"Samuel Benge" <stb### [at] hotmail com> wrote:
> It's one rlp object copied, translated and rotated.
Oops, it was *not* rotated. I shouldn't type on autopilot :)
> Attached is a demo image I never posted (I think).
This looks fabulous. Thanks for posting the code again (and the link to your
earlier demo image.)
Thanks Sam! Excellent stuff.
Note:
In rlp_Shapes.pov, the object square is not allowed. It should be
Square, as it otherwise refers to the square pattern.
Always better to use upper case letters to start ;-)
Thanks guys!
Thomas de Groot <tho### [at] degroot org> wrote:
> Note:
Version 0.2 was released before I started using uppercase letters for
everything. Somebody once mentioned how even seasoned povvers sometimes use
lowercase letters for their variables, and how said case might eventually
interfere with POV's reserved keywords, so I've tried to use uppercase ones ever
since. I might have to release another version simply for that :)
OMG, I almost never use capital letters for variables :-O
But then again, my variable names are almost never as simple as
#declare aaa = 45;
They're partial sentences(!)--like...
#declare rotation_for_my_cylinder_object_around_ground_heightfield = 45;
Lots of typing of course--thank God for cut-and-paste! ;-)
But for me, this removes a 'level of abstraction' in my scene code, so I easily
know where to go when there's a problem, or I want to change something without
having to think too hard about it.
The trouble comes if I want to post my code--then I have to go back and
*simplify* the names. Using capital letters for that is probably a very good
idea!
I regularly have to remind myself too...
You have sinned against the First Rule of POV-Ray ;-)
> #declare aaa = 45;
I know what you mean. While not as extreme as your example, I often use
long words too.
> idea!
Absolutely.
> #declare aaa = 45;
> [snip]
> idea!
Nothing wrong with long variable names. It's not like we're using FORTRAN IV
with 4096 bytes of RAM. I think it will matter only if you're posting a
library, where the users will be frequently typing your variable names into
their scene files.
Thanks, Sam!
Note to Linux and Unix users: the file rlp_Bevels&Types.pov has to be quoted in
order to render. E.g.:
povray 'rlp_Bevels&Types.pov' +a
It just occurred to me: could Sam's upload have failed because the Object
Collection server software choked on the ampersand?
No but we're still using an editor without auto-complete capability.
