![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 3-2-2019 10:26, ingo wrote:
> in news:5c569fc3$1@news.povray.org Thomas de Groot wrote:
>> http://news.povray.org/povray.binaries.images/attachment/%3Cweb.4ac2c5
>> 52a7005b411322341f0@news.povray.org%3E/landscapetutorial.pov.txt
> Interesting.
> There once was an include file for realistic sky/(fog?) based on media
> that had proper absortion depending on the suns angle. Can't find it :(
> Regarding tree placement, it would be nice if we could use voronoi
> (crackle) some howe to determine how big the crown of a tree can be before
> intersecting with the surrounding ones.
> The centre of the cell would be the trunk. The size of the cell the crown
> and the height of the tree.
> http://math.lbl.gov/voro++/examples/ for inspiration,
> ingo
I have to do a bit of research, but my mind tells me 'Tek' (Tekno
Frannansa) and a scene called 'Dawn'. I have it somewhere. Also there is
Jaime Vives Piqueres who has produced realistic skies with LightsysIV. I
have used it quite often but have to look that up too presently; will
take a little time.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Interesting.
> ingo
Too difficult .!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Interesting.
> ingo
That's a rather brilliant idea. :)
I have a .pov file where I copied the POV-Ray source for the crackle pattern,
hoping to decode it / translate it into SDL, for use in such scenes where the
parameters of the Voronoi diagram are user-accessible, but I have a lot to learn
about C++ and mysterious things like operator overloading....
That said, there's the way to "fake" a Voronoi diagram with overlapping cones.
Perhaps there's a way to do something with an array of cone-axes, and either
brute-force "collision detection" (overlap within a given radius) or using a
quad-tree plus collision detection, difference{} away the surrounding cones, and
then use trace() to determine the radius of the inscribed circle.
This might help a lot too:
https://en.wikipedia.org/wiki/Delaunay_triangulation#Algorithms
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
in news:web.5c57285b6bbc5191765e06870@news.povray.org Bald Eagle wrote:
> Voronoi diagram
been tinkering with it today using the voro++ commandline programm and the
Tess python binding. Intersting stuff can be done with it and I have my
first voronoi forrest, albeit with a bit of scaling that should not be.
I'm in the process of writing a python file that outputs all possible data
in arrays. The boundaries/faces of each cell can be turned into polygons
relative easy.
The voro++ command line programm output nice POV-Ray files, but arrays are
handier.
The main problem so far is the interaction with the boundaries of the
'box' that contains the cells.
ingo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Interesting.
>> ingo
> Too difficult .!
Seconded!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
in news:5c57e89b$1@news.povray.org Thomas de Groot wrote:
>> Too difficult .!
> Seconded!
is it?
ingo
Download 'forrest_spheres.jpg' (45 KB)
Preview of image 'forrest_spheres.jpg'
![forrest_spheres.jpg](/povray.binaries.images/attachment/%3CXnsA9EC6BC34394Fseed7%40news.povray.org%3E/forrest_spheres.jpg?ttop=428755&toff=100&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> Too difficult .!
>> Seconded!
> is it?
> ingo
I need to see the code in order to judge ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
<XnsA9EC8ED92EA29seed7@news.povray.org>
ingo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> ingo
Right, but my point is that - not having too much time - I am reluctant
to plunge into the learning/use of C++ programming at this stage. :-/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No need for that. I currently have a running python3 program that parses
the output file of Voro++ and writes the data as POV-Ray arrays to a file.
It uses exactly the same commandline options as Voro++ and even calls
Voro++ for you. Needs a thourough cleaning up, so it will take some time
before I publish it.
ingo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
