![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello!
I have a reduced scene containing a height_field that would cause povwin
to crash (so I suppose, it's a bug).
I strongly suspect a division by zero error in the height_field code,
since the error can be avoided if you slightly change the perspective or
use Jitter when antialiasing output.
My setup:
Official Version 3.1g.watcom.win32
Win98 de 4.10.1998
Pentium II 300 MHz
64 MB RAM
Here is the scene:
------------start-----------
#declare Set_to_zero = 0.01;
camera
location -z*2
direction z
right x
up y
look_at Set_to_zero
light_source
<10, 4, -20>
color rgb 1
height_field
tga "hf.tga"
color rgb 1
rotate x * 270
translate <-0.5, -0.5, 0>
-------------end------------
INI and Command Line Options:
Original quickres.ini, 160x120, AA 0.3
-j
povray will crash if 1) the variable Set_to_zero is zero and 2) you
disable antialiasing jitter.
I posted the height_field tga (12 kB) to the binaries.images.group
(Xref: news.povray.org povray.binaries.images:16962, this message is a
reply to it)
/PETER/
Peter Santo (PUMP development)
Visit: http://www.mp3pump.de
linux quote of the week:
It _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Peter Santo wrote:
> Hello!
> My setup:
> Win98 de 4.10.1998
> Pentium II 300 MHz
> 64 MB RAM
> reply to it)
> /PETER/
I can verify that this does crash the render session at 24% completion in
a predictable manner. I am using the same build of Pov and windows 98 that
Peter is using on a p200 mmx system with 128 megs of ram.
Note: The image Peter used for the height field is an 8 bit compressed targa
file and I was also able to reproduce the fault with an 8 bit uncompressed
targa file. Also note that rendering at a resolution of 100x100 does not
cause it to crash but any higher resolution does.
Ken Tyler
Older Links Page: http://home.pacbell.net/tylereng/links.htm
Updated Links Page: http://home.pacbell.net/tylereng/bkmrk999.htm
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Sat, 07 Aug 1999 17:37:53 +0200, Peter Santo
<san### [at] pool informatik rwth-aachen de> wrote:
>Hello!
>My setup:
>Win98 de 4.10.1998
>Pentium II 300 MHz
>64 MB RAM
I get this too. As near as I can tell, it's crashing when the
intersection exactly hits the very edge of a triangle on the
edge of the heightfield. The line it crashes on says
y3 = Get_Height(px, pz+1, HField);
pz is 159, and HField->Data->max_z is 158. Not a pretty picture.
I'm not sure what can be done about this, unfortunately, unless it's
to subtract epsilon before rounding down to get pz. Perhaps someone
else has an idea.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: height_field crashes povwin 3.1g
Date: 11 Sep 1999 14:27:53
Message: <37da9f29@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ron Parker wrote <37acc879.22494197@news.povray.org>...
>>Hello!
>>My setup:
>>Win98 de 4.10.1998
>>Pentium II 300 MHz
>>64 MB RAM
>else has an idea.
Me too.
I am using POVRay 3.1a.watcom and I also got that error several times, with
different height_field TGA's and different scenes. (It once crashed in an
animation
on frame 20 of 500 and I didn't notice until hours later...arrgh)
I prepared a simple scene .ZIPped to 5K. If anyone needs it
for debugging, mail to bia### [at] inetmail de.
After 16% of this is rendered, POVRay causes a Windows error dialog box to
be
displayed ("Allgemeine Schutzverletzung" - what's that in the English
Windows version ?)
which said:
in Modul PVENGINE.EXE bei 015f:0046fb77.
[PVENGINE caused an error by illegal page in module PVENGINE.EXE at ...]
Register:
EAX=00000000 CS=015f EIP=0046fb77 EFLGS=00010246
EBX=018a210c SS=0167 ESP=0186fc50 EBP=0186fd34
ECX=b0b0b0b1 DS=0167 ESI=01880048 FS=13c7
EDX=018b0b28 ES=0167 EDI=00000001 GS=0000
Bytes bei CS:EIP:
66 8b 01 db 84 24 dc 00 00 00 89 84 24 dc 00 00
Stapelwerte: [stack values]
00000000 3d100000 47bd4ee6 3fedbcc2
00000001 00000063 00000000 17971c19
00000004 0186f72c 0186f72c 0186f908
00000008 00000004 00000001 0186fd80
This must be the same problem as Peter Santo has.
My setup is:
iP 133 MHz, 32MB RAM, Win98
A friend of mine with an
iP2 333 MHz, 64MB RAM, Win95C
got the error at 16%, too.
Something has to be done about this, but I don't think I'd understand
the source code... (just about to start with C)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
