POV-Ray : Newsgroups : povray.binaries.utilities : Build human face from picture Server Time
28 Sep 2024 21:08:12 EDT (-0400)
  Build human face from picture (Message 1 to 10 of 10)
Subject: Build human face from picture
Date: 13 Oct 2001 10:04:33
Message: <3bc849f1@news.povray.org>
Would someone know a (good ?) program or plugin for building a human face
(in any format 'reusable'..) from 1 or several real pictures ?
Thanks..
Subject: Re: Build human face from picture
Date: 13 Oct 2001 20:06:52
Message: <3bc8d71c@news.povray.org>
I doubt there's a *good* one, but there most likely is some kind of
commerial program that will take image files from different angles and merge
them into one mesh. Such techniques aren't very accurate, though, and the
software would probably be expensive. Try a web search.
 camera{location<0,0.25,-2> look_at 0.5*y} #declare
T=texture{pigment{crackle scale 0.5 rotate 90 turbulence 0.75 color_map{[0
rgb 1][0.05 rgb 1][0.1 rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}}
finish{ambient 1}} #declare c=difference{torus{0.5,0.1
rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}  merge{object{c
translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
//Mahalis
"Eric" <eri### [at] wanadoofr> wrote in message
news:3bc849f1@news.povray.org...
> Thanks..
Date: 15 Oct 2001 02:54:04
Message: <3bca880c@news.povray.org>
 You *could* try http://www.photomodeler.com/
But  you'd need a _lot_ of patience and not loose track of where you are...
- Nekar
Version: 6.0.282 / Virus Database: 150 - Release Date: 2001/09/25
Date: 15 Oct 2001 10:30:49
Message: <3bcaf319@news.povray.org>
Eric wrote in message <3bc849f1@news.povray.org>...
face
>Thanks..
Don't know whether this is actually an answer but have you seen Rhino
(www.rhino3d.com). Also there's a technique for building a face from
orthographic views using HamaPatch/sPatch available through the
website links (from www.crosswinds.net/~hamapatch) . Probably Poser
may do what you want, too - I don't really know.
All except HamaPatch/sPatch are commercial programs, though, costing
over 300$.
Hope this helps
-Anoop
Date: 16 Oct 2001 16:03:47
Message: <3bcc92a3$1@news.povray.org>
what about the DMesh program?  anybody remember that?  it
was fairly labor-intensive but produced some decent stuff.  i
guess i'm not sure if you could use a photo or not, but i thought
it supported uv mapping.
good luck, miker
> Thanks..
Date: 16 Oct 2001 16:56:36
Message: <3BCC9F0F.518CEC27@aol.com>
You might try the "background image" feature in Hamapatch which corresponds to
the Animation Master "rotoscope" feature. This will allow you to assign a
background image to a view that you can use to follow the profile curves of
your photographs in creating a mesh.
Date: 17 Oct 2001 02:00:26
Message: <3bcd1e7a@news.povray.org>
Please tell me where I can get DMesh. I've been to the site but I couldn't find
the download.
- Nekar
"MR" <a### [at] bnet> wrote in message news:3bcc92a3$1@news.povray.org...
> good luck, miker
> > Thanks..
Date: 20 Oct 2001 17:29:42
Message: <3bd1ecc6@news.povray.org>
I think the author of DMesh is from Germany.
He wrote to me two years ago and I could find
his e-mail. Perhaps I have the zip file with
the dmesh.exe. I will look for it.
Kze### [at] Wanadoofr
Date: 27 Oct 2001 18:01:35
Message: <3BDB2FAA.56DBBC30@osgltd.com>
Hi Eric,
I made a simple util in Java that creates an inc file from a 2 color TGA image. It's
not great, but you can see an example
here: http://weirdx.sourceforge.net/image/20010110-weirdx-cygwin.png
-mike-
> Thanks..
Date: 30 Oct 2001 11:42:07
Message: <3bded85f@news.povray.org>
whoops!  sorry!  i haven't been back here in a while.  i believe
that the last time i seen dmesh, he had uploaded it to a third-
party distributor and was selling it as a low-cost app.  i'll see
what i can find.  if i find anything, i'll post back.
good luck, miker
"Nekar Xenos" <j-p### [at] citywalkcoza> wrote in message
news:3bcd1e7a@news.povray.org...
find
> the download.
> - Nekar
> > good luck, miker
face
> > > Thanks..
> Outgoing mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
