POV-Ray : Newsgroups : povray.binaries.images : Small abstract Server Time
29 Jun 2024 04:30:15 EDT (-0400)
  Small abstract (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Small abstract
Date: 19 May 2019 07:10:30
Message: <5ce139a6$1@news.povray.org>
On 19-5-2019 11:58, Norbert Kern wrote:
> and here the image...
Question: shouldn't 'method 2' not be 'method 3' in the media?
Date: 20 May 2019 05:00:56
Message: <5ce26cc8$1@news.povray.org>
Norbert Kern wrote on 19/05/2019 11:58:
Ethereal and relaxing.
Paolo
Date: 20 May 2019 15:30:01
Message: <web.5ce300095e75640e3c1c78400@news.povray.org>
> This is very beautiful indeed. Can be anything, from a cityscape to a
> microchip, and everything in between.
> Thank you!
> Thomas
I like the variability of the crackle pattern too - it can contain everything...
Norbert
Message: <web.5ce300315e75640e3c1c78400@news.povray.org>
> It sure is nice enough to show.
> Well done.
> Cheers
> Ton.
Thank you very much
Norbert
Date: 20 May 2019 15:35:01
Message: <web.5ce300ad5e75640e3c1c78400@news.povray.org>
> Thomas
I tried method 3, but it was slower, not better - but I made the test in an
early stage...
Norbert
Message: <web.5ce301005e75640e3c1c78400@news.povray.org>
> Paolo
That's a very kind comment - thank's for that
Norbert
Date: 21 May 2019 03:16:10
Message: <5ce3a5ba$1@news.povray.org>
>> Thomas
> early stage...
> Norbert
I suggest to use method 3 all right, but with a much lower samples
value: 600 instead of 1600 is already much faster and without
significant view deterioration. You can probably even lower it much
more. With samples 100 the image becomes a bit splotchy though.
Date: 26 May 2019 15:40:01
Message: <web.5ceaeabd5e75640e3c1c78400@news.povray.org>
> Thomas
Here is a version with method 3 and a different color map.
I used 1000 samples and it took 3 days for a 8000*4500 render.
I'm not concinced...
Norbert
Download 'abstract_neuer25.jpg' (777 KB)
Preview of image 'abstract_neuer25.jpg'
Date: 26 May 2019 18:25:01
Message: <web.5ceb11285e75640ea2aab1e70@news.povray.org>
hi,
how many physical monitors to make your desktop?!  :-)
me neither, too .. busy.  the green+blue works a lot better for me[*].  meant to
say thank you for the original (am using it as a wallpaper), 'ethereal' is the
perfect word I think.
[*] since Thomas said "from a cityscape to a microchip, and everything in
between", I can't help thinking: Greater Venice in the Year 2525, seen from an
aircraft.  :-)
regards, jr.
Date: 27 May 2019 03:11:34
Message: <5ceb8da6@news.povray.org>
I do not really like that color_map...
I started a small test with version 3.8, method 3, 200 samples, and
using 6 threads. After about 35 minutes, this is the state of the matter.
Download 'test.png' (306 KB)
Preview of image 'test.png'
