![](/i/fill.gif) |
High!
Version 3.7 RC5 apparently is not yet able to handle animation loops
properly: when I tried to render this script
background
#switch (clock)
#range (0, 24)
color rgb 0
#break
#range (25, 99)
color rgb (clock-25)*<0, 1/75, 1/75>
#break
#range (100, 299)
color rgb <0, 1, 1>
#break
location <0, 2, -3>
look_at <0, 1, 2>
sphere
#switch (clock)
#range (0, 99)
<0, 1, 2>, 0
#break
#range (100, 199)
<0, 1, 2>, (clock-100)*0.02
#break
#range (200, 299)
<0, 1, 2>, 2
#break
texture // line 32
pigment { color <1, 1, 0> }
light_source
<2, 4, -3>
#switch (clock)
#range (0, 199)
color rgb 0
#break
#range (200, 299)
color rgb (clock-200)*0.01
#break
#range (300, 399)
color rgb 1
#break
with +ki0 +kf299 +kfi0 +kff 299, PoV-Ray prompted an error message on
line 32: parse error: Expected 'numeric expression', texture found instead
The same scene runs flawlessly under 3.6!
See you in Khyberspace!
Yadgar
![](/i/fill.gif) |
![](/i/fill.gif) |
> High!
Looks like POV-Ray slips through the second #switch statement without
matching any of the #range blocks. Note that you failed to cover the
whole possible range: 99.5, for instance, isn't in included.
Now you may think that your animation settings should make sure that
clock = frame number, and therefore an integer value. However, note that
those settings don't instruct POV-Ray to just use frame_number as clock
- it still computes the clock like it would for any "odd" setting. As a
result, you may get rounding differences, and end up with clock values
of something like 99.999999.
Just make sure your ranges overlap (e.g. #range(0,100) and
#range(100,200)); POV-Ray will pick the first match and be done with it,
so a value of 100 will only hit the first range block.
![](/i/fill.gif) |
