POV-Ray : Newsgroups : povray.binaries.programming : POV Memory Server Time
6 Jul 2026 23:15:59 EDT (-0400)
  POV Memory (Message 2 to 11 of 21)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: POV Memory
Date: 22 Feb 2002 03:04:40
Message: <3c75fb98@news.povray.org>
You didn't mention the programming language you are using ('memalloc' is
not a C nor C++ function; at least not a standard one).
Subject: RE: POV Memory
Date: 22 Feb 2002 13:09:57
Message: <3c768975@news.povray.org>
Sorry, malloc is the function, I'm writting my program in C, but what I want
to know is the Algorithm or procedure to distribute the memory, for example:
sphere needs 3 coordinates for the center and a radius, each variable takes
4 bytes of memory, well, I need 16 bytes for a sphere, but for a box I need
24 bytes...
sphere    16 bytes
box          24 bytes
cone        28 bytes
cylinder   28 bytes
plane       16 bytes
torus          8 bytes
this are without transformations, they need more memory, that's the problem,
my memori not is infinite
Date: 22 Feb 2002 19:58:55
Message: <3C76EA1E.2060303@comtrade.ee>
majucatur wrote:
> Hi.
>    I have a question for you, well, I'm developing a ray-tracing program and
> I need help with the aspect of the memory allocation. I define my objects in
> special structures, each object is allocated in memory dynamically, you
> know, with memalloc and free, but the question is: How can I optimize this?,
> I want to use the less memory possible, because with objects like mesh or
> series of thousand objects consumes a lot of RAM memory, I don't know how
> POV-Ray uses the memory to its objects, but certainly it can trace scenes
> with a lot of complex objects without problem...
>    Should I put everything in memory?, primitives, mesh, textures, etc. or
> exist a technique to use more efficiently my resources.
If you want to render more geometry than fits into memory, then only
option is to cache it (if you don't want to leave it to op. sys. swapping).
One paper I know about it could be found:
http://graphics.stanford.edu/papers/displace/
Google should help in finding similar papers.
Other option is to optimize geometry. Latest Siggraph papers ('00 IIRC)
have number of various optimizations described.
Date: 23 Feb 2002 13:25:19
Message: <3c77de8f@news.povray.org>
> 24 bytes...
  So in 10 Megs of memory you can store almost 437000 boxes. I don't see
the problem.
Date: 4 Mar 2002 10:57:54
Message: <3c839982$1@news.povray.org>
> box          24 bytes
so you use only 4 bytes for the float number storage?
IMHO a box needs 6 float parameters to be defined...
regards
SY
Date: 4 Mar 2002 11:52:27
Message: <3c83a64b@news.povray.org>
  In fact, 2 is enough. See the box syntax for an example. (Of course with
2 floats it's axis-aligned, but that doesn't matter; the transformations of
a box are not made by moving its vertices anyways.)
Date: 4 Mar 2002 21:10:54
Message: <slrna88a9i.la6.ron.parker@fwi.com>
floats or vectors?
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 5 Mar 2002 03:29:31
Message: <3c8481eb@news.povray.org>
of
how do you define a box with 2 floats? even length, height and depth would
already need 3!
regards
SY
Date: 5 Mar 2002 06:53:17
Message: <3c84b1ad@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
> floats or vectors?
  Floats. (Of course that will create a cube, but as I said, transformations
can make it a box of any shape, and place and orient it in any way.)
  Thinking about it, it actually doesn't need any floats at all. Just
create a unit-cube by default and let the transformations do the rest.
  So in fact it requires 0 floats.
Date: 5 Mar 2002 06:54:00
Message: <3c84b1d8@news.povray.org>
> already need 3!
  I assumed that we can apply a transformation matrix to any object, including
the box.
