![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I use POVRAY to make images of straylight in optical systems. The very low
intensity parts of the image are the most interesting. Although the
information is present in the red/green image it is not visually
intelligible. It would be nice to have a POV output file format that was
logarithmic - but otherwise a *.exe utility which inputs the heightfield
and outputs an image file which is proportional to the log ( decimal or
natural )of 1 to 65535.
Is anyone able and willing and sufficiently interested to create one and
publish it?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>publish it?
If you have an image processing program that accepts Adobe-compatible
plugins, then I can let you have a plugin that will perform such
processing. Windows only. I've tried testing it on a dark HF_gray_16 TGA
file, and it seems to be doing the right sort of thing, but I don't have
any images that are in any way improved by being logarithmised and the
output looks pretty naff until I perform additional contrast and
brightness processing.
If you don't have an image processing program that accepts Adobe-
compatible plugins, then it's possible to do it for free with Irfanview,
by installing "8BF-Filters.dll" from the Irfanview plugins page, which
allows Irfanview to run Adobe-compatible plugins.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>publish it?
I've now put the plugin on my website
http://www.econym.demon.co.uk/plugins/index1.htm
There seems to be a bit of a problem if you use the plugin with Paint
Shop Pro 8. I can't find any way to persuade PSP8 to save the data in
HF_Grey_16 format that's accepted by POV as a heightfield after
processing. It seems to be OK under Irfanview and PSP7.
I currently use the following rules (when my "Scale" parameter is left
at zero):
For 8-bit grey output: output=loge(input)*23.0832
For HF_Grey_16 output: output=loge(input)*5909
[These magic numbers were chosen such that the max input value of 65535
maps to the max output value (255 and 65535 respectively)]
I could easily change it to use other rules if you'd like. Or I could
write one that applies Gamma correction from HF_Grey_16 to HF_Grey_16.
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>publish it?
>at zero):
Oops.
There turned out to be a bit of a glitch in my plugin. The system I used
is documented as having 32-bit arithmetic, but in practice numbers
higher than 32767 were turning negative. Since I was dealing with 16-bit
greyscales, I needed to handle numbers up to 65535.
It's fixed now, but if you grabbed a version below v1.2, then expect it
to only work with dark images, like the ones I initially tested it with.
I've added a second plugin for linearly adjusting the brightness and
contrast of a HF_grey_16 image. It's actually a bit pointless because
you can achieve the same effects by linearly translating and scaling the
height_field in POV. It did, however, clue me in to the bug in the
first plugin.
I've now moved my HF plugins to a separate page of their own, since most
plugin users would be unlikely to be interested in them:
http://www.econym.demon.co.uk/plugins/hf.htm
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Thu, 18 Dec 2003 18:11:33 +0000, Mike Williams <nos### [at] econym demon co uk>
Nothing to do with this thread, just wanted to say I love the backgrounds on you
site. If you weren't "churchy" I would say, "Can I have some of what you've been
smoking" :-}
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>smoking" :-}
It's just a few randomized f_noise3d pigment functions.
camera {orthographic right 2*x up 2*y
direction z location <0, 0, -100>}
#include "functions.inc"
#declare R1=seed(51);
#declare A=rand(R1);
#declare B=rand(R1);
#declare F=function{f_noise3d(x*10*A,y*10*A,0)}
#declare G=function{f_noise3d(x*10*B,y*10*B,0)}
plane {z,0 pigment {
function {
F(abs(x),abs(y),0)
color_map {
#local C = 0;
#while (C < 1.1)
#declare C1=<rand(R1), rand(R1), rand(R1)>;
[C rgb C1]
#declare C = C + .01 + rand(R1)*.1;
[C rgb C1]
#end }
finish {ambient 1}
plane {z,-1 pigment {
function {
G(abs(x),abs(y),0)
color_map {
#local C = 0;
#while (C < 1.1)
#declare C1=<rand(R1), rand(R1), rand(R1), rand(R1)>;
[C rgbt C1]
[C rgbt C1]
#end }
finish {ambient 1}
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 19 Dec 2003 18:38:42 +0000, Mike Williams <nos### [at] econym demon co uk>
It looks quite Aztec-ish to me but the proof of the pudding is in the formula.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
