On 20-5-2019 21:31, Norbert Kern wrote:
> Thomas de Groot <tho### [at] degrootorg> wrote:
>> On 19-5-2019 11:58, Norbert Kern wrote:
>> Question: shouldn't 'method 2' not be 'method 3' in the media?
>> Thomas
> I tried method 3, but it was slower, not better - but I made the test in an
> early stage...
> Norbert
I suggest to use method 3 all right, but with a much lower samples
value: 600 instead of 1600 is already much faster and without
significant view deterioration. You can probably even lower it much
more. With samples 100 the image becomes a bit splotchy though.
> Thomas
Here is a version with method 3 and a different color map.
I used 1000 samples and it took 3 days for a 8000*4500 render.
I'm not concinced...
Norbert
Download 'abstract_neuer25.jpg' (777 KB)
Preview of image 'abstract_neuer25.jpg'
hi,
how many physical monitors to make your desktop?! :-)
me neither, too .. busy. the green+blue works a lot better for me[*]. meant to
say thank you for the original (am using it as a wallpaper), 'ethereal' is the
perfect word I think.
[*] since Thomas said "from a cityscape to a microchip, and everything in
between", I can't help thinking: Greater Venice in the Year 2525, seen from an
aircraft. :-)
regards, jr.
I do not really like that color_map...
I started a small test with version 3.8, method 3, 200 samples, and
using 6 threads. After about 35 minutes, this is the state of the matter.
Download 'test.png' (306 KB)
Preview of image 'test.png'
