POV-Ray : Newsgroups : povray.bugreports : bounding boxes again Server Time
13 Jul 2025 14:18:51 EDT (-0400)
  bounding boxes again (Message 1 to 7 of 7)
Subject: bounding boxes again
Date: 10 Jan 2010 07:30:55
Message: <4b49c87f$1@news.povray.org>
Hello!
transform is not transforming the bounding boxes in this release (beta
35). I think this happened already in beta 32 (if i remember). Again,
this code renders ok in pov 3.6:
global_settings{#if(version < 3.7) assumed_gamma 1 #end}
camera{location x*10+z*5+y*5 look_at 0}
light_source{(x+y)*10 1}
background{rgb <0.5,0.6,0.7>}
#declare T1= transform{translate x}
#declare Ob1= intersection{
   sphere{0 10 translate -z*9.5}
   sphere{0 10 translate z*9.5}
   cylinder{z*2,-z*2 1 inverse}
   pigment{red 1}
   bounded_by{box{2.6, -2.6}}
   transform{ T1}
#declare Ob2= intersection{
   sphere{0 10 translate -x*9.5}
   sphere{0 10 translate x*9.5}
   cylinder{x*2,-x*2 1 inverse}
   pigment{green 1}
   transform{ T1}
union{
   object{Ob1} //<----- :?.. where is my bounding box!
   object{Ob2}
transform{T1}
Thank you!
Subject: Re: bounding boxes again
Date: 12 Jan 2010 04:47:36
Message: <4b4c4538@news.povray.org>
Martin a écrit :
> Hello!
Manual bounding is not clipping.
From my historical knowledge: windows-pov got a default +MB3 whereas
unix sticked to +MB25
Maybe the 3.7 get a uniform value for all ?
With so few objects, bounding would be turned off, which might explains
your issue.
Whatever, if you want to clip, use clipping_by.
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
Date: 12 Jan 2010 13:42:01
Message: <4b4cc279@news.povray.org>
  clipped_by is another possibility. It's slightly better in that it doesn't
give any parsing error.
Date: 14 Jan 2010 05:57:58
Message: <4b4ef8b6$1@news.povray.org>
> your issue.
What is it that makes you think that i want to clip? I want to bound.
The objects should look as two lenticular shapes. Is just a test.
I have more complex objects prperly bounded_by, to speed render, that
rendered ok with beta 34, and now don't render as they should, and the
objects are exactly the same.
+MB25 gives the same (wrong) results in this beta.
Thank You
Date: 14 Jan 2010 17:10:43
Message: <4b4f9663$1@news.povray.org>
Le 14/01/2010 11:58, Martin nous fit lire :
But that bounding is:
 1. Manual (and probably not needed)
 2. far too big at least in one direction
 3. wrong: some part of the intersection are outside the box (check it
with clipped_by or adding the box in the intersection)
Garbage in, Garbage out.
Hence my suggestion to clipped_by.
Date: 15 Jan 2010 05:09:49
Message: <4b503eed$1@news.povray.org>
All right, sorry. At first sight it seemed to me the same problem, so I
was using a test 2 years old, thinking it was well bounded :).
Now I try to see what happens, and seems like the cone is inverted.
Date: 15 Jan 2010 06:08:08
Message: <4b504c98$1@news.povray.org>
I installed beta 35 just five days ago, and i've seen the new one right
now. Problem solved.
Thanks to you and all the Pov-team for doing pov-ray.
