POV-Ray : Newsgroups : povray.binaries.images : Towards Tek's Isosurface City Server Time
16 Apr 2026 18:44:11 EDT (-0400)
  Towards Tek's Isosurface City (Message 1 to 6 of 6)
Subject: Towards Tek's Isosurface City
Date: 27 Dec 2023 22:50:00
Message: <web.658cef0e2f5f1a9e2ba5690489db30a9@news.povray.org>
The attached image is the results of my attempts to find out how Tek made the
images he posted in this thread:
Subject: Isosurface City revistied (WIP-maybe)
Date: 2008-03-25 19:24:01
https://news.povray.org/povray.binaries.images/thread/%3C47e997a1%40news.povray.org%3E/
AFAIK he did not post the code anywhere in here - and his web pages seems to be
down.
I've not yet figured out what pattern he used to make the windows.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Download 'towards teks isosurface city.png' (1864 KB)
Preview of image 'towards teks isosurface city.png'
Subject: Re: Towards Tek's Isosurface City
Date: 28 Dec 2023 09:45:00
Message: <web.658d898796cac28216086ed06830a892@news.povray.org>
> From: Tek
> down.
> Tor Olav
> http://subcube.com
This looks close, but increasing the relative height of buildings compared to
their base areas gave them more orthogonal / artificial looking overall lines.
by the looks of it I'm assuming that the core of your procedural is a Crackle
pattern... If so, did you use metric 4 to give it more square appearance ? Some
metric superior to 25 would end up providing even "squarer" angled cells.
Using two planimetric components of the vector "form <x,y,z>" (depending on the
orientation of your scene) may also allow you to control the convexity of cells.
Thanks for your endeavour !
These are base on old tweaks I had tried when comparing Blender internal Voronoi
with pov's crackle procedural textures for the purpose of Blender to POV export.
(draft notes attached)
Download 'blend2povvoronoi.pdf' (441 KB)
Date: 28 Dec 2023 11:10:00
Message: <web.658d9cc996cac2821f9dae3025979125@news.povray.org>
Hi TOK - thanks for the recent advice!  :)
I have been rewiring my brain for the past several years, but still need to do
more to get better at functional programming. It's gonna take me a while to
unravel this one and implement it in SDL:
https://www.shadertoy.com/view/fsyyzt
Kenneth was working on a very similar building scene a while back - maybe you
may find some clues there.
http://news.povray.org/povray.binaries.images/thread/%3C59766804%40news.povray.org%3E/
Hi Maurice - I'd be interested to see what work you've done with the Voronoi
pattern, and if you have a version that infinitely tiles.  I haven't fully
worked out the details of that part yet.
I did manage to work out full-color solid cells, but my colors don't tile along
with the repeating pattern for some reason.
I have also worked out many of the source-code patterns in SDL, if you're
interested in seeing my code for those.
Date: 29 Dec 2023 15:10:00
Message: <web.658f273996cac2829b4924336e066e29@news.povray.org>
> to be down.
Your attempt looks quite good as-is!
In the newsgroups, this is what I have found. I already had links to a few of
these:
his early renders  and code, March 2002... "the power of crackle"...
https://news.povray.org/povray.binaries.images/thread/%3C3C8C6B5A.A940E282%40gmx.de%3E/
and
https://news.povray.org/povray.binaries.scene-files/thread/%3C3c8bf694%40news.povray.org%3E/?ttop=442431&toff=950
Another render from March 18 2002...
https://news.povray.org/povray.binaries.images/thread/%3C3c97ab74%241%40news.povray.org%3E/
and his code, March 19 2002-- he called it 'Crackle City'...
https://news.povray.org/povray.binaries.scene-files/thread/%3C3c96f0bc%40news.povray.org%3E/?ttop=442431&toff=950
from August 2009... something he called 'Greeble City'...
https://news.povray.org/povray.binaries.scene-files/thread/%3C4a78a444%40news.povray.org%3E/?ttop=442431&toff=300
and renders of same...
https://news.povray.org/povray.binaries.images/thread/%3C4a78a486%40news.povray.org%3E/
Another from March 2002...
https://news.povray.org/povray.binaries.images/thread/%3C3c96585e%40news.povray.org%3E/
from July 2008...
https://news.povray.org/povray.binaries.images/thread/%3C488e5300%40news.povray.org%3E/?mtop=280940&moff=20
Date: 29 Dec 2023 21:50:00
Message: <web.658f852e96cac282c342de0989db30a9@news.povray.org>
> > From: Tek
> > down.
> > Tor Olav
> > http://subcube.com
I'm struggling a bit to compare the height to base ratio of buildings in
Tek's an my renders.
I'll decrease the building heights in future renders.
Yes, it's a crackle pattern, but with metric 1, as Tek mentioned,
For the buildings I'm using form <-1, 0, +1> and for the ground I'm using
form <-1, +1, 0>.
This sounds interesting. I did not know that it was possible to make the
crackle cells more "squarer".
I know very little about crackle patterns. I tried to read about crackle
in the POV-Ray documentation, but the explanation of the parameters where
to cryptic for me.
I'll experiment with those metric values.
No problem. It's an interesting challenge to try to find out how Tek might
have made his latest city images.
Thank you. I'll have a look at your notes.
I remember now that I once read a little about Voronoi diagrams and that
they are related to crackle patterns.
Tor Olav
http://subcube.com
Date: 2 Jan 2024 20:50:00
Message: <web.6594bc6c96cac2824238d36c89db30a9@news.povray.org>
> > to be down.
> these:
Thank you for all those links Kenneth. I must have done a poor job when looking
for relevant code.
Tor Olav
http://subcube.com
