POV-Ray : Newsgroups : povray.bugreports : FS#17 - square blotches in transparency recurrence ? Server Time
15 Nov 2025 13:17:30 EST (-0500)
  FS#17 - square blotches in transparency recurrence ? (Message 1 to 3 of 3)
Subject: FS#17 - square blotches in transparency recurrence ?
Date: 18 Mar 2013 19:40:01
Message: <web.5147a53e4732d1a85d50475e0@news.povray.org>
hello, i am currently having the same bug as described in :
http://bugs.povray.org/task/17
on Povray 3.7 RC7 msvc10.win64
the bug was fixed in change #4822, but in my scene it is recurring (or I may
have done something dumb, i hope so)
bug not sensitive to adc_bailout or max_trace_level
bug sensitive to +WTn
workaround is to render with +WT1 (one thread i presume)
synopsis of the scene animation :
a planet is seen from space at a quite low orbit. the orbiting camera moves to
the unlit side of the planet and the 32 pixels blotches appear in the
atmosphere. surface is made with isosurfaces, one for ground, one for water.
unrelated elements are commented.
uses LightSysIV for sun, but bug persists with standard light sources
atmosphere object uses rayleigh scattering media + density color map.
render procedure : scene use a state.dat file that stores an angle (function
describing angular velocity is not integrable, so i had to sum the angles for
rotation of the probe in a state file). because of the state you'll have to
render all frames from 1 to 40 at 320/240 or less to make it fast enough
depending on your configuration to see the bug around frames 20 to 40.
it should take less than 10 minutes.
povray.ini configuration :
initial_clock=0
final_clock=40
initial_frame=0
final_frame=40
thank you for any hints, or corrections to my code.
luckily, the render time during the unlit phases of the robit is a small portion
of the animation
Full scene for reference :
//**********************INCLUDES**********************************
#include "colors.inc"    // The include files contain
#include "stones.inc"    // pre-defined scene elements
#include "textures.inc"    // pre-defined scene elements
#include "shapes.inc"
#include "glass.inc"
#include "metals.inc"
//******************** CIE & LIGHTSYS ****************************
#include "LightSysIV\CIE.inc"
//CIE_ColorSystemWhitepoint(sRGB_ColSys,Illuminant_D50)
#include "LightSysIV\lightsys.inc"
#include "LightSysIV\rspd_jvp.inc"          // predefined material samples
#include "LightSysIV\CIE_tools.inc"
#include "LightSysIV\lightsys_constants.inc"
#include "LightSysIV\espd_lightsys.inc"
#include "LightSysIV\lspd_elements.inc"
#include "LightSysIV\rspd_pantone_coated.inc"
#include "LightSysIV\rspd_pantone_matte.inc"
#include "LightSysIV\rspd_aster.inc"
#include "LightSysIV\CIE_Skylight"
//********************** PERSONAL INCLUDES**********************************
//#include "heat-shield2.pov"
//********************** GLOBAL SETTINGS AND SWITCHES***********************
#declare one_frame = 0;
#declare radiosity_on = 0;
global_settings {
                    assumed_gamma 1
                    max_trace_level 20
                    ambient_light <0,0,0>
                    adc_bailout 0.002
                    #if (radiosity_on = 1)
                    radiosity {
                                 brightness 2.2
                                 count 50
                                 error_bound 0.15
                                 gray_threshold 0.0
                                 low_error_factor 0.2
                                 minimum_reuse 0.015
                                 nearest_count 10
                                 recursion_limit 3
                                 adc_bailout 0.01
                                 max_sample -1.0
                                 media off
                                 normal off
                                 always_sample 1
                                 pretrace_start 0.08
                                 pretrace_end 0.01
//********************** LIGHTS, STARS & ARTIFICIAL & SUN
//Star field
sphere {
   <0,0,0>, 100
   hollow
      image_map {
         png "starmap.png"
         map_type 1
         once
   finish {
      ambient 0
      diffuse 0
   scale 10000000000000
light_source{
            <0,20,-50>*10
            Light_Color(SunColor,1)
            adaptive 0
            jitter
#declare LC3 = EmissiveSpectrum(ES_HS_Sodium_Lamp);
#declare LC4 = EmissiveSpectrum(ES_Mitsubishi_Metal_Halide);
#declare LM3 = Lm_GE_LinearR7S_500w;
//#declare probe_projector = Light_Color(LC3,LM3*10);
//-----------------------------------ALIEN MEDUSA MACRO-------------------------
#macro alien_medusa(pos,size_rel,color_base_emi,color_base_xmit,trsp)
sphere { pos, size_rel
         hollow
         interior {
                 media{
                         emission
rgb<0.2,0.1,0.8*color_base_emi>*0.02/size_rel*10*color_base_emi
                         //scattering{ 1, 0.17 exnction 0.01}
                         method 3
                         intervals 5
                         samples 1,1
                         density{
                                  spherical
                                     turbulence 0
                                     color_map {
                                                 [0 rgb
<0.2,0.1,0.8>*5/size_rel*10*color_base_emi]//border
                                                 [1 rgb
<0.5,0,0.2>*2/size_rel*10*color_base_emi]//center
                    pigment{ crackle scale 0.1
                             color_map{[0.0 color rgbt
<0,0,0.7,1*trsp>*1.3*color_base_xmit]
                                       [0.5 color rgbt
<0.5,0,0.75,0.7*trsp>*1.15*color_base_xmit]
                                       [0.5 color rgbt
<0.2,0.5,0.8,0.3*trsp>*1.25*color_base_xmit]
                                       [1.0 color rgbt
<0.2,0,2,0.3*trsp>*1.3*color_base_xmit]
                                      }//end of color_map
                           } // end of pigment}
                    normal {
                             waves 1.5 frequency 0.5 scale 0.02
                    finish {
                             ambient 0.01 diffuse 0.5 phong 0.5 crand 2.3
reflection{ 0.6 metallic 0.85}
                            //irid { 0.2 thickness 0.1 }
                 } // end of texture
         scale<1,1,1>  rotate<0,0,0>  //translate<0,0.5,0>
       } // end of sphere
     alien_medusa(<0,0,0>,2.55,1,1.2,0.5)
     alien_medusa(<0,0,4.5>,1.25,1,1.6,0.4)
     alien_medusa(<4.5,0,0>,1.25,1,1.5,0.35)
     alien_medusa(<-4.5,0,4.5>,1.25,1,1.8,0.3)
     alien_medusa(<4.5,0,-4.5>,1.25,1,2,0.3)
//-----------------------------------OCEAN FUNCTIONS-------------------------
#declare fn_pattern=
                    function {
                                pattern { bozo turbulence 2 noise_generator 1.2
scale <1,1,1>*0.7 }
#declare fn_water=
                    function {
                                sqrt(pow(x,2) + pow(y,2) + pow(z,2)) -
0.04*((fn_pattern(x,y,z))) - 4.47
//-----------------------------------TERRAIN FUNCTIONS-------------------------
#declare fn_pattern2=
                    function {
                                pattern { wrinkles turbulence 4 noise_generator
2.2 scale <1,1,1>*0.7 }
#declare fn_terrain=
                    function {
abs(0.07*((fn_pattern2(x,y,2*z)))) - 4.478
#declare ocean = isosurface {
                                function { fn_water(x, y, z) }
                                accuracy 0.05
                                max_gradient 5
                                contained_by { sphere { <0,0,0>,5.2 }}
                                          pigment { color rgbt <0.0,0.3,0.6,0.4>
                              finish {ambient 0.0 reflection 0.4
                                      //irid { 0.6 thickness 0.4 }
#declare terrain = isosurface {
                                function { fn_terrain(x, y, z) }
                                accuracy 0.05
                                max_gradient 2.5
                                contained_by { sphere { <0,0,0>,5.25 }}
                                          pigment {color rgb < 0.8, 0.6, 0.15>}
                                          normal {granite 0.2 scale 0.02}
                                          normal { bumps 0.4 scale 0.02}
                                          finish {
                                                   brilliance 1.6
                                                   specular 0.3
                                                   ambient 0.0
declare atmosphere = sphere {
                              <0,0,0>,1
                              hollow
                              material {
                                                    pigment { rgbt <1,1,1,0.8> }
                                                    //finish {irid { 2.6
thickness 0.4 }}
                                         interior {
                                                    media {
                                                            method 3
                                                            intervals 1
                                                            confidence 0.0001
                                                            variance 1.0/1.0
                                                            scattering
{4,<0,0.502,1.0>}
                                                            density {
        spherical
        color_map
 [ 0.0 rgb <0.00,0.00,0.00>*6 ]
 [ 0.005 rgb <0.002,0.002,0.002>*6 ]
 [ 0.1 rgb 0.08*4.5 ]
 [ 0.2 rgb 0.1*3 ]
 [ 0.3 rgb 0.5*1.5 ]
 [ 1.0 rgb 0 ]
                              scale 4.9
 #declare CloudTexture = texture {
                                            bozo
                                            colour_map {
                                                          [0.00 colour rgbt
<0,0,0,1>]
                                                          [0.40 colour rgbt
<1,1,1,1>]
                                                          [0.60 colour rgbt
<1,1,1,0.80>]
                                                          [0.85 colour rgbt
<1,1,1,0>]
                                                          [1.00 colour rgbt
<1,1,1,0>]
                                            turbulence 4.0
                                            lambda 3.0
                                            omega 0.55
                                            ramp_wave
                                            scale <1,0.55,0.5>*5
#declare CloudTexture2 = texture {
                                            bozo
                                            colour_map {
                                                          [0.00 colour rgbt
<0,0,0,1>]
                                                          [0.55 colour rgbt
<1,1,1,1>]
                                                          [0.65 colour rgbt
<1,1,1,0.70>]
                                                          [0.80 colour rgbt
<1,1,1,0>]
                                                          [1.00 colour rgbt
<1,1,1,0>]
                                            turbulence 2.0
                                            lambda 3.0
                                            omega 0.55
                                            ramp_wave
                                            scale <1,0.9,0.5>*5
#declare CloudSphere1 = sphere { <0,0,0>,4.65
                                    texture { CloudTexture }
                                    hollow
#declare Cloudsphere2 = sphere { <0,0,0>, 4.72
                                    texture { CloudTexture2 }
                                    hollow
#declare PlanetCloudSphere0 = union {
                                      object {CloudSphere1}
                                      object {Cloudsphere2}
object {PlanetCloudSphere0}
object {terrain}
object {ocean}
object {atmosphere}
#declare max_items = 1;
#declare amt = array[1];
#declare amt2 = 1.4*exp(sin(0.025*((clock+1) - 72.2))) - 3.8;
#macro SaveState()
       #fopen file "state.dat" write
       #local i = 0;
       # while (i<max_items)
               #write ( file, amt[i])
               #local i=i+1;
       #fclose file
#macro LoadState()
       #fopen rfile "state.dat" read
       #local i = 0;
       #while (i<max_items)
               #read ( rfile, amt3)
               #local i=i+1;
       #fclose file
       #declare amt[0] = amt3;
#if (clock = 1)
#declare amt[0] = amt2;
SaveState()
LoadState()
#declare orbit = <-0.5*exp(sin(0.025*(clock - 72.2))) + 5.87,0,0>;
#declare height = orbit.x;
#declare orbit = vrotate(orbit,<-60,0,0>); // tilt orbit up
#declare orbit = vrotate(orbit,<0,30,0>); // twist orbit a bit
#declare orbit = vrotate(orbit,<0,amt[0],0>); // rotate about origin
#declare orbit2 = <-0.5*exp(sin(0.025*(clock - 72.2))) + 5.87,0,0>;
#declare orbit2 = vrotate(orbit2,<-60,0,0>); // tilt orbit up
#declare orbit2 = vrotate(orbit2,<0,30,0>); // twist orbit a bit
#declare orbit2 = vrotate(orbit2,<0,amt[0] - 60,0>); // rotate about origin
#declare amt[0] = amt[0] + amt2;
#if (one_frame = 0)
SaveState()
#declare height2 = trace(ocean,orbit,vnormalize(-orbit)*0.01);
#declare prograde = orbit2 - orbit;
#declare pro_right = vcross(orbit,prograde);
#declare orbit_v =  orbit;
//#declare Pt = <0,10,-10>;
//#declare Orig = <0,0,0>;
//#declare Axis = <0,0,1>;
#declare dstx = abs(orbit.x) - abs(height2.x);
#declare dsty = abs(orbit.y) - abs(height2.y);
#declare dstz = abs(orbit.z) - abs(height2.z);
#declare height3 = sqrt(pow(dstx,2) + pow(dsty,2) + pow(dstz,2));
#warning concat("HEIGHT3 ", str(height3.x,5,5))
#warning concat("ROT ", str(amt2,5,5))
#warning concat("ROT integral ", str(amt[0],5,5))
#warning concat("orbit_v x ", str(orbit_v.x,5,5))
#warning concat("orbit_v y ", str(orbit_v.y,5,5))
#warning concat("orbit_v z ", str(orbit_v.z,5,5))
#warning concat("height2 x ", str(height2.x,5,5))
#warning concat("height2 y ", str(height2.y,5,5))
#warning concat("height2 z ", str(height2.z,5,5))
#warning concat("orbit x ", str(orbit.x,5,5))
#warning concat("orbit y ", str(orbit.y,5,5))
#warning concat("orbit z ", str(orbit.z,5,5))
#warning concat("orbit2 x ", str(orbit2.x,5,5))
#warning concat("orbit2 y ", str(orbit2.y,5,5))
#warning concat("orbit2 z ", str(orbit2.z,5,5))
#warning concat("prograde x ", str(prograde.x,5,5))
#warning concat("prograde y ", str(prograde.y,5,5))
#warning concat("prograde z ", str(prograde.z,5,5))
//object {heat_shield rotate y*180 scale 0.0001  translate (orbit) translate
(orbit2/10000 - orbit/10000)*0.10*clock}
//********************************* PROBE CAMERA
         //location (Orig + vaxis_rotate(Pt - Orig, Axis, 5*clock))
           location orbit
           look_at orbit2
           sky vnormalize(orbit)
           angle 50
Subject: Re: FS#17 - square blotches in transparency recurrence ?
Date: 18 Mar 2013 20:27:01
Message: <5147b0d5@news.povray.org>
Am 19.03.2013 00:37, schrieb rodv92:
Let's rephrase this: You're seeing similar symptoms. Whether it is the
same bug is yet to be examined.
>                      radiosity {
>                                   brightness 2.2
>                                   count 50
>                                   error_bound 0.15
>                                   gray_threshold 0.0
>                                   minimum_reuse 0.015
>                                   nearest_count 10
>                                   recursion_limit 3
>                                   adc_bailout 0.01
>                                   max_sample -1.0
>                                   media off
>                                   normal off
>                                   always_sample 1
>                                   pretrace_start 0.08
>                                   pretrace_end 0.01
32x32 block artifacts may also appear when a significant number of
radiosity samples is taken during the main render rather than the
pretrace. This is why "always_sample" now defaults to off, and it is
highly recommended to leave it at this setting. (I can't think of any
scenario where "always_sample on" would make any sense; if it wasn't for
backward compatibility, I'd have kicked it out of 3.7 in no time flat.)
Can you please try again with "always_sample off", and let us know
whether this fixes the block artifacts?
("brightness 2.2" is also not recommended - it should be left at the
default of 1.0 unless you know what you're doing - but that's a
different story and has nothing to do with the issues you're reporting.)
Date: 19 Mar 2013 08:30:01
Message: <web.51485a3b4eb1e5845d50475e0@news.povray.org>
hello!
My bad, i didn't thought that always_sample would be taken into account inside a
radiosity block under a if block evaluated to false, but still it was my mistake
to not have tried first to change the value.
so yes, it works now thanks to you.
i will perform a little ritual with an offering to the POV-Ray Gods to calm
their wrath :)
thanks !
> >                      radiosity {
> >                                   brightness 2.2
> >                                   count 50
> >                                   error_bound 0.15
> >                                   gray_threshold 0.0
> >                                   minimum_reuse 0.015
> >                                   nearest_count 10
> >                                   recursion_limit 3
> >                                   adc_bailout 0.01
> >                                   max_sample -1.0
> >                                   media off
> >                                   normal off
> >                                   always_sample 1
> >                                   pretrace_start 0.08
> >                                   pretrace_end 0.01
