POV-Ray : Newsgroups : povray.binaries.images : creepy figures Server Time
17 May 2024 22:19:04 EDT (-0400)
  creepy figures (Message 21 to 24 of 24)
Subject: Re: creepy figures
Date: 12 Feb 2018 12:35:08
Message: <web.5a81cf372200fd9e254f29550@news.povray.org>
> So, I have read about the octree algorithm, and I can follow along and make
> sense of what's going on, however -
> (and maybe I need to go through it in a much more detailed level)
> One of the interesting things about an octree is "saving" the leaves and
> rejecting the empty voxels so that later you can quickly traverse the octree.
> Maybe that's what he had developed later, before the HDD crash, but I think
> that's a tool that a lot of Povvers could use, and I'm interested in learning
> about that aspect of it, and coding it up as time permits.
> Also, I don't see that Robert used a difference{}, and so I'm unsure how you're
> suggesting I implement that second object and where it gets referenced.
Here is a test scene to play with.
#version 3.7;
#declare RAD = 4;
global_settings {
        #declare a_g = 2.2;
        assumed_gamma a_g
        max_trace_level 5
        noise_generator 2
        #if(RAD > 0)
                radiosity {
                        pretrace_start 0.08
                        pretrace_end 0.04/RAD
                        count 30*RAD
                        nearest_count min (20, RAD)
                        error_bound 2/RAD
                        low_error_factor 0.5
                        recursion_limit 1
                        gray_threshold 0
                        minimum_reuse 0.015
                        brightness 1
                        adc_bailout 0.005
                        normal on
                        media on
#include "stdinc.inc"
sky_sphere {
                average
                pigment_map {
                        [1      function {max (min (y, 1), 0)}
                                color_map {
                                        [0      rgb 2.35]
                                        [0.96   rgb 4.5]
                                        [1      rgb 13.5]
                                turbulence 0.2
                                color_map {
                                        [0      rgbt 1]
                                        [0.5    rgbt <0.385,0.77,1.1,1>]
                                rotate z*-45
        location <2,2,-4>
        look_at <0.1,0,0>
        up y
        angle 82
light_source {
        <-80000,50000,-50000>,
        color rgb <2.42,2.23,1.87>
plane {y, -1.6 finish {reflection {0, 1}}}
//______________________________________________________________________________
#declare obj_ =
isosurface {
 function {f_sphere (x,y,z,1)-f_noise3d (x*2.5,y*2.5,z*2.5)*0.6}
 contained_by {sphere {0, 1.6}}
 max_gradient 2.5
 hollow
         pigment {color rgb <0.35,0.32,0.55>}
object {obj_}
#declare rootObj =
difference {
        object {obj_ scale <2.5, 1.4,1.4>}
        object {obj_}
#declare thin = 0.02;
#declare frame =
union {
        cylinder {<-1,-1,-1>, <-1,1,-1>, thin}
        cylinder {<-1,-1,1>, <-1,1,1>, thin}
        cylinder {<1,-1,-1>, <1,1,-1>, thin}
        cylinder {<1,-1,1>, <1,1,1>, thin}
        cylinder {<-1,-1,-1>, <1,-1,-1>, thin}
        cylinder {<1,-1,-1>, <1,-1,1>, thin}
        cylinder {<1,-1,1>, <-1,-1,1>, thin}
        cylinder {<-1,-1,1>, <-1,-1,-1>, thin}
        cylinder {<-1,1,-1>, <1,1,-1>, thin}
        cylinder {<1,1,-1>, <1,1,1>, thin}
        cylinder {<1,1,1>, <-1,1,1>, thin}
        cylinder {<-1,1,1>, <-1,1,-1>, thin}
        sphere {<-1,-1,-1>, thin}
        sphere {<1,-1,-1>, thin}
        sphere {<-1,1,-1>, thin}
        sphere {<-1,-1,1>, thin}
        sphere {<-1,1,1>, thin}
        sphere {<1,-1,1>, thin}
        sphere {<1,1,-1>, thin}
        sphere {<1,1,1>, thin}
#declare MAX_DEPTH = 8;
#declare R = seed (0);
#declare OUTSIDE = 0;
#declare PARTIAL = 1;
#declare INSIDE  = 2;
#declare _nDepth = 0;
#declare _nBoxes = 0;
#declare _nNullBoxes = 0;
#macro GAUSS (X)
((rand (X)+rand (X)+rand (X)+rand (X)+rand (X)+rand (X)-3)*1)
#macro GetBoxState (obj_, bbox)
#local bmin = min_extent (bbox);
#local bmax = max_extent (bbox);
#local n = 0;
#if (inside (obj_, <bmin.x,bmin.y,bmin.z>)) #local n = n+1; #end
#if (inside (obj_, <bmax.x,bmax.y,bmax.z>)) #local n = n+1; #end
#if (inside (obj_, <bmin.x,bmax.y,bmin.z>)) #local n = n+1; #end
#if (inside (obj_, <bmax.x,bmax.y,bmin.z>)) #local n = n+1; #end
#if (inside (obj_, <bmax.x,bmin.y,bmin.z>)) #local n = n+1; #end
#if (inside (obj_, <bmin.x,bmin.y,bmax.z>)) #local n = n+1; #end
#if (inside (obj_, <bmin.x,bmax.y,bmax.z>)) #local n = n+1; #end
#if (inside (obj_, <bmax.x,bmin.y,bmax.z>)) #local n = n+1; #end
#switch (n)
        #case (0)
                #local state = OUTSIDE;
        #break
        #case (8)
                #local state = INSIDE;
        #break
        #else
                #local state = PARTIAL;
        #break
state
#macro BuildDisplayVoxel (bbox)
#local clr1 = srgb <225,180,105>/255;
#local clr2 = srgb <105,90,30>/255;
#local gry  = RRand (0.1, 0.9, R);
#local ctr  = (bmin+bmax)*0.5;
union {
        object {frame}
        rotate y*90
        scale _rootScale
        pigment {color rgb <1,0,0>}
        scale vlength (ctr-bmax)
        translate ctr
#declare _nBoxes = _nBoxes+1;
#macro SubdivideVoxel (root, bbParent)
#declare _nDepth = _nDepth+1;
#if (_nDepth <= MAX_DEPTH)      // break into 8 sub-boxes
        #local aBox = array [8];
        #local bmin = min_extent (bbParent);
        #local bmax = max_extent (bbParent);
        #local midX = (bmin.x+bmax.x)*0.5;
        #local midY = (bmin.y+bmax.y)*0.5;
        #local midZ = (bmin.z+bmax.z)*0.5;
        #local aBox [0] = box {<bmin.x,bmin.y,bmin.z>,<midX,  midY,  midZ>}
        #local aBox [1] = box {<bmin.x,midY,  bmin.z>,<midX,  bmax.y,midZ>}
        #local aBox [2] = box {<midX,  bmin.y,bmin.z>,<bmax.x,midY,  midZ>}
        #local aBox [3] = box {<midX,  midY,  bmin.z>,<bmax.x,bmax.y,midZ>}
        #local aBox [4] = box {<bmin.x,bmin.y,midZ>,  <midX,  midY,  bmax.z>}
        #local aBox [5] = box {<bmin.x,midY,  midZ>,  <midX,  bmax.y,bmax.z>}
        #local aBox [6] = box {<midX,  bmin.y,midZ>,  <bmax.x,midY,  bmax.z>}
        #local aBox [7] = box {<midX,  midY,  midZ>,  <bmax.x,bmax.y,bmax.z>}
        #local n = 0;
        #while (n < 8)
                #if (INSIDE = GetBoxState (root, aBox [n]))
                        BuildDisplayVoxel (aBox [n])
                #else
                        #if (PARTIAL = GetBoxState (root, aBox [n]))
                                SubdivideVoxel (root, aBox [n])
                        #else
                                #declare _nNullBoxes = _nNullBoxes+1;
                                #local isect =
                                intersection {
                                        object {root}
                                        object {aBox [n]}
                                #local bmin = min_extent (isect);
                                #if (bmin.x > -10000000000)
                #local n = n+1;
#declare _nDepth = _nDepth-1;
#macro SubdivideVoxelMain (root, bbParent)
#local n = 0;
#while (n < 8)
        #else
                #else
        #local n = n+1;
#declare bmin = <-40,-40,-40>; //min_extent (rootObj);
#declare bmax = <40,40,40>; //max_extent (rootObj);
#declare ctr = (bmin+bmax)*0.5;
#declare bbRoot =
box {
        vtransform (ctr, transform {translate -bmax}),
        vtransform (ctr, transform {translate bmax})
#declare _rootScale = 20/vlength (ctr-bmax)*2;
union {
        SubdivideVoxelMain (rootObj, bbRoot)
// end of code
Norbert
Download 'octree_test_scene.jpg' (614 KB)
Preview of image 'octree_test_scene.jpg'
Date: 12 Feb 2018 12:55:00
Message: <web.5a81d3d52200fd9ec437ac910@news.povray.org>
Excellent - that looks nice.
I experimented with the original code for a while, and got things to 'work'
after a bit of fiddling.
I tried using a Wire_Box object instead of a sphere with unit edges, and that
was way too small.  7-10 units seemed to work much better for some reason.
I had to crank up the subdivision level to 7 to get good coverage of "Jack".
http://news.povray.org/povray.binaries.images/message/%3Cweb.5a1f60f72471086b5cafe28e0%40news.povray.org%3E/#%3Cweb.5a1
It also didn't really seem to be doing quite what I thought it might, based on
the size and placement of the boxes.  I might need to do a progressively finer
subdivision like in the original post, and color code the inside, partial, and
outside states of the bounding boxes.
Thanks again for the test scene - I'll try to look at it in detail tonight.  :)
Date: 19 Feb 2018 04:50:00
Message: <web.5a8a9d862200fd9e16086ed00@news.povray.org>
> Hello,
> here is a way to modificate meshes of humans or animals to creepy figures.
> After finding a random point on a mesh surface another trace was done inside the
> mesh. A box was then placed between the two points.
> Each of the two figures consists of 990.000 boxes.
> Texture uses a proximity technique described in
http://news.povray.org/povray.binaries.images/thread/%3Cweb.59d38d1358cfc649f2ea585a0%40news.povray.org%3E/.
> Background is from Margus Ramst.
> Scene uses assumed_gamma 1 as in my last pictures.
> Norbert
Amazing result ! Giacometti-like figures over a Magritte background, gracious
postures and anatomy.
Date: 19 Feb 2018 18:00:01
Message: <web.5a8b56c92200fd9ea47873e10@news.povray.org>
> several years before I stopped working on an image because of the disturbing
> river rock distribution...
This is gorgeous. There si so much to like in the scene-- the warm afternoon
sunlight, the composition, the flowers and weeds and their colors. The scene has
a nice *choice* of colors, too-- not *every color in the rainbow* but a
restricted palette. (Personally, I think that's an attribute of some of the best
paintings.)
I think many of the rocks are a bit too 'flat'-- several look like turtles (uh,
maybe they ARE turtles!) But as Thomas noted, sinking them further into the mud
would be a choice, along with fattening them up along the y-axis. Although I
really like your rough-looking rock and stone textures in most of the scene,
river rocks have a tendency to be smoother.
