POV-Ray : Newsgroups : povray.binaries.scene-files : Sky simulation Server Time
15 May 2026 19:16:50 EDT (-0400)
  Sky simulation (Message 21 to 30 of 38)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: Sky simulation
Date: 7 Mar 2018 15:59:03
Message: <5aa05297$1@news.povray.org>
> BTW has anyone heard or seen a ruler where feet are divided into tenths?
> Giving the impression that there are 10 "X inches" to a foot.
> I saw one once about 30 years ago.
Not feet into tenth, but with inches divided into 1/5, 1/10, 1/3, 1/6,
1/9 and 1/12.
I've seen one with foot divided into 1/3 and 1/4.
Date: 7 Mar 2018 16:44:16
Message: <5aa05d30$1@news.povray.org>
> 1/9 and 1/12.
I think it might be industry specific rule.
About 30 years ago. My boss, offshore, took some measurements in the
toolpusher's office using a rule he found there. After getting whatever
it was made. It did not fit. He got a bit of a slagging for it. As you
would. ;-)
He went back up to check only to find that there was 10 "inches" to the
foot.
Drillers use some strange terms. The anchor chain tension is measured in
Kilo-pound-inches. I had never heard of that measurement before I had to
calibrate the load sensors.
Regards
Date: 7 Mar 2018 18:29:09
Message: <5aa075c5$1@news.povray.org>
On 3/7/2018 7:21 AM, Stephen wrote:
> Now, I would be surprised if people in the UK did not know that. I guess
> I was about 15 or 16 when I was taught it at school.
> But as a rule of thumb that an inch is about the length of your thumb's
> distal phalanx. Is good enough for children as they more resemble the
> size of an adult of bygone years.
I have a triangular drafting ruler that is like that.
Mike
Date: 8 Mar 2018 02:54:47
Message: <5aa0ec47$1@news.povray.org>
>> 1/9 and 1/12.
> would. ;-)
> foot.
Interesting story. "kilo-pound-inches", could that mean 'thousand pounds
per inch'? the word kilo being used for the thousand's value?
Date: 8 Mar 2018 03:25:10
Message: <5aa0f366$1@news.povray.org>
>> in Kilo-pound-inches. I had never heard of that measurement before I
>> had to calibrate the load sensors.
Yes kilo is a multiplier and since it is a unit of work it should have
been KIP, kilo inch pounds which is 112.98 Nm.
I got kpi stuck in my head. :-)
For something so important the transmitter was a simple op amp. Check
the zero and span against the supplied load cell manufacturers data
sheet. Easy peasy. :-)
Regards
Date: 8 Mar 2018 04:04:27
Message: <5aa0fc9b@news.povray.org>
>> pounds per inch'? the word kilo being used for the thousand's value?
Easy peasy indeed. I imagine the guys calibrating those data sheets:
"Hey John! Lets give it a pound more!"  BANG!  ;-)
I am always surprised that we got to the Moon at all, or Mars for that
matter, where we were able to crash at least once because of
imperial/metrics confusion... ;-)
Date: 8 Mar 2018 04:34:24
Message: <5aa103a0$1@news.povray.org>
>>>> measured in Kilo-pound-inches. I had never heard of that measurement
>>>> before I had to calibrate the load sensors.
More likely Pop. The materials used are designed to take the weight and
are over rated.
Big mistake mixing units. I may think in imperial but work in metric
when I can.
Regards
Date: 8 Mar 2018 07:23:21
Message: <5aa12b39$1@news.povray.org>
>>>>> measurement before I had to calibrate the load sensors.
>>> have been KIP, kilo inch pounds which is 112.98 Nm.
> are over rated.
Sad. I would like a bit of drama ;-)
> when I can.
smart. But then you grew up with imperial of course. I find it difficult
(not that I need it).
Date: 8 Mar 2018 08:26:33
Message: <5aa13a09@news.povray.org>
>> and are over rated.
Your slightest wish is my command.
https://youtu.be/CjzykTQM-4w?t=78
A similar incident happened on the platform I was on. Unfortunately the
crane driver was not so lucky. He got trapped in the cabin for hours and
lost a foot and part of his lower leg.
>>> that matter, where we were able to crash at least once because of
>> when I can.
It is difficult and took years of repetition before it became second
nature. But after learning things like there are 5280 ft in a mile and
60 mph is 88 ft/s. Not to mention the currency. The metric system is a
walk in the park.
Also we oldies can add up in our head. Unlike the youth of today.
Regards
Date: 8 Mar 2018 08:38:18
Message: <5aa13cca$1@news.povray.org>
I just noticed a follow up video.
The cage the guys are in is galled a Billy Pugh and you are supposed to
stand on the outside so you don't get trapped if it goes into the sea. I
used them for my one trip on the Piper. A white knuckle job.
https://www.youtube.com/watch?v=ZD8y7Slx2ow
Regards
