POV-Ray : Newsgroups : povray.binaries.programming : Difference Server Time: 2 Dec 2008 05:57:50 GMT
  Difference (Message 1 to 8 of 8)
Subject: Difference
Date: 7 Dec 2005 17:03:19
Message: <439715d7$1@news.povray.org>
Hello all,
This is my first post and maybe I ask a silly (beginner) question: When
you use difference you get the color of the object you substract. When
you substract something easy, let's say, a box A minus a box B, then it
is easy to get the right color in your cut surface. You just use the
same color for B. But, when A is something composed of many different
objects with many different colors... Is there any way or "trick" to get
this colors in the cut edge instead of the same color of B?
Thanks
Subject: Re: Difference
Date: 7 Dec 2005 17:20:00
Message: <web.439718b03616f208af771770@news.povray.org>
First of all this is the wrong newsgroup. such questions should be posted in
newusers http://news.povray.org/povray.newusers/
To answer your question. When i understand you right you want the resulting
object to have one overall texture. in this case it is the easiest way not
to use pigments (or textures) in the single object declarations but apply
it once to the resulting cutobject. for example
difference {
  object { this }
  difference {
    object { that }
    merge {
      object { whatever }
  texture { myTexture }
Hope that helped
Regards Roman
Alvaro Blanco <ablanco [at] icmmcsices> wrote:
> Hello all,
> Thanks
Date: 7 Dec 2005 17:39:21
Message: <43971e49$1@news.povray.org>
Hello Roman, Thanks for your quick response.
Maybe I was also too quick when I wrote the question.
The problem is the folowing:
Imagine that I have 2 boxes: 1 is red and the other is blue and they are
one ontop of the other. If I cut this with a Black box I obtain a black
edge. But i want the edge red and blue. It is not a problem of total
pigments or final pigments (or textures), the problem is that i want to
see the "real" cut of the first object. Maybe this is just fundamental
problem in Pov-ray because all objects are empty and you only see
surfaces. I was just wondering if anybody have had this problem and have
  solved it. Imagine that you have a Ham and Cheese Sandwich and u cut
it with a red knife. I don't want to see a red cut but the edge of the
bread, the ham and the cheese.
Alvaro
> difference {
>   object { this }
>   difference {
>     object { that }
>     merge {
>       object { whatever }
> Hope that helped
> Regards Roman
>>Hello all,
>>Thanks
Date: 7 Dec 2005 18:10:01
Message: <web.439724ee3616f208af771770@news.povray.org>
This is much more complicated and i do not have a quick solution for that
and consulting my conception of how csg is being calculated i doubt there
is one. when you (for example) intersect to objects povray traces both
objects and when both are hit it uses the intersection point that is farer
away.
the ray just intersects with surfaces. there's no the interior (except you
use media but i doubt this would be a good solution it that case ;-)).
therefore the ray gets the color of the object whose surface has been hit.
in your example the red knife.
surely one can can trick around that when the object isn't too complicated.
maybe an other user already had experiences with that. i hadn't
Regards Roman
> Alvaro
> > difference {
> >   object { this }
> >   difference {
> >     object { that }
> >     merge {
> >       object { whatever }
> > Hope that helped
> > Regards Roman
> >>Hello all,
> >>Thanks
Date: 7 Dec 2005 18:20:00
Message: <web.439726d33616f20e8d525f60@news.povray.org>
3.5.10
cutaway_textures
Your sandwich should now be properly cut :)
JYR
Date: 8 Dec 2005 00:50:00
Message: <web.4397823b3616f208af771770@news.povray.org>
"JYR" <jyrehby [at] hotmailcom> wrote:
> 3.5.10
> cutaway_textures
> JYR
hehe. didn't know that. still learning ;-)
Date: 9 Dec 2005 10:56:21
Message: <439962d5$1@news.povray.org>
Thanks!! I will eat it today!
3.5.10 hidden in the middle of the tutorial. It should be placed in
difference section or, at least, there should be a hyperlink to 3.5.10
from there.
:-) Alvaro
JYR wrote:
> 3.5.10
> cutaway_textures
> JYR
Date: 31 Jan 2006 19:16:24
Message: <43dfb788$1@news.povray.org>
you got
union {
    box texture {red}
    box texture {blue}
and you want to subtract
box texture {black}
without black coor
then do this
intersection {
            union {
                    box red
                    box blue
            box {<...>,<...> texture {black} inverse}
insteed of getting the difference ,   une the intersection of your object
with all_the_outside of you second object by using the inverse keyword into
your black box
"Alvaro Blanco" <ablanco [at] icmmcsices> a écrit dans le message de
news:43971e49$1@news.povray.org...
> Alvaro
posted in
resulting
not
apply
> > difference {
> >   object { this }
> >   difference {
> >     object { that }
> >     merge {
> >       object { whatever }
> > Hope that helped
> > Regards Roman
> >>Hello all,
> >>Thanks
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
