POV-Ray : Newsgroups : povray.binaries.utilities : hamapatch point selection Server Time
11 Oct 2025 01:04:03 EDT (-0400)
  hamapatch point selection (Message 1 to 10 of 14)
Subject: hamapatch point selection
Date: 28 Apr 2001 10:13:15
Message: <3AEAD036.D8194E58@exmail.de>
hope, this is not the wrong newsgroup!!
I'm starting to work with hamapatch, but i can't figure out how to
select points. Yes, i have read the manual, and yes, there is a
selection tool in the patch tab. But.. it doesn't work ;-((. I'm using
version 2.1.
can someone help me?
best wishes,
Robert
Subject: Re: hamapatch point selection
Date: 28 Apr 2001 15:09:02
Message: <MPG.155525b99f72db8c9898f2@news.povray.org>
On Sat, 28 Apr 2001 16:14:14 +0200, Robert =?iso-8859-1?Q?G=FCnther?=
wrote...
> Hi,
> version 2.1.
Select the tool on the objeccts tab that looks like a dashed box, and
drag a box around the points you want to select.
Or you can single click with the four pointed arrow tool (translate) to
select single points IIRC.
Bye for now,
     Jamie.
Date: 29 Apr 2001 05:10:14
Message: <3AEBDAB3.D3AE4B6C@exmail.de>
Hi Jamie,
thanks for answering, but what you call the dashed box, was what i meant
with the selection tool. It doesn't work!
I only can deselect points that were selected before. Ok, a work around is
to select all points with the select tab in the menu bar and then deselect
the desired points and then inverse them with the selection tab in the menu
bar.
But that can't be the idea of the dashed box??
(what is the meaning of IIRC?)
best wishes,
Robert
> Bye for now,
>      Jamie.
Date: 29 Apr 2001 06:27:34
Message: <ulpnet8ssghali9meo1vcn0noba2k2i4uk@4ax.com>
>Hi Jamie,
>bar.
Hi Robert,
 I have been using Hamapatch V2.1 quite a lot recently and the selection tool works
fine for
me.
The selection tool is the cross with four arrow heads, NOT the dashed box, which is
for
multiple selection in a rectangular area. This and the "lasso" tool work much the same
as
their equivalents in PSP.
To select single points;
1) selected the Patch tab
2) select the first button, (a cross with four arrow heads)
3) select each point individually with the left mouse button.
(I switch off the axes button for most operations)
The use of the Control button in combination with the mouse click is very important.
By holding down Control whilst clicking you can add or remove points from your
selection.
If you already have more than one point selected then you MUST hold down Control
whilst
clicking the left mouse button to select or deselect.
BTW, IIRC=if I remember correctly.
Hope this helps.
David
dav### [at] hamiltonitecom
http://hamiltonite.com/
Date: 29 Apr 2001 06:42:37
Message: <3AEBF05A.2A1BCB73@exmail.de>
Hi David,
the hint with the control button was the break through!!!
Many thanks! That's what i wanted.
Nevertheless, how does the rectanguler box and the lasso work? (don't know PSP). When
i do a
selection with them, nothing happens...
Many thanks again,
Robert
> Hi Robert,
fine for
> me.
for
same as
selection.
whilst
> Hope this helps.
> David
Date: 29 Apr 2001 07:21:26
Message: <5dtnetg3o1nqqvkt1ius5fajhffr8tl9n4@4ax.com>
>How does the rectanguler box and the lasso work? (don't know PSP). When i do a
Robert,
The rectangular box and the lasso are used to select multiple points.
The rectangle button works by placing the cursor somewhere near where you want to
start the
selection, then press and HOLD the left mouse button whilst you drag the cursor over
the
rectangular area you are interested in. Releasing the mouse button selects all the
points
contained within the rectangle.
The lasso button is used to draw an irregular area around points you wish to select.
This
works by again pressing and holding the left mouse button whilst dragging the cursor
around
the points you want to select.  This results in a white trace of the cursor.  When you
release
the mouse button all the points enclosed within the area of the white trace will be
selected.
The clue to both is to drag the cursor whilst holding down the left mouse button.
The use of inverse is also very useful here as you can select the points you DON'T
want and
then use inverse to get all those you want.
David
Date: 29 Apr 2001 07:31:27
Message: <3AEBFBCB.59466A6@exmail.de>
Hi David,
so far it was clear to me that i have to hold down the left mouse button whilst
dragging the
mouse. But, what should i say? Am I too stupid? When i do the mentioned things,
nothing happens.
The encircled points remain red (no selection occured). The other way round
(everything is
selected) to deselect points work...
Robert
> Robert,
start the
the
points
 This
around
you release
selected.
want and
> David
Date: 29 Apr 2001 11:22:54
Message: <shboetsbm5f2rs08ggno3bpt29r442q5cf@4ax.com>
dragging the
nothing happens.
(everything is
Hi Robert,
I have tried to reproduce what is happening to you, but cannot.  My system selects the
points
just as I have described.  It also works the other way round (as yours does) and
deselects
points already selected.  It may be something you are doing wrong, but I can't see
what it is.
It may just be that there has been a glitch with your system and it will be OK after
you have
rebooted.  If this fails to sort things out, you could try re-loading Hamapatch
BTW, in my configuration Hamapatch is not entirely stable.  Sometimes it just exits
when I am
selecting a point, so I make sure I save everything frequently.
I will be interested to hear if you manage to sort out your selection problems.
David
Date: 29 Apr 2001 16:22:41
Message: <MPG.1556887f8213be3c9898f7@news.povray.org>
I've just remembered something.  You are pressing [enter] to clear your
previous selection before trying to make another selection, aren't you?
Bye for now,
     Jamie.
Date: 30 Apr 2001 08:34:21
Message: <3AED5C0B.DF70939C@exmail.de>
> Bye for now,
>      Jamie.
Yes, i did. But you dont have to, if you want to select some more points to
the already selected.
BTW, now it works! I downloaded hamapatch again (not so simple, due to
crosswind.net) and now everything is allright ;-) Strange...
best wishes,
Robert
