POV-Ray : Newsgroups : povray.binaries.images : pattern blend Server Time
4 Apr 2026 19:05:56 EDT (-0400)
  pattern blend (Message 27 to 36 of 66)
Subject: Re: pattern blend
Date: 5 Mar 2018 08:30:00
Message: <web.5a9d45db8351d7b05cafe28e0@news.povray.org>
This is a great tool - one that is obvious in retrospect, but I had never
thought of.
It's great that it's possible to save an image with a certain gamma and then use
it as a height field, but the obvious question that affects the real utility of
this is:
Is it possible to READ the existing, non-gamma modified image in using a certain
gamma value for use in a height field?
So, for example, use TdG's gamma 1.0 image to generate his gamma 2.2 height
field?
Date: 5 Mar 2018 08:46:56
Message: <5a9d4a50$1@news.povray.org>
Am 05.03.2018 um 14:27 schrieb Bald Eagle:
> thought of.
> this is:
> field?
Well, yes, absolutely: In the height field, just specify "gamma FLOAT"
after the image file name.
I think you need to specify "gamma 1/2.2" for the intended effect.
There may be slight differences due to different rounding, but other
than that it should work just fine.
Date: 5 Mar 2018 10:15:00
Message: <web.5a9d5e968351d7b06d6a50430@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> Has anyone tried to produce a solarisation effect?
with a simple approach I got this image - here is the code
// render with image resolution and No AA. Method is very memory intensive for
large image sizes!
#version 3.7;
global_settings {
        assumed_gamma 1
#include "stdinc.inc"
        orthographic
        location <0,0,-2>
        look_at 0
        right x*image_width
        up y*image_height
#declare image_width_Old = image_width;
#declare image_ratio = image_width/image_height;
#declare image_height_Old = image_width_Old/image_ratio;
#declare pig_map =
function {
                image_map {jpeg "glasses" gamma 2.2}
                scale <image_width_Old,image_height_Old,1>
#declare nx = 0;
#while (nx < image_width)
        #declare ny = 0;
        #while (ny < image_height)
                #declare paint_pig = pig_map (nx+0.5,ny+0.5,0);
                box {
                        0, 1
                        pigment {color srgb <max (paint_pig.x,
1-paint_pig.x),max (paint_pig.y, 1-paint_pig.y),max (paint_pig.z,
1-paint_pig.z)>*2-1}
                        finish {emission 1 diffuse 0}
                        translate <nx-image_width*0.5,ny-image_height*0.5,0>
                #declare ny = ny+1;
        #declare nx = nx+1;
        #debug concat (str (nx/image_width*100, 0, 1)," % processed \n")
Norbert
Download 'glasses solarized.jpg' (359 KB)
Preview of image 'glasses solarized.jpg'
Date: 5 Mar 2018 11:50:25
Message: <5a9d7551$1@news.povray.org>
> Hi,
Oo! shiny. I like.
You are on a roll, Norbert. :-)
> large image sizes!
> #version 3.7;
> global_settings {
>          assumed_gamma 1
> camera {
>          orthographic
>          location <0,0,-2>
>          look_at 0
>          right x*image_width
>          up y*image_height
> #declare pig_map =
> function {
>          pigment {
> #declare nx = 0;
>          #declare ny = 0;
>                  box {
>                          0, 1
>                  #declare ny = ny+1;
>          #end
>          #declare nx = nx+1;
> #end
> Norbert
Regards
Date: 5 Mar 2018 11:52:47
Message: <5a9d75df@news.povray.org>
On 05/03/2018 16:50, Stephen wrote:
> Oo! shiny. I like.
It looks good as a negative, too (also).
Regards
Date: 5 Mar 2018 15:40:01
Message: <web.5a9daa628351d7b0a47873e10@news.povray.org>
> Hi,
Brilliant! I actually didn't think it was possible.
Date: 5 Mar 2018 15:55:00
Message: <5a9daea4@news.povray.org>
> On 4-3-2018 18:12, Norbert Kern wrote:
>> #declare p_o_x = function {p_original (x,y,z).x}
>> #declare p_o_y = function {p_original (x,y,z).y}
>> #declare p_o_z = function {p_original (x,y,z).z}
> I had thought to use:
> #declare p_o_R = function {p_original (x,y,z).red}
> #declare p_o_G = function {p_original (x,y,z).green}
> #declare p_o_B = function {p_original (x,y,z).blue}
> But that should yield the same thing I guess. I was going to code that...
Yes, both forms will yield the same end result, but, the second form is
recommended whenever you are dealing with colours.
Date: 5 Mar 2018 15:55:01
Message: <web.5a9dadc48351d7b0a47873e10@news.povray.org>
> > I shall make a small test scene. A way for me to remember stuff.
> Like this. Left, image gamma is 1.0; right, image gamma is 2.2.
Nice! And you picked a good pattern to show it off.
The real *fun* begins when you take a height_field image (made elsewhere) and
*combine* it with a procedural pigment or pattern-- both of which can be
gamma-bent. It's a bit more complicated to code, but I was working up an example
anyway, and will post in a new thread. (BTW, some other interesting effects can
be gotten by making the gamma *less than* 1.0.)
Date: 5 Mar 2018 18:05:01
Message: <web.5a9dcc7e8351d7b0a47873e10@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> (There's also a HF difference
> between images SAVED at different gamma values, for the same reason-- 1.0 being
> a linear slope, 2.2 being more of a curve.)
Uh, I'm not so sure about that now. I made a test scene a couple of weeks ago
that showed this. (Or so I thought.) Now, a newer test scene shows no
difference-- producing the same 'linear' height_field slopes no matter what
gamma the images are saved at (with either JPEG *or* PNG image files.) But then
again, I'm using my older wonky Photoshop 5 to make and save the original
images, which can't be completely trusted as far as gamma goes.  Hmm, a mystery.
Date: 6 Mar 2018 02:40:49
Message: <5a9e4601@news.povray.org>
>> thought of.
>> this is:
>> field?
And that is exactly what I did above; I see that I generated some
confusion with BaldEagle :-) The - single - original height_field image
has an unknown (to me) gamma. It is in POV-Ray that I declare the gamma
value to use, like Clipka said [code snippet]:
     image_map {
       tga "Apophysis_06_hfisland.tga" gamma 2.2 //or 1.1
       map_type 0
       interpolate 2
