POV-Ray : Newsgroups : povray.binaries.scene-files : An rendering artifact on torus Server Time
17 Dec 2025 22:37:25 EST (-0500)
  An rendering artifact on torus (Message 1 to 8 of 8)
Subject: An rendering artifact on torus
Date: 3 Apr 2015 09:30:00
Message: <web.551e94cd7c9493f713709ea20@news.povray.org>
When I rendered this file, I got this:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.551e92b74514bfb213709ea20%40news.povray.org%3E/
And here is a discussion several days ago, which may be a similar phenomenon.
http://news.povray.org/povray.bugreports/thread/%3Cweb.5517c69b250fa02e5189b500%40news.povray.org%3E/
Download 'bugreport.pov.txt' (2 KB)
Subject: Re: An rendering artifact on torus
Date: 3 Apr 2015 22:34:00
Message: <551f4d98@news.povray.org>
It looks like it could be a precision/accuracy isue as multiplying the
dimentions by 50 makes the artefact disapear. You may hit the limits of
double precision FP numbers.
Scaling up, even by 1000, DON'T improve the end result. In fact, when
scalling up, I get a full black circle, not just parts of it.
Date: 4 Apr 2015 03:43:43
Message: <551f962f$1@news.povray.org>
>> phenomenon.
> Alain
I just scaled it by 10 and it went away:
    torus{
    -0.1247, 0.2357
    rotate <-90,0,0>
    scale 1/10
Date: 5 Apr 2015 00:30:01
Message: <web.5520b948682c5a60123791000@news.povray.org>
Thank you.
I explain my intend of doing it. I made a macro that is used for chamfering a
cylinder and it is necessary to take the torus's inner surface in some
conditions. So I intersect sphere and torus with negative major_radius and
sometimes found these black lines.
Maybe the same demand can be done by using polynomial's torus and I would like
to try some day. Because I thought the black line may be produced by the
bounding cylinder of the torus object that the document describes.
Date: 7 Apr 2015 02:15:28
Message: <55237600$1@news.povray.org>
Am 05.04.2015 um 06:25 schrieb And:
> Thank you.
Have you tried using a positive major_radius and the "inverse" keyword
instead?
Date: 7 Apr 2015 03:40:00
Message: <web.55238934682c5a60123791000@news.povray.org>
> > Thank you.
> instead?
Oh, I will try later. I just found that the torus object's overlay area is not
inside the object.
And when I use polynomial object directly it shows strong precision problem
because my torus is too small.
Date: 7 Apr 2015 11:35:00
Message: <web.5523f85c682c5a60123791000@news.povray.org>
> > Alain
>     torus{
>     -0.1247, 0.2357
>     rotate <-90,0,0>
>     scale 1/10
Sometimes it disappear, doesn't have to be a scaling problem.
Date: 7 Apr 2015 12:35:00
Message: <web.552406fd682c5a60123791000@news.povray.org>
> inside the object.
I said it shows strong precision/accuracy problem. It happened when I tested it
with inside() function. But when I test it with inverse and intersection this
time, it overturn.
This is an (inversed) polynomial torus intersect a sphere and the torus object
version.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.552405c288bb499a123791000@news.povray.org%3E
