POV-Ray : Newsgroups : povray.binaries.scene-files : New version screen.inc Server Time
13 Mar 2026 07:14:09 EDT (-0400)
  New version screen.inc (Message 13 to 22 of 52)
Subject: Re: New version screen.inc
Date: 18 Nov 2009 21:27:57
Message: <4b04ad2d$1@news.povray.org>
On 11/18/2009 10:51 AM, Captain Jack wrote:
> I put a copy of the rendering up at YouTube, here:
> http://www.youtube.com/watch?v=LzgV8dALdIo.
Cool. I've been using it to render illustrations in POV-Ray, and then
create markers and text on top of it in GeoGebra.
Mike
Date: 19 Nov 2009 09:29:21
Message: <4b055641$1@news.povray.org>
"SharkD" <mik### [at] gmailcom> wrote in message
news:4b04ad2d$1@news.povray.org...
> Mike
And, just for the sake of completeness if anyone else is reading this, I
fixed the spring macro, using a macro from transforms.inc:
#macro Spring(Base_Point, Top_Point, Spring_Radius, Turns, Wire_Radius,
Length_Scale)
    #local Length = vlength(Top_Point - Base_Point);
    #local Points = 4*Turns + 3;
    #local Arm_Delta = (Length/Length_Scale) / (4*Turns);
    #local Arm_Offset = -Arm_Delta;
    #local Arm_Rotation = 0;
    sphere_sweep {
        b_spline
        Points
        #local Counter = 0;
        #while (Counter < Points)
            , vrotate(Spring_Radius*x, Arm_Rotation*y) + Arm_Offset*y,
Wire_Radius
            #local Arm_Offset = Arm_Offset + Arm_Delta;
            #local Arm_Rotation = mod(Arm_Rotation + 90, 360);
            #local Counter = Counter + 1;
        scale Length_Scale*y + (x + z)
        Point_At_Trans(Top_Point - Base_Point)
        translate Base_Point
        bounded_by {
            cylinder {
                -Wire_Radius*y,
                (Length+Wire_Radius)*y,
                Spring_Radius+Wire_Radius
Date: 17 Aug 2010 11:15:01
Message: <web.4c6aa70eb4b005963d51a7b10@news.povray.org>
I am getting error messages like this:
File: /home/ellef/lang/pov-ray/inc//myScreen.inc  Line: 111
File Context (5 lines):
  #local val_3 = vinv_transform(Loc, Camera_Transform_All);
Parse Error: Expected 'object or directive', < found instead
What am I doing wrong?
I am trying to add labels and help lines to geometrical figures (See
povray.newusers thread "Labels on geometrical figures").  It would be nice to do
that too entirely inside Pov-ray.
Date: 17 Aug 2010 19:18:07
Message: <4c6b18af@news.povray.org>
> Parse Error: Expected 'object or directive',<  found instead
Please post the entire scene.
http://isometricland.com
Date: 18 Aug 2010 10:10:00
Message: <web.4c6be990b4b005963d51a7b10@news.povray.org>
After some struggle, I have made a minimal example which works.  Thanks to
Captain Jack for TargetTest.pov (and of course to SharkD, this is a really cool
feature).
Maybe some might be interested in the "minimal" example, so I post it here.
So now, it is just to connect this to SVG, imageMagick and make, and we have a
general tool :)
Download 'screenminimal.pov.txt' (2 KB)
Date: 18 Aug 2010 10:15:01
Message: <web.4c6bea4fb4b005963d51a7b10@news.povray.org>
feature).
general tool :)
Date: 18 Aug 2010 19:55:26
Message: <4c6c72ee$1@news.povray.org>
> feature).
> general tool :)
It would be cool if there were a library of macros that created
SVG-equivalent shapes in POV. Might be a nice little project for someone
who has the time.
Date: 19 Jan 2016 00:55:01
Message: <web.569dcf40b4b005965dbf06e80@news.povray.org>
Here's an updated version. It uses a new macro, Set_Camera_Orthographic, to
toggle orthographic mode on/off. Otherwise, the script will not be compatible
with old scenes made prior to this script.
Mike
Download 'screen_new.inc.txt' (8 KB)
Date: 17 Mar 2016 04:50:00
Message: <web.56ea6fa7b4b00596629fde300@news.povray.org>
Thanks for your great work.
However, when I tried this version, I saw that the render was not the same when
simply switching from the regular screen.inc to screen_new.inc.
Is that expected?
Thanks.
Yannick
Date: 3 Nov 2017 18:40:01
Message: <web.59fcef3fb4b00596591d362a0@news.povray.org>
This is a really cool feature which I'd like to use for an animation. Somehow it
does not work for me: the camera "zooms in" much more than using the normal
orthographic camera. The object positioning of text does not work either, as
shown in the standard screen.inc example attached.
What am I doing wrong. Or did something change?
Download 'screentest.png' (105 KB)
Preview of image 'screentest.png'
