POV-Ray : Newsgroups : povray.binaries.scene-files : TheatreSys theatrical lighting system Server Time
15 Jul 2026 17:38:14 EDT (-0400)
  TheatreSys theatrical lighting system (Message 1 to 5 of 5)
Subject: TheatreSys theatrical lighting system
Date: 18 Mar 2009 11:56:41
Message: <49c119b9@news.povray.org>
Here's a set of macros that I've been working on for a while, and
finally feel like I can submit. It effectively allows you to place
standard theatrical instruments in your scene, and attach various
accessories (colors, template patterns, etc).
I tried to make everything in here as realistic as possible, in terms of
photometric data, and left a lot of room for modification and expansion.
It uses LightSysIV (and CIE.inc) from Jaime for color and fading
calculations.
Color filters (Gels in the technical lingo) were modeled by taking the
transmission spectra for each color in spline form and passing it
through CIE to create colors as accurately as possible. The lamps
themselves use the rated blackbody temperatures of the real lamps, so
anything made in this should look nearly identical to what it looks like
in person, within gamma and monitor calibration tolerances.
The zip file contains a folder that contains the main include file, a
sample proscenium theatre space to test lights in, a wooden stick figure
to test with, transmission spectrum data for 3 major manufacturers of
gels, a fairly detailed readme with usage instructions, and a few demo
scenes to try.
Let me know what you think!
cshake
Download 'theatresys_1.0.zip' (381 KB)
Subject: Re: TheatreSys theatrical lighting system
Date: 20 Mar 2009 06:30:00
Message: <web.49c36feaed50e71e7cb988ed0@news.povray.org>
> cshake
I did one short test...
.... and I believe that you have done a hard and complex work!
.... and I think you got a good result.
Carlo
Date: 21 Mar 2009 07:58:04
Message: <49c4d64c$1@news.povray.org>
> calculations.
> scenes to try.
> cshake
Looks promising and I'm glad someone could make some use of my old CIE
include file. Which reminds of the lack of a *real* documentation for it
and I guess the purpose and usage of CIE.inc is quite difficult to
understand. I'm sorry for this and I always wanted to write a tutorial &
documentation but never had the time for it. RL - you know.
-Ive
Date: 21 Mar 2009 14:15:00
Message: <web.49c52db2ed50e71ef50167bc0@news.povray.org>
Having *tried* to work out just the rudiments of something like this myself, I
can only say THANKS and CONGRATS on putting it all together. Not an easy task!!
I will definitely be checking it all out, for practical use (in pre-designing
the stage lighting for local theater plays that I'm involved with.)
One question of curiosity (a practical one, actually): What assumed_gamma is
*best* for using this package?  I.e., while designing this and working it out,
which assumed_gamma did you use? I want to make sure I follow your lead.
KW
Date: 21 Mar 2009 14:35:37
Message: <49c53379$1@news.povray.org>
Thanks! There are still some issues, but I tried to make it as usable as
possible for different applications (especially with the global unit
system).
> KW
I've been running everything with assumed_gamma=1 on my PC for 3.6, and
removed the statement in 3.7 due to it being deprecated, both of which
produce the same results. I still notice that everything gets brighter
when I switch to my mac (mostly dark lights become visible, etc), but
the color mixes themselves stay the correct color, only a small amount
brighter. With 3.7 I leave the gamma correction turned on, and that
works fine. The difference in brightness between mac/pc shows up if I
take the rendered images over from PC to mac, I haven't compared images
generated on both.
The more important part (for correct colors) is setting the global
whitepoint, which I hardcoded into the .inc file to be D50 (after
comparing the renders to photographs of the real lights). D55 also looks
decent, but setting it down as low as blackbody(5200) (the color of the
light sources themselves) makes it all look weird.
It is set right at the top of theatresys.inc, and you can just comment
that out if you wish to use a different environment.
cshake
