POV-Ray : Newsgroups : povray.binaries.images : pattern blend Server Time
20 Sep 2024 20:19:36 EDT (-0400)
  pattern blend (Message 21 to 30 of 66)
Subject: Re: pattern blend
Date: 5 Mar 2018 04:05:30
Message: <5a9d085a@news.povray.org>
Just to show off. ;-)
Download 'and_pattern blend.png' (698 KB)
Preview of image 'and_pattern blend.png'
Date: 5 Mar 2018 04:11:04
Message: <5a9d09a8@news.povray.org>
again...
Download 'and_pattern blend_f2.png' (474 KB)
Preview of image 'and_pattern blend_f2.png'
Date: 5 Mar 2018 04:18:41
Message: <5a9d0b71$1@news.povray.org>
> again...
I like this one. :-)
Has anyone tried to produce a solarisation effect?
Regards
Date: 5 Mar 2018 04:46:11
Message: <5a9d11e3$1@news.povray.org>
On 3/2/2018 10:27 AM, And wrote:
> Use some codes to modify photos.
> #declare p_modify1 =
> pigment{
>      pigment_pattern{p_original}
>      pigment_map{
>      #for(i,0,255)
>          [i/255,
>          bumps
>          scale 1/input_wide_res
>          scale 4.8
>          rotate <0,0,20>
>              color_map{
>              [0.2+0.6*(1-pow(i/255,1/3)) rgbt<0,0,0,0.1>]
>              [0.2+0.6*(1-pow(i/255,1/3)) rgbt<0,0,0,0.9>]
>      #end
I needed such a "half-tone" effect for something or other in the past. I
wish I could remember what.
Mike
Date: 5 Mar 2018 05:20:00
Message: <web.5a9d18df8351d7b01792537a0@news.povray.org>
> Thomas
This two are dazzling.
Date: 5 Mar 2018 07:55:58
Message: <5a9d3e5e@news.povray.org>
On 5-3-2018 8:40, Thomas de Groot wrote:
> On 4-3-2018 15:51, Kenneth wrote:
>> Thomas de Groot <tho### [at] degrootorg> wrote:
>>>>> It is a bit like your airbrush.
>>>>> Thomas
>>>> I'd like to see.
http://news.povray.org/povray.binaries.images/thread/%3C48295282%40news.povray.org%3E/
>> BTW, re: the discussion there of 'bending the slopes of
>> height_fields': It can
>> be done in an alternate way now, using POV-Ray's 'blend gamma'
>> feature-- i.e.,
>> by purposely changing the gamma of the image that's used to make the
>> HF. That
>> effectively changes the otherwise 'linear' slope of HF contours to
>> more of a
>> curve. For example, HF mountains made this way look more natural to my
>> eye--
>> like the mountain's slopes have naturally eroded. (There's also a HF
>> difference
>> between images SAVED at different gamma values, for the same reason--
>> 1.0 being
>> a linear slope, 2.2 being more of a curve.)
> Indeed. That is something I never really used purposefully but which you
> do well to remind me of. Thanks!
> I shall make a small test scene. A way for me to remember stuff.
Like this. Left, image gamma is 1.0; right, image gamma is 2.2.
Download 'hf_test_image gamma.png' (132 KB)
Preview of image 'hf_test_image gamma.png'
Date: 5 Mar 2018 08:30:00
Message: <web.5a9d45db8351d7b05cafe28e0@news.povray.org>
This is a great tool - one that is obvious in retrospect, but I had never
thought of.
It's great that it's possible to save an image with a certain gamma and then use
it as a height field, but the obvious question that affects the real utility of
this is:
Is it possible to READ the existing, non-gamma modified image in using a certain
gamma value for use in a height field?
So, for example, use TdG's gamma 1.0 image to generate his gamma 2.2 height
field?
Date: 5 Mar 2018 08:46:56
Message: <5a9d4a50$1@news.povray.org>
Am 05.03.2018 um 14:27 schrieb Bald Eagle:
> thought of.
> this is:
> field?
Well, yes, absolutely: In the height field, just specify "gamma FLOAT"
after the image file name.
I think you need to specify "gamma 1/2.2" for the intended effect.
There may be slight differences due to different rounding, but other
than that it should work just fine.
Date: 5 Mar 2018 10:15:00
Message: <web.5a9d5e968351d7b06d6a50430@news.povray.org>
with a simple approach I got this image - here is the code
// render with image resolution and No AA. Method is very memory intensive for
large image sizes!
#version 3.7;
global_settings {
        assumed_gamma 1
#include "stdinc.inc"
        orthographic
        location <0,0,-2>
        look_at 0
        right x*image_width
        up y*image_height
#declare image_width_Old = image_width;
#declare image_ratio = image_width/image_height;
#declare image_height_Old = image_width_Old/image_ratio;
#declare pig_map =
function {
                image_map {jpeg "glasses" gamma 2.2}
                scale <image_width_Old,image_height_Old,1>
#declare nx = 0;
#while (nx < image_width)
        #declare ny = 0;
        #while (ny < image_height)
                #declare paint_pig = pig_map (nx+0.5,ny+0.5,0);
                box {
                        0, 1
                        pigment {color srgb <max (paint_pig.x,
1-paint_pig.x),max (paint_pig.y, 1-paint_pig.y),max (paint_pig.z,
1-paint_pig.z)>*2-1}
                        finish {emission 1 diffuse 0}
                        translate <nx-image_width*0.5,ny-image_height*0.5,0>
                #declare ny = ny+1;
        #declare nx = nx+1;
        #debug concat (str (nx/image_width*100, 0, 1)," % processed \n")
Norbert
Download 'glasses solarized.jpg' (359 KB)
Preview of image 'glasses solarized.jpg'
Date: 5 Mar 2018 11:50:25
Message: <5a9d7551$1@news.povray.org>
> Hi,
Oo! shiny. I like.
You are on a roll, Norbert. :-)
> large image sizes!
> #version 3.7;
> global_settings {
>          assumed_gamma 1
> camera {
>          orthographic
>          location <0,0,-2>
>          look_at 0
>          right x*image_width
>          up y*image_height
> #declare pig_map =
> function {
>          pigment {
> #declare nx = 0;
>          #declare ny = 0;
>                  box {
>                          0, 1
>                  #declare ny = ny+1;
>          #end
>          #declare nx = nx+1;
> #end
> Norbert
Regards
