POV-Ray : Newsgroups : povray.binaries.scene-files : Stargate Glyphs Server Time
9 Jun 2026 05:39:17 EDT (-0400)
  Stargate Glyphs (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Stargate Glyphs
Date: 24 Jun 2008 05:01:11
Message: <4860b7d7@news.povray.org>
Doctor John wrote:
> Must be a Windoze problem 0_0
Looks fine on XP too (Netscape).
Date: 24 Jun 2008 05:10:18
Message: <4860b9fa@news.povray.org>
"Christian Froeschlin" <chr### [at] chrfrde> wrote in message
news:4860b7d7@news.povray.org...
Hmm. Strange. It shows up with the right name, but an extension of zm9 in
Outlook Express and it downloads with that extension too when I do a Save
Attachments, but it's 'zip' on the web site.
I don't know if it's just my newsreader then.
Chris B.
Date: 24 Jun 2008 17:55:01
Message: <web.48616c784d571f95970752e90@news.povray.org>
My condolences to all new windoze users. Everything I hear says to me, stay away
and keep current sweet sytem.
I brains cells serve, it was this one, Lightwave:
http://www.scifi-meshes.com/meshes/index.php?dlid=249
Lightwave loaded in Blender->Poseray->POV export
Seems divided into 4 meshes. Wouldn't be able to animate central ring.
Download 'stargatemesh.zip' (568 KB)
Date: 25 Jun 2008 23:20:02
Message: <web.48630a294d571f95184271a10@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote:
> A POV-Ray prism object for each of the 39 Glyphs on the Milky Way Stargate.
> Regards,
> Chris B.
And here (finally) is mine.  It contains the scene-file for the Stargate and one
for the transporter rings as well.  The rings are all CSG, the Stargate uses CSG
and height-fields.  The gate is not finished, as the chevrons are not complete
nor animated, but the ring is animated (glpyhs rotate around) and the event
horizon is animated (only an already open gate, not the "kawoosh" effect).
Feel free to add whatever you want, and add them both to the object repository
under whatever the appropriate license is (unless I need to do that, in which
case point me in the right direction).  If you add anything to it or do any
animations, I'd love to see them.
Mike
Download 'stargate.zip' (493 KB)
Date: 26 Jun 2008 19:45:00
Message: <web.4864290f4d571f95159cbc820@news.povray.org>
> Regards,
> Chris B.
Chris, it shows up as .zip on the web, but when I download it I get a ".zip file
is corrupt" error.  Can you post it unzipped?  I'd like to compare your prism
version versus the heightfield version I did.
Thanks,
Mike
Date: 27 Jun 2008 04:10:09
Message: <4864a061@news.povray.org>
"Mike Sobers" <mcn### [at] msncom> wrote in message
news:web.4864290f4d571f95159cbc820@news.povray.org...
> prism
> Thanks,
> Mike
Here are the POV-Ray prism and SVG files unzipped. I still don't know quite
what went wrong with the zip.
Your height fields benefit from a smooth edge whereas the prisms leave a
very sharp.
I notice that converting your images from png to jpeg brings your images
down to about a quarter their size. Although jpeg is lossy it doesn't seem
to be detrimental to the result.
I also noticed that the two sets of glyphs differ slightly in their outlines
I don't know which is most authentic or even whether there's any consistency
in the TV shows and films.
Chris B.
Download 'Stargate.pov.txt' (6 KB) Download 'StargateGlyphs2.pov.txt' (163 KB) Download 'StargateGlyphs2.svg.txt' (36 KB)
Date: 27 Jun 2008 12:48:27
Message: <486519db@news.povray.org>
Chris B nous illumina en ce 2008-06-27 04:09 -->
> Regards,
> Chris B.
Whenever you compress a file, there is a chance that the process goes wrong,
resulting in an unusable archive. Very good to always check the integrity of the
archive immediately after you make it.
It can also get corrupted in the process of uploading it...
Jehovah's Witnesses: May we have a moment of your time to show you some of our shit?
Date: 27 Jun 2008 13:12:17
Message: <48651f71@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:486519db@news.povray.org...
>> quite what went wrong with the zip.
>> Regards,
>> Chris B.
> wrong, resulting in an unusable archive. Very good to always check the
> integrity of the archive immediately after you make it.
> Alain
Yes I know. As I mentioned earlier in the thread I downloaded it again and
decompressed it successfully after renaming it from 'zm9' to 'zip'. John and
Christian said that it appeared as 'zip' for them, so they didn't even need
to rename it. However, Mike reported that the copy he downloaded was
corrupt.
Chris B.
Date: 29 Jun 2008 01:35:01
Message: <web.48671ea74d571f95862a19220@news.povray.org>
The copy was fine.
After writing an svg reader worthy of reading StargateGlyphs2.svg, I made a new
centered set. Rendered within one pixel of previous splines, now centered on
<0,0,0>
dont need no Inkscape
Download 'stargateglyphs.zip' (37 KB)
Date: 1 Jul 2008 19:40:01
Message: <web.486abf8a4d571f95eedae2cc0@news.povray.org>
> Regards,
> Chris B.
I'm not sure which glyphs are more accurate.  Mine were made from a font I found
online.  I used POVRay to animate through them using an ortho camera to make the
images for the heightfields.  The prisms definately render faster.  Maybe I'll
make a mesh of the decorations around the edges instead of copying the
heightfield 360 times ...
Mike
Thanks for the introduction to Inkscape for the bezier curve tools- that will
come in handy.  I've been wondering the best way to convert some images to
vector graphics for some T-shirt artwork, but I think I have the solution.
