POV-Ray : Newsgroups : povray.binaries.scene-files : POV-Ray 3.7 sometimes omits media photons Server Time
17 Apr 2026 13:35:01 EDT (-0400)
  POV-Ray 3.7 sometimes omits media photons (Message 1 to 6 of 6)
Subject: POV-Ray 3.7 sometimes omits media photons
Date: 7 Jul 2017 08:14:14
Message: <595f7b16$1@news.povray.org>
See thread in p.b.i.  The scene uses two light sources, one to trace a
cylindrical parallel beam through two prisms and across a room, and
another, with media interaction turned off, to light the scene.  The
latter light has a looks_like for what reason I don't remember.  (This
was 12 years ago!)
When the scene is rendered as an animation, the looks_like is omitted in
frame 2.
File beam0-pared-by37.log is the statistics from a v3.7.0 run with
+KFF2.  File beam0-pared-by36.log is the statistics from a v3.6.1 run
with +KFF2 +EF1.
POV-Ray versions:
   3.6.1 (g++ 3.4.1 @ i686-pc-linux-gnu)
   This is an official version prepared by the POV-Ray Team.
   3.7.0.unofficial [no source code alterations]
   Compilation settings:
     Build architecture:  x86_64-unknown-linux-gnu
     Built/Optimized for: x86_64-unknown-linux-gnu (using -march=native)
     Compiler vendor:     gnu
     Compiler version:    g++ 4.8
     Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -pthread
OS: openSUSE 13.2 (GNU/Linux)
Download 'beam0-pared.zip' (5 KB)
Subject: Re: POV-Ray 3.7 sometimes omits media photons
Date: 7 Jul 2017 14:15:05
Message: <web.595fce9fbec6f4a49c5d6c810@news.povray.org>
> was 12 years ago!)
> frame 2.
Don't know the reason behind it but simply making the looks_like sphere hollow
allows the photons to show.
Date: 8 Jul 2017 03:07:34
Message: <596084b6$1@news.povray.org>
Am 07.07.2017 um 20:10 schrieb omniverse:
>> was 12 years ago!)
>> frame 2.
Well, /I/ know the reason behind it now ;)
During refactoring for 3.7.0, a bug was introduced that may cause
objects in the same CSG group to mess with each others' `hollow` flag,
with the last object winning. In this case that happened to be the
non-hollow `looks_like` object.
Date: 8 Jul 2017 04:00:00
Message: <web.5960905bbec6f4a49c5d6c810@news.povray.org>
> >> was 12 years ago!)
> >> frame 2.
Much appreciation to you for finding that.
I hadn't thought of the looks_like being part of CSG if a lone object is used.
Wow, code reading is fun and confusing. Just before you answered to that I was
finally getting a look at both the 3.7 and 3.62 source for comparisons of what
might have changed, in particular the parse.cpp file, and I sure get lost fast.
I just wanted to see what parts looks_like dealt with, although I guessed it was
probably the object or hollow causing the trouble when conveyed to the parser
somewhere. I was thinking about the "children" parts and if that might be the
reason.
Please ignore me for my lack of certainty, clarity and definition there. I'm way
out of my league!
Anyway, thanks again for checking on that... both of you Christoph and Richard.
Date: 8 Jul 2017 04:15:59
Message: <596094bf$1@news.povray.org>
Am 08.07.2017 um 09:07 schrieb clipka:
>>> was 12 years ago!)
>>> frame 2.
... actually, no: The bug wasn't introduced in v3.7; it was a
pre-existing condition.
The reason your scene renders fine in v3.6 is that the symptoms were
ever so slightly different: Instead of the last object, it was the first
object that won the `hollow` flag war.
Place the box after the light source, and it will render fine in v3.7
but break in v3.6.
Can someone please open a GitHub issue for this one? It may need some
work before it can be fixed.
Date: 9 Jul 2017 02:25:00
Message: <web.5961cb6dbec6f4a49c5d6c810@news.povray.org>
> but break in v3.6.
I'm surprised I hadn't noticed this problem before with it around all that time,
or maybe I just change the scenes until they work right... or give up on them.
Done, whether correct enough is another matter but I tried my best.  :)
