On 22/09/2014 18:07, LanuHum wrote:
> Thomas,thanks.
> I started understanding your mechanism.
> But, I had an idea to use means of Blender (force field : wind) to do without
> excess mathematical calculations.
> Wind is applied to particles, but there is no realistic bend
> It is necessary to find only the solution of a realistic bend of a trunk of a
> plant also means of Blender
Just a suggestion LanuHum,
Can Blender apply wind to cloth?
Can you create a stalk as a "cloth" with only 2 degrees of freedom and
very stiff?
If so then you can apply "wind" to the "clothified"* stalk.
*Using Poser terminology.
Regards
Yes.
> very stiff?
I don't think that such option will be real for a large number of triangles. The
scene will be very heavy.
I am inclined to use only data, to process and write down the file
Subject: Re: Wind pattern code and reed stalk example
Date: 22 Sep 2014 15:40:49
Message: <54207b41@news.povray.org>
> Yes.
>> very stiff?
Fair enough. It was just a thought.
Keep up the good work. :-)
Regards
Date: 23 Sep 2014 03:17:08
Message: <54211e74@news.povray.org>
On 22-9-2014 19:07, LanuHum wrote:
> Thomas,thanks.
Ah yes, that is an idea. Like Stephen suggested, something Poser also
does. Only thing indeed is the bending.
It seems to me, looking at your image, that the rate of bending should
be inverted. What I mean is this: Now, the angle goes from high at the
start to gradually low towards the top, producing a concave-up bending
shape. Could you /invert/ the calculation for this? Thus making a
convex-up bending shape?
Alternatively, can you make the wind power in Blender to increase upwards?
> Thomas
If to use sphere_sweep probably it is possible to reach desirable result of a
bend.
It is necessary to study influence of several wind modifiers for increase in
wind power from above.
If the result is effective then it is necessary to think of leaves. :)
Download 'force_field_wind_render.jpg' (95 KB)
Preview of image 'force_field_wind_render.jpg'
Now there are a lot of modifiers
Download 'wind.blend.jpg' (375 KB)
Preview of image 'wind.blend.jpg'
Date: 24 Sep 2014 03:59:42
Message: <542279ee$1@news.povray.org>
This is looking very good! Exactly how I think it should be.
> Thomas
I develop leaves :)
Download 'wind_with_leaves.jpg' (104 KB)
Preview of image 'wind_with_leaves.jpg'
>> Thomas
> I develop leaves :)
You do it well. Bravo!
Regards
> > I develop leaves :)
> Regards
> Stephen
It only scheme (plan).
In high resolution it won't look good.
Besides, I used manual editing. For animation automatic process is necessary.
