![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 15-1-2024 om 14:48 schreef Thomas de Groot:
> Op 15-1-2024 om 01:44 schreef Samuel B.:
>> "Samuel B." <stb### [at] hotmail com> wrote:
>>> triplanar mapping
> Very good!
> This is what I get with a rapid test of your code. Also attached is the
> crater map I use.
Forgot to say: left is your first code, right is the second one.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> >> triplanar mapping
> Very good!
> crater map I use.
> Thomas
Hmm, I don't know what's causing those parallel lines, but it might be the lack
of a sharpness value. I updated the macro, and its new sharpness input /should/
help mitigate such errors plus any warping caused planar mapping. Also, that
crater map has some issues... not sure what the problem is. The attached is a
test render I made today, and the code below is what produced it.
Sam
triplanar-craters-test.pov
2024 stb
+fn +f +a0.3 +am2 +r2 +w768 +h768
#version 3.7;
#default{ finish{ambient 0} }
global_settings{
assumed_gamma 1.0
#if(true)
radiosity{
pretrace_end .04
count 32
error_bound .25
recursion_limit 1
nearest_count 10
normal on
camera{
right x up y
location -z*1000
look_at 0
scale .0027
// sunlight
#if(true)
light_source{
<1, .5, 0>*1e5, srgb <1.5, 1.4, 1.3>
#if(true)
#declare ALRes = 2;
#declare ALSize = .06*1e5;
area_light x*ALSize, z*ALSize, ALRes, ALRes
jitter
adaptive 1
area_illumination
// starry background
#if(true)
sky_sphere{
pigment{
granite
scale .05
poly_wave 32
pigment_map{
[0 rgb 0]
[.25 bozo scale .01]
// some triplanar mapping settings
#declare TriplanarScale = 1.5; // triplanar image scaling
#declare TriplanarTranslate = <0, .25, 0>; // triplanar image translation
#declare TriplanarAccuracy = 1.0; // accuracy of triplanar surface normals
(1=default; higher=smoother)
#declare TriplanarSharpness = 0.7; // 0 to 1
// input image for triplanar color and normal
#declare PImg =
pigment{
image_map{
png "craters.png"
interpolate 2
scale TriplanarScale
// try to find a proper normal accuracy value based on TriplanarScale and image
size
#declare ImageRes = max_extent(PImg);
#declare ImageRes = min(ImageRes.x, ImageRes.y);
// isosurface displacement
#declare FDisp =
function{
pattern{
bumps
scale .65
turbulence .3
translate 2.5*z
// triplanar macro (Pigment in z-direction; Sharpness value between 0 and 1)
#macro Triplanar(Pigment, Sharpness)
pigment_pattern{
slope x
triangle_wave
pigment_map{
[0+.5*Sharpness Pigment rotate y*90]
[1-.5*Sharpness
pigment_pattern{
slope y
triangle_wave
pigment_map{
[0+.5*Sharpness Pigment rotate x*90]
[1-.5*Sharpness Pigment rotate z*165]
translate TriplanarTranslate
// asteroid
isosurface{
function{
sqrt(x*x+y*y+z*z)
-.5*FDisp(x, y, z)
-.5
accuracy .001
max_gradient 1.54
texture{
pigment{
pigment_pattern{Triplanar(PImg, TriplanarSharpness)}
color_map{
[0 rgb <0, .05, .1>]
[1 rgb 1]
normal{
poly_wave .5
bump_size .75
accuracy TriplanarAccuracy / ImageRes
Download 'triplanar-craters-test0m_28s.jpg' (47 KB)
Preview of image 'triplanar-craters-test0m_28s.jpg'
![triplanar-craters-test0m_28s.jpg](/povray.binaries.images/attachment/%3Cweb.65a5da7193092b9916bed5696e741498%40news.povray.org%3E/triplanar-craters-test0m_28s.jpg?ttop=443824&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 16-1-2024 om 02:22 schreef Samuel B.:
>>>> triplanar mapping
>> Very good!
>> crater map I use.
>> Thomas
> Sam
Right. I was wondering about those lines too and I assumed they were
somehow generated by the places were the three planes /joined/. I am
wondering now if there might nor be a problem with the seamless (?)
joints of the crater map. going to investigate...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 16-1-2024 om 10:15 schreef Thomas de Groot:
No. looks like that is fine.
Download 'hf_seamless_test.jpg' (382 KB)
Preview of image 'hf_seamless_test.jpg'
![hf_seamless_test.jpg](/povray.binaries.images/attachment/%3C65a678d1%40news.povray.org%3E/hf_seamless_test.jpg?ttop=443824&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
So, they way I understood it was that each plane contributed to the texturing of
the surface by how closely its normal matched that of the surface. Surfaces
with a 45 deg angle would be an even blend of 2 planes, etc.
I think you have the idea properly implemented in code, but you should eliminate
the unnecessary triangular_wave statement? Shouldn't it be a straight sawtooth
wave?
It's early and I might be reading it wrong, but should the slope {x} pattern
blend between an xz plane and one rotated into the yz plane by rotation around
z? (first pigment map), etc? Seems you have that first image map rotated around
y, when it ought to be rotated around x to make it lay flat.
Then rotate around z, then y to cover all 3 planes.
"The slope value at a given point is dependent on the angle between the
<Direction> vector and the normal of the surface at that point."
- BW
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I got a really strange problem applying your code to:
superellipsoid {
<0.25,0.25>
pigment_pattern {Triplanar(PImg, TriplanarSharpness)}
color_map {
[0.20 rgb <1,1,0>]
[0.50 rgb <1,0,1>]
[0.80 rgb <0,1,1>]
normal {
poly_wave .5
bump_size .75*2
scale 0.75
rotate <0, 30, 0>
translate <0, 0.75, 0>
If you change the rotation of the object, especially > 30*y or < -30*y
in this example, the texture becomes distorted! Also with other types of
objects.
What is happening here?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I gave it a go, since I had to visualize the rotations, lest it bother me for
the rest of the day. I use a helper macro to choose the waveform, and cubic
seemed to work really nicely. I'd suggest trying it with different images to
see if the smoothness is a result of just using one test image.
Rotating the superellipsoid doesn't seem to have too much effect - the line
artefacts might be more to do with the linear travertine image?
- BW
#declare IM = pigment {image_map { "YourImage.png" interpolate 2}}
#macro WaveType (N)
#switch (N)
#case (0)
ramp_wave
#break
#case (1)
triangle_wave
#break
#case (2)
sine_wave
#break
#case (3)
scallop_wave
#break
#case (4)
cubic_wave
#break
#case (5)
poly_wave 0.5
#break
#macro TP (P, N)
average
pigment_map {
[ 1.0
pigment_pattern {
slope x
WaveType (N)
pigment_map {
// When 100% aligned with x
[0 IM rotate -y*90]
// vector can rotate away from x in either the y or z direction
[ 1.0
pigment_pattern {
// arbitrarily choose z axis for primary pattern
slope z
WaveType (N)
pigment_map {
// 100% aligned with z
[0 IM ]
// 100 aligned with y
[1 IM rotate x*90]
[ 1.0
pigment_pattern {
slope y
WaveType (N)
pigment_map {
// When 100% aligned with y
[0 IM rotate x*90]
[ 1.0
pigment_pattern {
slope x
WaveType (N)
pigment_map {
// 100% aligned with x
[0 IM rotate -y*90]
// 100 aligned with z
[1 IM]
[ 1.0
pigment_pattern {
slope z
WaveType (N)
pigment_map {
// When 100% aligned with z
[0 IM]
[ 1.0
pigment_pattern {
// arbitrarily choose x axis for primary pattern
slope z
WaveType (N)
pigment_map {
[0 IM rotate -y*90]
[1 IM rotate x*90]
#declare Round = 0.125;
#declare Rounded_Box = superellipsoid { <Round, Round> rotate -y*30}
object {Rounded_Box TP (IM, 3)}
Download 'tpmapping.png' (485 KB)
Preview of image 'tpmapping.png'
![tpmapping.png](/povray.binaries.images/attachment/%3Cweb.65a69a5f93092b991f9dae3025979125%40news.povray.org%3E/tpmapping.png?ttop=443824&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 16-1-2024 om 16:02 schreef Bald Eagle:
> - BW
Thanks Bill! I gave it a go and I noted the following:
1) your code seems to respond better to object rotation (before calling
the texture macro).
2) it appears that in Sam's code (but also in your code) rotating the
object */after/* the texture call generates increasing horizontal
lines/deformations (0*y rotation shows no linear deformation; 90*y
rotation shows maximum linear deformation). Rotations through other axes
show similar behaviour.
3) so it appears (to me) that the texture does not follow the object
rotation. Why this is is a mystery to me and it is the first time I
witness such behaviour indeed.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I think it might be more of an issue of how the image_map is oriented with
regard to the slope, (+90 vs -90 deg).
I also don't think I have a complete pattern definition, since I was unsatisfied
with how the slope controlled 100% pigment when perfectly aligned with an axis
vs rgbt 1 when perpendicular to it.
I would suggest looking at the method of creating a normal map by user "NPC"
used in this thread:
https://news.povray.org/povray.binaries.images/thread/%3Cweb.5d978f0b44e99bc84eec112d0%40news.povray.org%3E/
The key being:
sine_wave frequency 0.5 phase -0.25
which, indeed, when I add that frequency and phase correction in my WaveType
macro, seems to get rid of what you might be seeing.
(left: pigment applied before -90*y rotation, right: pigment applied after -90*y
rotation)
Try and experiment.
Still needs improving, in my opinion - sumthin' still ain't right.
- BW
Download 'tpmapping.png' (346 KB)
![tpmapping.png](/povray.binaries.images/attachment/%3Cweb.65a6b42b93092b991f9dae3025979125%40news.povray.org%3E/tpmapping.png?ttop=443824&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
To me, those parallel lines look similar to the typical behavior of an image_map
applied to a 1X1X1-unit box-- where the edge pixels 'wrap around the sides' (as
an analogy only.) I haven't examined the code examples here or run them yet--
I'm currently testing other things-- but I wonder if a small scaling factor
needs to be used *somewhere*, to try and eliminate that effect. Something like
scale <0.9999,0.9999,1>. Sorry if this proposal seems simplistic, but it's the
first thing that popped into my head.
As for the textures etc not following the rotation of the whole object, that's a
strange mystery...perhaps a hidden problem with the 'slope' pattern itself?
Download 'simple_image_map_on_box.jpg' (37 KB)
Preview of image 'simple_image_map_on_box.jpg'
![simple_image_map_on_box.jpg](/povray.binaries.images/attachment/%3Cweb.65a7171993092b999b4924336e066e29%40news.povray.org%3E/simple_image_map_on_box.jpg?ttop=443824&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
