections can
>> create the talk/discussion area. Or, I suppose, if the update looks good
>> to those reviewing, just get it into the actual reference.
> lathe additions have been added:
> http://wiki.povray.org/content/Reference:Lathe
> didn't have time to do prism yet
prism additions have been added:
http://wiki.povray.org/content/Reference:Prism ... thanks for the
contribution
Date: 26 May 2016 20:11:30
Message: <574790b2$1@news.povray.org>
On 05/26/2016 11:56 AM, Le_Forgeron wrote:
> Le 26/05/2016 00:53, Jim Holsenback a écrit :
> Thanks for your time :-)
> I'm going to be painful, hopefully not to much for Jim, but other(s):
> what is "clockwise" and "counterClockwise" ?
> And before someone jumps in to state the obvious, think again about it.
> Usually (Danger Will Robinson, Danger), +X is to the right and +Y is up.
> And the direction of Z when going 3D is a holy war between left-hand and right-hand
system.
> But it is not unusual either that +X is to the right and +Y is down (many pictures
format have such convention).
> (origin at top left, and in fact, western-text has that same convention: Nth lines,
Mth character on that line)
> And some tenants of right-hand system like +X to the left, +Y up and +Z away (and
most 3D formats are rather right-handed... at least STL is strongly thought as such)
define left/right with an alien over a radio link: even using physical laws to have
the same experiment. You can define down and up (gravity is helpful), you can define
away and nearer, but,
> as the alien's environment might be matter or anti-matter, you cannot use anything
to provide the same definition of left & right.
> And if you cannot define left/right, clockwise and counterclockwise are lost too.
> All this, to ask for more explanation, or illustration, of "clockwise" and
"counterClockwise".
I'm not opposed to making things clearer. I was aiming for wording I
thought most would easily understand, while conforming somewhat to
conventions.
The clockwise vs counter-clockwise concept is used commonly for 2D
geometric algorithms and the lathe and prism spline point lists are 2D.
In the case of the lathe we are working in a normally defined x,y plane.
In the case of prisms we are working in a normally defined x,z plane.
There are different ways to make the determination, but for splines
which form closed loop(s), a counter-clockwise loop would be one such
that the sum over all the loop edges of (x2-x1)*(y2+y1) is negative.
Points inside a counter-clockwise loop of edges are considered to be
inside the shape. A clockwise loop reverses the points to shape
relationship.
In the case of lathes we can have edge(s) which do not form a closed
loop. There we chose a point (x3,y3) to the left of an edge and look at
the determinant (cross product) :
(x2-x1)*(y3-y1)-(y2-y1)*(x3-x1).
If the value returned is >0, the 'edge-by-direction' is
counter-clockwise with respect to the test point and the test point is
considered to be inside. If <0 the test point is considered outside. If
exactly 0, the test point is collinear with the edge.
POV-Ray today follows the above clockwise vs counter-clockwise 2D
conventions for determining inside vs outside everywhere except for the
bezier spline in the prism, where, the inside and outside conventions
are reversed for the prism sides. Further, all prism ends point outward
no matter the loop order.
Asides: There are degenerate, fringe point lists which will also fall
outside these 2D conventions, but I think users will not often deal with
them. The 2d clockwise vs counter-clockwise conventions are used mostly
with what is our linear spline. Of course for prisms replace y with z in
the equations above.
So, I guess the question is do we:
- add some or all the text above about 2d clockwise / counter-clockwise
conventions?
- add some figures explicitly showing the two example point lists or
others showing what would be clockwise and counter-clockwise point lists
with respect to inside/outside determination?
- change to more generic wording like 'orientation' and 'reverse
orientation' without any suggestions about normal, normal directions but
noting they flip.
- simply note that point list order matters to surface normal
determination in lathes and prisms and leave it at that? Starting to
feel like I have wandered off into the weeds... :-)
Thoughts?
Bill P.
Date: 26 May 2016 21:22:39
Message: <5747a15f$1@news.povray.org>
On 5/26/2016 8:11 PM, William F Pokorny wrote:
> Thoughts?
well ... i think i'll indulge my sweet tooth and make myself a root beer
float (substitute dr pepper) ... i'll leave the haggling up to you all
and will monitor this thread as well as your user page then make
whatever changes are needed once the chatter has settled down.
Date: 27 May 2016 03:37:19
Message: <5747f92f$1@news.povray.org>
> chirality.
I would say so too.
I know that if I use an image map and RH handiness in Bishop3D. The
image is reversed. Likewise PoseRay, on its PovRay output tab. States:
Right handed (PoseRay default) Y up
Left handed (POV-Ray default) Y up
I also used Moray where Z is up and am quite aware of all the kerfuffle
around this topic.
Personally I prefer the Y up because when I started work as an
Electronic Engineer, in the early 70's. The Z axis*, on an oscilloscope,
could be used to control the brightness of the waveform simulating depth.
<Aside> I seem to remember from that distant past. I was told that
engineers use the Y up, from the oscilloscope example. And that
mathematicians prefer the Z up coordinate system because they visualise
a XY graph on paper with the Z axis coming up from the desk. It doesn't
hold but it helps me visualise converting from one system to another.
* It was called the Z buffer.
# If you think I am using too many commas. It is to keep Dr. John amused. :)
Regards
Date: 28 May 2016 10:03:43
Message: <5749a53f$1@news.povray.org>
> Thoughts?
i added a note just before the passages in question for both the lathe
and prism objects ... hopefully that will suffice
Date: 30 May 2016 08:54:47
Message: <574c3817$1@news.povray.org>
>> Thoughts?
Yes, I think is good. Certainly MUCH simpler than any convoluted
explanation I had in the works for Jérôme's request :-). Thanks!
Bill P.
