See p.b.i. for an example image of the following code.
Download 'cedeaq_semi-random landscape.pov.txt' (8 KB)
Subject: Re: Cedeaq's semi-random landscape revisited
Date: 21 Jun 2018 21:31:01
Message: <5b2c5155@news.povray.org>
Hi(gh)!
I added map functionality... see image on p.b.i!
See you in Khyberspace!
Yadgar
Download 'landscape.pov.txt' (21 KB)
Date: 22 Jun 2018 03:36:12
Message: <5b2ca6ec$1@news.povray.org>
On 22-6-2018 3:30, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
> Yadgar
Beware that your font path is not for universal use! Users have to edit
your code in order to use it properly. For demonstration purposes it is
better to stick to the standard ttf's provided by POV-Ray.
Date: 22 Jun 2018 08:08:07
Message: <5b2ce6a7$1@news.povray.org>
Hi(gh)!
Yes, I know and initially planned to add a comment... but it was late
and I wanted to get the thing online before laying down for sleep! I
also will refine the code in the coming days, especially implementing
arrays and loops for the depth/elevation levels and their arrangement in
color_maps, and making the map legend parametrizeable for different map
layouts...
And later on, I will do much modification on surface textures and
vegetation, thus "Afghanizing" the whole scenery... but at the moment,
it's still a pipe dream.
See you in Khyberspace (yes, it may turn out the become some sort of
fictional Khyberspace!)
Yadgar
Date: 22 Jun 2018 22:34:55
Message: <5b2db1cf@news.povray.org>
Hi(gh)!
Here is the cleaned-up code!
Yadgar
Download 'landscape.pov.txt' (12 KB)
Date: 23 Jun 2018 03:07:55
Message: <5b2df1cb@news.povray.org>
On 23-6-2018 4:34, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
>> edit your code in order to use it properly. For demonstration purposes
>> it is better to stick to the standard ttf's provided by POV-Ray.
> Yadgar
Neat!
One other thing: In F_SelfShine, change 'ambient' into 'emission'. Will
give you one lengthy warning less ;-)
Le 18-06-22 à 22:34, Jörg "Yadgar" Bleimann a écrit :
> Hi(gh)!
> Yadgar
On a normally installed version of POV-Ray, the path to your fonts
should already be in your input paths.
That mean that you should not need to have that
«#local textpath = "/home/Raytracing/Povscn/Fonts/";"»
In fact, under Windows, in the message pane, you can find this :
Library paths:
...[some other paths]...
C:\Windows\Fonts
Without having that path in any of the ini files.
On a Linux system, or a Mac, you should have something similar.
Am 23.06.2018 um 18:00 schrieb Alain:
>>> purposes it is better to stick to the standard ttf's provided by
>>> POV-Ray.
> Library paths:
> ....[some other paths]...
> C:\Windows\Fonts
While on Windows fonts are handled by the operating system itself,
that's not the case on Unixoid systems like Linux or Mac OS X; AFAIK, on
these systems, font management is instead the job of whatever graphical
interface is installed - be it KDE, Gnome, or whatever. The
corresponding path(s) /may/ have been added by the POV-Ray package
manager of whatever distribution you're using, but to my knowledge
there's nothing similar in vanilla "out of the box" POV-Ray for Linux.
Besides, even if POV-Ray for a given platform knows /where/ to find
fonts installed on the system, there's no guarantee that a /particular/
font will be found there. For example, you shouldn't expect "arial.ttf"
to be installed on Unix machines.
