POV-Ray : Newsgroups : povray.binaries.images : Alum Server Time
18 Jun 2025 08:14:46 EDT (-0400)
  Alum (Message 1 to 10 of 13)
Subject: Alum
Date: 19 Sep 2021 19:10:00
Message: <web.6147c32b226a4256cb705ca46e741498@news.povray.org>
Here's an alum crystal.
The face data (including HKL, distance and colors [not used]) were copied from
KrystalShaper and converted to an array-ready format thanks to a couple of find
& replace operations in notepad++. Because the data works with the cubic
crystalline system, they were easily converted into plane normals and offsets.
The planes were then used in an intersection object. 50 faces total. No
light_sources are present in the scene; just reflections.
(If anyone's wondering why I don't simply export POV-Ray files from
KrystalShaper, it's because in the future I intend to have more customization
options for certain faces.)
Here's the source code (minus luminous bloom):
HKL-cubic-alaun.pov
2021 Samuel B.
Suggested command line options:
 +fn +f +a0.3 +am2 +r1
If outputting to luminous bloom:
 +fh +f +a0.3 +am2 +r1
#version 3.7;
global_settings{
 assumed_gamma 1.0
 max_trace_level 11
#default{ finish{ambient 0} }
#declare RGBSun = srgb 1.3*<2, 1.99, 1.97>;
#declare RGBSky = srgb <.45, .475, .5>;
#declare CamPos = <0, 7, -10>;
camera{
 fisheye right x*.7 up y*.7
 location CamPos
 look_at 0
 angle 60/3.5
 aperture .77 focal_point -z blur_samples 30 variance 0
#if(1)
 sky_sphere{
  pigment{
   spherical scale 2 translate z
   poly_wave 2
   rotate -x*30
   rotate y*40
   color_map{
    [0 RGBSky]
    [1 RGBSun]
// ground plane
#if(1)
 plane{
  y, -1.001
  pigment{
   pigment_pattern{
    cylindrical
    scale 5
    translate 2*z
   pigment_map{
    [0 rgb 0]
    [1
     granite
     scale 5
     turbulence .2 lambda 3
     poly_wave .2
  finish{reflection{.2, 1 fresnel metallic 1} conserve_energy}
  normal{granite .05 scale .001}
  interior{ior 1.55}
// KRSCOPY KrystalShaper data copied from program and converted with notepad++
#declare FaceData =
 array[50][7]{
  {1, 0, 0, 1.02, 255, 255, 128},
  {0, 1, 0, 1.02, 255, 255, 128},
  {0, -1, 0, 1.02, 255, 255, 128},
  {-1, 0, 0, 1.02, 255, 255, 128},
  {0, 0, -1, 1.02, 255, 255, 128},
  {0, 0, 1, 1.02, 255, 255, 128},
  {1, 1, 1, 0.7, 0, 255, 255},
  {1, 1, -1, 0.7, 0, 255, 255},
  {1, -1, 1, 0.7, 0, 255, 255},
  {-1, -1, 1, 0.7, 0, 255, 255},
  {-1, 1, 1, 0.7, 0, 255, 255},
  {1, -1, -1, 0.7, 0, 255, 255},
  {-1, -1, -1, 0.7, 0, 255, 255},
  {-1, 1, -1, 0.7, 0, 255, 255},
  {1, 1, 0, 0.799, 255, 128, 128},
  {1, -1, 0, 0.799, 255, 128, 128},
  {-1, -1, 0, 0.799, 255, 128, 128},
  {-1, 1, 0, 0.799, 255, 128, 128},
  {-1, 0, -1, 0.799, 255, 128, 128},
  {0, 1, 1, 0.799, 255, 128, 128},
  {1, 0, -1, 0.799, 255, 128, 128},
  {0, 1, -1, 0.799, 255, 128, 128},
  {1, 0, 1, 0.799, 255, 128, 128},
  {0, -1, -1, 0.799, 255, 128, 128},
  {-1, 0, 1, 0.799, 255, 128, 128},
  {0, -1, 1, 0.799, 255, 128, 128},
  {3, 2, 1, 0.869, 0, 255, 0},
  {-2, -1, -3, 0.869, 0, 255, 0},
  {1, 3, 2, 0.869, 0, 255, 0},
  {-3, -2, -1, 0.869, 0, 255, 0},
  {2, 1, 3, 0.869, 0, 255, 0},
  {-1, -3, -2, 0.869, 0, 255, 0},
  {3, 2, -1, 0.869, 0, 255, 0},
  {-2, -1, 3, 0.869, 0, 255, 0},
  {1, 3, -2, 0.869, 0, 255, 0},
  {-3, -2, 1, 0.869, 0, 255, 0},
  {2, 1, -3, 0.869, 0, 255, 0},
  {-1, -3, 2, 0.869, 0, 255, 0},
  {-1, 3, 2, 0.869, 0, 255, 0},
  {2, -1, 3, 0.869, 0, 255, 0},
  {3, -2, -1, 0.869, 0, 255, 0},
  {-1, 3, -2, 0.869, 0, 255, 0},
  {-2, 1, 3, 0.869, 0, 255, 0},
  {3, -2, 1, 0.869, 0, 255, 0},
  {1, -3, -2, 0.869, 0, 255, 0},
  {-2, 1, -3, 0.869, 0, 255, 0},
  {-3, 2, 1, 0.869, 0, 255, 0},
  {1, -3, 2, 0.869, 0, 255, 0},
  {2, -1, -3, 0.869, 0, 255, 0},
  {-3, 2, -1, 0.869, 0, 255, 0}
// crystal
#if(1)
 intersection{
  #for(I, 0, 49)
   plane{
    <FaceData[I][0], FaceData[I][1], FaceData[I][2]>, FaceData[I][3]
  // I guessed the proper color :/
  pigment{rgb <.85, .7, 1> filter 1}
  finish{reflection{0, 1 fresnel} conserve_energy}
  normal{granite .03 scale .001}
  interior{
   // alum ior from classicgems.net
   ior 1.453
   media{absorption .3}
   // an unrealistic dispersion value
   dispersion 1.075 dispersion_samples 7
  hollow
  rotate -y*43
Download 'hkl-cubic-alaun9m_07s-plus-lb7b1m_02s.jpg' (29 KB)
Preview of image 'hkl-cubic-alaun9m_07s-plus-lb7b1m_02s.jpg'
Subject: Re: Alum
Date: 19 Sep 2021 19:20:00
Message: <web.6147c4a2cca1de15cb705ca46e741498@news.povray.org>
And here's an image of the crystal as seen in KrystalShaper. It's safe to say
that cubic systems map directly to planes (with the caveat of z being up, and
the handedness possibly being different).
Sam
Download 'alaun-ks.png' (16 KB)
Preview of image 'alaun-ks.png'
Subject: Re: Alum
Date: 20 Sep 2021 09:31:25
Message: <61488d2d$1@news.povray.org>
> HKL-cubic-alaun.pov
> 2021 Samuel B.
generate PNG images by default.
Those two switches are default values since version 3.7.
+a0.3 is also the default when antialiasing is used.
The default of +r3 gives you better results.
> // crystal
> #if(1)
>   intersection{
>    #for(I, 0, 49)
>     plane{
>    #end
For a crystal, this should be :
pigment{rgbt 1}
The colour don't come from the surface but from the substance itself.
>    interior{
This is where the colour of the crystal should be.
Starting settings :
	fade_color rgb <.85, .7, 1>//desired colour
	fade_power 1001 //how the path length affect the colour
	fade_distance 0.5 //base distance to be used for the fading
Adjust fade_distance to change the intensity of the colour of the crystal.
>     ior 1.453
You may also use a colour here.
As a starter, you may try :
{absorbtion rgb<0.15, 0.3, 0>}
Use the complement of your colour. That's 1 minus the desired colour.
>    hollow
>    rotate -y*43
> #end
Subject: Re: Alum
Date: 20 Sep 2021 15:25:06
Message: <6148e012@news.povray.org>
Il 20/09/2021 01:09, Samuel B. ha scritto:
 > Hi,
copied from
couple of find
offsets.
customization
This image is poetic, Sam!
Paolo
Subject: Re: Alum
Date: 21 Sep 2021 11:42:44
Message: <6149fd74$1@news.povray.org>
Cool. Thank you for posting the code.
I used your scene to do a little crude bench-marking of my povr branch.
To create the attached image, I changed:
to
#declare RGBSun = srgb <1, 0.99, 0.97>;
#declare RGBSun = 2.7*RGBSun;
because my povr branch now doesn't allow srgb channel specifications
outside the 0-1 range.
Plus, I changed the crystal's normal to the povr branch's quilted normal
- but still scaled very small - and aiming for a blurred reflection.
Given you are using camera blur to over sample, I wanted to see how
povr's big jitter would compare time wise. The big jitter approach took
2.4x longer to render at +a0.0 +am2 +r4 +j62.111 than your blur samples
method of oversampling. I can tell from the render statistics I was too
aggressive at r4 - as I shot roughly 2.7x more rays. I'd say the mothods
are in the ballpark performance wise, with other differences in control
and result which might matter or not. FWIW.
Bill P.
Download 'sam_.jpg' (47 KB)
Preview of image 'sam_.jpg'
Subject: Re: Alum
Date: 21 Sep 2021 19:50:00
Message: <web.614a6f11cca1de15cb705ca46e741498@news.povray.org>
I know some things are enabled by default, but I like to include all the options
that I plan to change later on... because I'm lazy :D
True that, but +r1 is faster and better than no antialiasing at all, imo. (It
lends a softer look to the rendering.)
Thanks, Alain. I originally used fade_color and supporting statements, but the
color was becoming too saturated. So I cheaped out instead, which is
regrettable. Because by doing so, I only managed to simulate surface dyes, which
are highly frowned upon in the mineral community ;)
Sam
Subject: Re: Alum
Message: <web.614a6f30cca1de15cb705ca46e741498@news.povray.org>
Thanks Paolo!
Sam
Subject: Re: Alum
Date: 21 Sep 2021 20:10:00
Message: <web.614a733fcca1de15cb705ca46e741498@news.povray.org>
Thanks, Bill. Is there a binary of povr for Windows, or am I just not seeing it?
> to
Is that why the image is darker overall? (Why the clamping, btw?)
Right away I can see that the quilted pattern seems superior in this instance.
The reflection on the plane starts out much sharper, whereas the granite pattern
I used starts out way too blurry.
The blur is exaggerated in your render compared to mine, so perhaps the
performance would be more comparative with a reduced bump_size and lower +r
value?
Sam
Subject: Re: Alum
Date: 22 Sep 2021 04:27:05
Message: <614ae8d9$1@news.povray.org>
On 9/21/21 8:05 PM, Samuel B. wrote:
> ... Is there a binary of povr for Windows, or am I just not seeing it?
No, it's a linux / unix / macos only effort. I don't use windows.
Further, I only once in a while publish a tarball(1) that you currently
have to compile yourself. I've not yet gotten to what I want to be my
initial, public, git repository. It's my playpen, but hope some find
bits of the play/work useful.
(1) - To povray.binaries.programming
Yes.
It isn't about clamping values, but rather restricting the srgb* keyword
use to values which make sense. There is an underlying equation - and it
runs for any input channel value - but only values in the [0..1] range
make sense.
//--- Limit srgb use to [0..1] range!
#version 3.8;
global_settings {assumed_gamma 1.0}
#declare RGBSun  = srgb 1.30*<2, 1.99, 1.97>;
#declare RGBSun_0 = rgb 1.30*<2, 1.99, 1.97>;
#declare RGBSun_1 = rgb 4.58*<2, 1.99, 1.97>;
#declare RGBSun_2 = srgb <2.0, 0.9, 0.8>;
#declare RGBSun_3 = srgb <2.0,-0.9,-1.8>;
#declare SRGBSun  = srgb <1.0, 0.45, 0.4>;
#declare RGBSun_4 = 9.16*SRGBSun;
#debug "\n"
#debug concat("srgb 1.30*<2, 1.99, 1.97> = rgb <",
     vstr(3,RGBSun,",", 0,-1),">\n")
#debug concat("rgb  1.30*<2, 1.99, 1.97> = rgb <",
     vstr(3,RGBSun_0,",", 0,-1),">\n")
#debug concat("rgb  4.58*<2, 1.99, 1.97> = rgb <",
     vstr(3,RGBSun_1,",", 0,-1),">\n")
#debug concat("srgb      <2.0, 0.9, 0.8> = rgb <",
     vstr(3,RGBSun_2,",", 0,-1),">\n")
#debug concat("srgb      <2.0,-0.9,-1.8> = rgb <",
     vstr(3,RGBSun_3,",", 0,-1),">\n")
#debug "\n"
#debug concat("9.16*SRGBSun              = rgb <",
     vstr(3,RGBSun_4,",", 0,-1),">\n")
#debug "\n"
#error "Parsing test. Stop early."
> value?
Yes, I expect you are correct.
Attaching another image. Here playing with one of the prototype normal
patterns in povr's bevy normal wrapper. It's kind of a non-drifting(1)
wrinkles rotation about a specified axis (or was it toward a point...).
Anyhow, it's perturbing/mangling the normal and for the image use a
negative bump to intentionally 'sometimes' invert the normals. Doesn't
represent anything real, but I think it looks neat! :-)
(1) - Elsewhere I posted about our current "normal wrinkles pattern bias."
Bill P.
Download 'sam_bevy_normal_6_negbmp.jpg' (49 KB)
Preview of image 'sam_bevy_normal_6_negbmp.jpg'
Subject: Re: Alum
Date: 22 Sep 2021 12:38:50
Message: <614b5c1a$1@news.povray.org>
> Sam
If your colour get to saturated, that mean that your fade_distance is to
short, so, just increase fade_distance as needed.
Also, to get realistic results, fade_power need to be 1001 or 1, not 2.
