Please see the attached downloadable RAR archive file. It contains all necessary
files.
PROBLEM
I am developingm an authentic classical Roman ballista. Those are the
predecessors of the later guns. They use the energy that rope fibers can store.
The ballista is not finished yet, but I am not able to create those twisted
ropes, after one entire day of fruitless attempts. I cannot manage the spline
object, that's the problem.
The attached archive contains a folder called "Example", there you can find a
graphic that shows what is needed (the twisted brown ropes left and right).
If here's anyone who has the ability to help me out, it would be great! All
POV-Ray scene-related files are inside the other three folders.
As a small Thank You for your time, intention and efforts, the archive also
contains another folder by the name of "PCP" - this means "POV-Ray Color Picker"
(for Windows), and lets you select colors and converts them into POV-Ray code.
Very useful.
Please don't hes to ask me, if you have questions. Big thanks.
Download 'ballista 001.rar.dat' (2487 KB)
Hi BaldEagle,
nice hearing again from you, and thanks for yout time.
It is not quite a wraping around the cylinder that I need, it is several ropes
pushed sideways where the horizontal arm extends from the vertical cylinder.
This is something that I cannot do with my current level of POV-skills. I am,
actually, quite desperate and frustrated. :-)
I believe it would be easier to use another render software with a WYSIWYG
editor, and simply visually push the individual ropes sideways, some more, some
less, some not. And then to export that object as mesh for POV-Ray. But I do not
have any other render software on this machine, and I am at the hospital
rightnow, data through mobile phone is expensive. Cannot downloaDo you know of
any way to achieve a solution for the rope problem? I imagine, the sphere-sweep
spline or other splines can be the solution, but I have no understanding of them
and always get bad results. I cannot control their directions die lack of
understanding.
Hope this helps.
The vertical cylinder where the ropes go around has a diamter of 0.25 and a
height from < 0.0, 0.0, 0.0 > to < 0.0, 2.7, 0.0 >.
The arm separates from the middle of the cylinder#s height and has an own radius
of 0.2 there.
Excerpt:
union // sling arm
cylinder { < 0.0, -0.2, 0.0 > < 0.0, 2.5, 0.0 > 0.25 texture { TopColor rotate
< 90.0, 0.0, 0.0 > } }
cone { < 0.0, 1.15, 3.0 > 0.15 < 0.0, 1.15, 0.0 > 0.2 texture { TopColor } }
box { < 0.0, 1.00, 3.0 > < 0.18, 1.30, 2.5 > texture { RustyIron } }
cylinder { < 0.0, 1.15, 3.0 > < 0.0, 1.15, 2.9 > 0.17 texture { RustyIron }
cylinder { < 0.0, 1.15, 2.7 > < 0.0, 1.15, 2.6 > 0.18 texture { RustyIron }
torus { 0.15, 0.05 translate < 0.18, 1.15, 2.75 > texture { RustyIron } }
sphere { < 0.0, 1.15, 3.0 > 0.15 texture { RustyIron } }
torus { 0.05, 0.025 rotate < 90.0, 0.0, 0.0 > translate < 0.33, 1.15, 2.75 >
texture { Rope } } // // ropes around rings
cylinder { < 0.33, 1.15, 2.75 > < 4.19, 1.275, 3.7825 > 0.025 texture { Rope
rotate < 0.0, 55.0, 0.0 >
translate < -1.5, 0.0, 1.32 >
The first cylinder is the vertical one (rope skein), and the first cone is the
arm.
The ropes need to have a cross-section radius larger tan 0.025, maybe 0.030 or
0.035 maximum.
