![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 28/11/2017 19:37, Sven Littkowski wrote:
> On 28.11.2017 13:47, Stephen wrote:
>> Why don't you try yourself. You will never get the expertise if you get
>> others to build your scenes.
>> Help is a good thing but ask for it when you fail to get the results you
>> want.
> I actually do, trust me. :-)
The phrase brings back memories, man. ;)
I do if you say so.
> I am sitting hours and days on this scene. I did not want to give the
> impression I am not involving myself heavily into this. Oh gosh - really
> not at all.
Maybe one of the failed experiments would help us to see what your
problem is.
You may have to use extreme emission settings. On a df3 scene I was
working on at the beginning of the month. I could not understand why the
df3s were not showing up properly until I set emission > 1000. I wasted
a couple of weeks creating and recreating df3s until I realised the
solution.
> I am good with regular shapes and differences, doing those things for
> decades. I just never ventured out into media and such. See the attached
> image, I did this, without even any WYSIWYG editor. But as strange as it
> sounds, trying to understand media is for me the same difficult as to
> try to learn using WYSIWYG editors which are sooo easy to use for
> others. Much easier for me to keep all coordinates in my mind and get a
> visual understanding of the objects (that's how I built that spaceship).
Very nice!
I can't do what you can do. Which is why I use a modeller to see the
scene in OpenGl.
> The human mind is truly ununderstandable and not logical. :-)
For varying values of understandable, yes.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 28.11.2017 16:54, clipka wrote:
> To solve this, download the v3.8.0 help file from GitHub and save it in
> your POV-Ray v3.7.0 installation directory tree alongside
> `povray37.chm`; you can find the file in question here:
> https://github.com/POV-Ray/povray/blob/release/v3.8.0/distribution/platfo
rm-specific/windows/Help/povray.chm
Thanks, I did, now it works! :-D
http://www.avg.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I have started to work on your scene, to adapt it even more.
> Yes, you are right - changing the atmospheric colors does not lead to
> straight, expected results, but to unexpectable new colors. I believe
> (but I have no clue about media and density), that the reason for this
> color problem lays with the fact, that you specify the colors within the
> density map. I wonder, if there is a way to use neutral shades for the
> density map, and move the color map into the pigment statement right
> below the coordinates of the cloud layer.
Yes.
Some of the medias in your sample code have neutral colour_map.
If the media have a global colour, and a non-neutral colour_map, then
the rgb values are multiplied together : media rgb<1, 0.5, 0.2> and
colour_map entry rgb<0.3, 1, 0.1> give rgb<0.3, 0.5, 0.02>
It should be noted that with scattering and absorbing media, you get
shadows. That imply some amount of self shadowing. If the media is not
of a neutral tint, that mean that the remaining get illuminated by a
tinted light of the complimentary colour.
A blue scattering or absorbing media's shadow will be yellow.
It can get really complicated when you have multiple scattering and
absorbing medias as each one will cause some shadowing on all the others.
You don't want the container to have any colour as it will make it visible.
> I wonder, if I can use these two suns as light sources instead of a
> traditional light_source, when filling them with media?
Yes. Use looks_like as follow :
// Big red Sun
light_source{
< 80.0, -0.0, 35.0 >*33.0 rgb<3,0,0.1>
area_light 12*33*x 12*33*y 33 33 circular orient adaptive 0
looks_like{
sphere
< 0.0, 0.0, 0.0 > 1.0
pigment
gradient y
color_map
[ 0.00 rgb < 0.0, 0.0, 0.0 > ]
[ 0.50 rgb < 0.0, 0.0, 0.0 > ]
[ 1.00 rgb < 3.0, 0.0, 0.1 >*5.0 ]
translate < 0.0, -0.5, 0.0 >
scale 2.0
finish { emission 1.0 }
//scale 12.0
//scale 33.0
// translate < 80.0, -0.0, 35.0 >*33.0
// Small blue Sun
light_source{
< 80.0, 12.0, 46.0 >*33.0 rgb< 0.1, 0.3, 20.0>/10
area_light 33*x 33*y 33 33 circular orient adaptive 0
looks_like{
sphere
pigment { color rgb < 0.1, 0.3, 20.0 >*10.0 }
finish { emission 2.0 }
//scale 33.0
//translate < 80.0, 12.0, 46.0 >*33.0
Remove the other light.
You now have two coloured shadows with fuzzy edged.
Adjust the brightness ot the lights as needed. The may be way to bright
as they are now.
> http://www.avg.com
Those anti-virus tags mean nothing as some virus imitate them.
When you have multiple medias:
Work on one untill it's correct.
Comment it out.
Work on the next one.
Repeat untill you have set all medias.
Activate two medias.
Tweak them a little if needed.
Add the others one by one making some small adjustments as needed.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Stephen <mca### [at] aol com> wrote:
>> On 28/11/2017 18:11, Sven Littkowski wrote:
>>> I want to change the two suns into light-emitting media, can you assist?
>>> I simply lack expertise, never worked with media. Those will later
>>> replace the traditional light_source.
>> want.
> I'm thinking media won't be able to do what's wanted anyway. Sure, emitting
> media will illuminate surrounding objects, but cast shadows like a light on
> distant things? No, don't believe it can.
Emissive media CAN cast shadows.
For that to happen, you need to use radiosity with "media on" in the
radiosity block.
That way, the media can act like a fuzzy area_light whose brightness can
vary across it's visible surface.
radiosity{count 20000 media on}
default{radiosity{importance 75/20000}}
sphere{100*x 2 hollow pigment{rgbt 1}
interior{media{emission rgb<100, 50, 20>*25 samples 20}
radiosity{importance 1}}
Will use an average of 75 radiosity samples for most of the scene's
objects, but a very high count density for that relatively small and
bright object.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> radiosity block.
> bright object.
Well, seeing is believing... and unfortunately I wasn't able to do that. Test
scene below, comparing actual light with emitting media. I don't want to doubt
your idea but here's what I tried.
Curiously, after getting nowhere at first, I found radiosity 'brightness' needed
to be increased. Rather drastically, from what I've done with it before.
Still very different thing for these two illumination methods, like I expected,
no well-defined shadows. Probably because of how radiosity acts on both light
and shadow regions... or do I recall someone saying unlit portions are
ignored...?
Anyway... for your perusal, a test scene:
#version 3.7;
#default{ finish{ ambient 0 diffuse 1 }}
#local NoLight=yes; // yes = emitting media sphere, else light
global_settings{
assumed_gamma 1
ambient_light 0
radiosity{
pretrace_start 0.04
pretrace_end 0.01
count 20000 //1601
recursion_limit 3
nearest_count 10 //12
always_sample off
max_sample 0.9
error_bound 1.33 //1.2 //0.4
low_error_factor 0.4 //0.8
maximum_reuse 0.16*2 //0.2
minimum_reuse 0.028*2 //0.015
adc_bailout 1/127 //0.01
gray_threshold 0.0 //0
brightness #if (NoLight) 20 #else 1 #end
normal on
media on
}// end global_settings
#default{radiosity{importance 75/20000}}
//sky_sphere{ pigment { color rgb <1,1,1>} }
camera{ location <0, 22, -33>
rotate 12*y
look_at <-1.25,2.8,0>
angle 50
plane{ <0,1,0>,0 // floor
texture{
pigment { color rgb 1 }
finish {
ambient 0.0
diffuse 1
specular 0.4
roughness 0.01
// radiosity {importance 1}
union {
#for (Cnt,1,3)
difference {
box { <-1,-1,-1>,<1,1,1> }
sphere {0,1.40 inverse texture{ pigment{ color rgb <1,1,1>*0.5}} }
sphere {0,1.25}
texture{ pigment{ color rgb <1,1,1>}
finish{ phong 1 diffuse 1-Cnt/10 }
translate <0,0,0>
scale 1+Cnt*0.65
translate <0,1+Cnt*0.30,0>
rotate Cnt*<0,-22,0>
scale <1,1,1>
translate <0,1,0>
hollow on
//radiosity {importance 1}
#if (NoLight)
sphere {
0, 1
hollow on
pigment {color rgbt 1}
interior {
media {
emission <100, 50, 20>*25
//scattering {1, 1}
samples 20
density {
spherical
density_map {
[0 rgb 0]
[1 rgb 1]
scale 2
translate <-5,5,-5>*2 // near comment out *2, or far
#else
light_source {
<-5,5,-5>*2,
color <100, 50, 20>/100
looks_like {sphere {0,2
pigment {color rgb <100, 50, 20>/20}
finish {emission 1}}}
area_light x*2,y*2,10,10 jitter circular orient adaptive 2
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Yes.
> // Big red Sun
> light_source{
> // Small blue Sun
> light_source{
> as they are now.
>> http://www.avg.com
> Comment it out.
I actually tried this morning on my own some versions, but with these
look-alike suns I did not get a satisfying result (though I got nice
colors): the suns were almost not visible anymore.
I therefore decided to continue to use the traditional light_source. I
however try to make the suns getting a glow (seems to be the same like
"looks-alike"), but still failing with that.
I want, that the small sun is light blue or white inside but emitts a
purple-blue glow around it. The large sun is dim red and supposed to
have a red glow around it, too. I just fail currently.
Glow Example:
http://www.joshuarenglish.com/cyclopedia/lookslike.html
Here is my current scene code, please see also the 2nd attached image.
#version 3.8;
#declare MyRadiosity = off;
global_settings
assumed_gamma 1.4
#if(MyRadiosity=on)
radiosity { media on }
#default
finish { ambient 0.0 diffuse 1.0 }
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
camera
/*ultra_wide_angle*/ //angle 20
location < -35.0 , 11.0 , 0.0 >
//right x*image_width/image_height // not needed for v3.8
look_at < 0.0 , 5.0 , 0.0 >
// sky -------------------------------------------------------------------
background { color rgb 0.0 }
disc
0.0, y, 1.0, 0.0
hollow on
no_shadow
pigment { rgb < 0.5, 0.75, 1.0 > }
scale 100.0
translate y*100.0
// ground -----------------------------------------------------------------
box
< -1.0, -1.0, -1.0 > < 1.0, 1.0, 1.0 >
pigment { color rgb 1.0 }
scale < 555.0, 497.0, 555.0 >
translate -y*494.0
// Clouds
#local Scale = 5.0;
#declare Clouds = density
ripples // controls the cloud formation
color_map
[ 0.33 rgb 10.0 ]
[ 0.67 rgb 100.0 ]
scale < 3.0, 1.0, 10.0 >*0.5
warp { turbulence < 2.5, 1.0, 1.6 > }
rotate 45.0*y
//cloud layer:
box
pigment { rgbt 1.0 }
hollow
interior
media
samples 20
absorption < 3.0, 4.0, 0.5 >*1.0/(Scale*100.0)
emission < 1.0, 1.0, 1.0 >*0.5/(Scale*100.0)
scattering
1
< 0.5, 0.75, 1.5 >*3.0/(Scale*100.0)
extinction 0.5
density
boxed
density_map
[ 0.000 rgb 0.0 ]
[ 0.001 Clouds scale 1.0/100.0 ]
scale Scale*100.0
translate -y*494.0
//atmosphere:
sphere
< 0.0, 0.0, 0.0 >, 1.0
hollow
interior
media
samples 20
absorption 0.5
scattering
5
< 1.25, 1.0, 1.5 >*2.0/Scale
extinction 0.67
eccentricity 0.2
density
gradient y
color_map
[ 0.00 rgb 1.0 ] //base ground fog
[ 0.10 rgb < 9.0, 0.3, 0.10 > ] //top ground fog
[ 0.30 rgb < 0.9, 0.3, 0.10 > ] //top ground fog
[ 0.50 rgb < 0.5, 0.1, 0.09 >*0.100 ] //base atmospheric haze
[ 0.67 rgb < 0.1, 0.2, 0.90 >*0.100 ] //top atmospheric haze
[ 1.00 rgb < 0.1, 0.3, 0.90 >*0.001 ] //top atmospheric haze
[ 0.00 rgb < 1.0, 1.0, 1.00 >*1.000 ] //base ground fog
[ 0.10 rgb < 3.0, 0.3, 0.10 >*1.000 ] //top ground fog
[ 0.30 rgb < 0.3, 0.3, 0.10 >*1.000 ] //top ground fog
[ 0.67 rgb < 0.3, 0.7, 1.00 >*0.100 ] //top atmospheric haze
[ 1.00 rgb < 0.3, 0.7, 1.00 >*0.001 ] //top atmospheric haze
rotate -x*15.0
warp { spherical }
scale Scale*2.0*y
scale Scale*111.0
translate -y*535.0
// Planet:
union
sphere
< 0.0, 0.0, 0.0 > 7.0
pigment
gradient y
color_map
[ 0.00 rgb < 1.0, 1.0, 1.0 >*0.05 ]
[ 0.10 rgb < 1.0, 1.0, 1.0 >*0.05 ]
[ 0.12 rgb < 1.0, 1.0, 1.0 >*0.05 ]
[ 0.15 rgb < 0.80392, 0.66275, 0.47059 >*0.05 ]
[ 0.20 rgb < 0.80392, 0.66275, 0.47059 >*0.05 ]
[ 0.22 rgb < 0.63922, 0.55686, 0.31373 >*0.05 ]
[ 0.27 rgb < 0.63922, 0.55686, 0.31373 >*0.05 ]
[ 0.40 rgb < 0.47451, 0.30980, 0.14118 >*0.05 ]
[ 0.43 rgb < 0.47451, 0.30980, 0.14118 >*0.05 ]
[ 0.45 rgb < 0.20392, 0.24314, 0.41176 >*0.05 ]
[ 0.55 rgb < 0.20392, 0.24314, 0.41176 >*0.05 ]
[ 0.57 rgb < 0.47451, 0.30980, 0.14118 >*0.05 ]
[ 0.60 rgb < 0.47451, 0.30980, 0.14118 >*0.05 ]
[ 0.73 rgb < 0.63922, 0.55686, 0.31373 >*0.05 ]
[ 0.78 rgb < 0.63922, 0.55686, 0.31373 >*0.05 ]
[ 0.80 rgb < 0.80392, 0.66275, 0.47059 >*0.05 ]
[ 0.85 rgb < 0.80392, 0.66275, 0.47059 >*0.05 ]
[ 0.88 rgb < 1.0, 1.0, 1.0 >*0.05 ]
[ 0.90 rgb < 1.0, 1.0, 1.0 >*0.05 ]
[ 1.00 rgb < 1.0, 1.0, 1.0 >*0.05 ]
turbulence 0.3
translate < 0.0, -7.0, 0.0 >
scale 14.0
difference
cylinder { < 0.0, -0.00001, 0.0 > < 0.0, 0.00001, 0.0 > 16.0 }
cylinder { < 0.0, -0.00002, 0.0 > < 0.0, 0.00002, 0.0 > 10.0 }
pigment
onion
color_map
[ 0.00 rgbt < 0.47451, 0.30980, 0.14118, 0.7 > ]
[ 0.60 rgbt < 0.47451, 0.30980, 0.14118, 0.7 > ]
[ 0.62 rgbt < 0.47451, 0.30980, 0.14118, 0.7 > ]
[ 0.63 rgbt < 0.80392, 0.66275, 0.47059, 0.7 > ]
[ 0.66 rgbt < 0.80392, 0.66275, 0.47059, 0.7 > ]
[ 0.67 rgbt < 0.63922, 0.55686, 0.31373, 0.7 > ]
[ 0.71 rgbt < 0.63922, 0.55686, 0.31373, 0.7 > ]
[ 0.73 rgbt < 0.47451, 0.30980, 0.14118, 0.7 > ]
[ 0.76 rgbt < 0.47451, 0.30980, 0.14118, 0.7 > ]
[ 0.80 rgbt < 0.63922, 0.55686, 0.31373, 0.7 > ]
[ 0.81 rgbt < 0.63922, 0.55686, 0.31373, 0.7 > ]
[ 0.82 rgbt < 0.47451, 0.30980, 0.14118, 0.7 > ]
[ 0.83 rgbt < 0.47451, 0.30980, 0.14118, 0.7 > ]
[ 0.86 rgbt < 0.63922, 0.55686, 0.31373, 0.7 > ]
[ 0.88 rgbt < 0.63922, 0.55686, 0.31373, 0.7 > ]
[ 0.89 rgbt < 0.80392, 0.66275, 0.47059, 0.7 > ]
[ 0.91 rgbt < 0.80392, 0.66275, 0.47059, 0.7 > ]
[ 0.97 rgbt < 0.63922, 0.55686, 0.31373, 0.7 > ]
[ 0.99 rgbt < 0.63922, 0.55686, 0.31373, 0.7 > ]
[ 1.00 rgbt < 0.63922, 0.55686, 0.31373, 0.7 > ]
scale 16.0
finish { crand 0.01 emission 0.1 }
scale 250.0
rotate < -10.0, -20.0, 50.0 >
translate < 160.0, 50.0, -100.0 >*33.0
// Big Sun
#declare SunLarge = union
/*sphere
pigment
gradient y
color_map
[ 0.50 rgb < 1.5, 0.0, 0.1 > ]
scale 2.0
scale 12.0
sphere
hollow
no_shadow
pigment { rgbt 1 }
interior
media
emission 1/12.0
density
spherical
density_map
[ 0.0 rgb < 0.0, 0.0, 0.0 >*1.0 ]
[ 0.5 rgb < 3.0, 0.0, 0.1 >*0.5 ]
[ 1.0 rgb < 1.0, 1.0, 1.0 >*1.0 ]
samples 1,1
intervals 1
confidence .1 // quite fast settings
method 3
scale 12.0
scale 66.0
translate < 160.0, 0.0, 78.0 >*33.0
// Small Sun
#declare SunSmall = union
sphere
pigment { color rgb < 0.23529, 0.11373, 0.46275 >*1.0 }
finish { emission 0.0 }
sphere
hollow
no_shadow
pigment { rgbt 1 }
interior
media
emission 1/1.0
density
spherical
density_map
[ 0.0 rgb 0.0 ]
[ 0.5 rgb < 0.23529, 0.11373, 0.46275 >*0.5 ]
[ 1.0 rgb < 0.23529, 0.11373, 0.46275 >*0.5 ]
samples 1,1
intervals 1
method 3
scale 1.0
scale 66.0
translate < 160.0, 25.0, 112.0 >*33.0
object { SunLarge }
//object { SunSmall }
light_source
-z*9999.0//< 50, 100, -250 >*10e4
color 1.0 * 1.4//< 1.0, 0.62353, 0.46667 >*2
rotate < 20.0, 240.0, 0.0 > // altitude, azimuth, tilt
#declare light_object = sphere
< 160.0, 25.0, 112.0 >*33.0 100.0
pigment { rgbf < 0,0,1,1 >*2 }
finish { specular 5 metallic}
light_source
color rgb < 0,0,1> *2
looks_like { light_object }
light_source
0,
color 0.5 *< 2.0, 7.0, 9.0 > // comment color out?
// area_light <12*33,0,0>,<0,12*33,0>,4,4 circular orient adaptive 0
looks_like { SunLarge }
translate < 160.0, 30.0, 98.0 >*33.0
light_source
0,
color 0.5 *< 0.9, 0.6, 1.0 > // comment color out?
// area_light <33,0,0>,<0,33,0>,3,3 circular orient adaptive 0
looks_like { SunSmall }
translate < 160.0, 45.0, 132.0 >*33.0
//artefact:
#local S=seed(4132);
union
#for (It,1.0,8.0,1.0)
#local xR=rand(S);
#local yR=rand(S);
#local zR=rand(S);
#local xR2=rand(S);
#local yR2=rand(S);
#local zR2=rand(S);
box
0.0, 1.0
scale < 1.0+xR, 8.0+yR*4, 1.0+zR >/2.0
pigment
checker
color rgb 0.1 color rgb 0.9 scale 0.5
translate (-< xR*20.0,0.0,zR*20.0 > + <xR2*40.0, 0.0, zR2*40.0 >)/2.0
rotate y*90.0
translate < -20.0, 2.0, 5.0 >
Download 'sl - cloud cities - omniverse - 2 look_alike suns.jpg' (138 KB)
Download 'sl - cloud cities - omniverse - glow.jpg' (92 KB)
Preview of image 'sl - cloud cities - omniverse - 2 look_alike suns.jpg'
![sl - cloud cities - omniverse - 2 look_alike suns.jpg](/povray.binaries.images/attachment/%3C5a1e2359%40news.povray.org%3E/sl%20-%20cloud%20cities%20-%20omniverse%20-%202%20look_alike%20suns.jpg?ttop=430894&toff=350&preview=1)
Preview of image 'sl - cloud cities - omniverse - glow.jpg'
![sl - cloud cities - omniverse - glow.jpg](/povray.binaries.images/attachment/%3C5a1e2359%40news.povray.org%3E/sl%20-%20cloud%20cities%20-%20omniverse%20-%20glow.jpg?ttop=430894&toff=350&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This thread has become so large that is becomes increasingly harder to
overview it.
Thus I created a PART 2 of this remarkable thread, its name is "Cloud
City II" and is here:
news://news.povray.org:119/5a1e741d@news.povray.org
http://www.avg.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> radiosity block.
>> bright object.
> ignored...?
> #version 3.7;
> global_settings{
> assumed_gamma 1
> ambient_light 0
> radiosity{
> pretrace_start 0.04
> pretrace_end 0.01
> count 20000 //1601
> recursion_limit 3
> always_sample off
> max_sample 0.9
/*You may need a smaller value here.
Smaller values tend to allow sharper shadows.
//Should be OK
// Default is 0.5
// Was 0.8 back in version 3.5
/* Don't increase this.
If you increase brightness like that, it will play havoc elsewhere.
It's usually better to leave this parameter out.
> normal on
> media on
> rotate 12*y
> angle 50
> texture{
> finish {
> ambient 0.0
> diffuse 1
> specular 0.4
> roughness 0.01
> union {
> #for (Cnt,1,3)
> difference {
> sphere {0,1.25}
> translate <0,0,0>
> scale 1+Cnt*0.65
> #end
> scale <1,1,1>
> translate <0,1,0>
> hollow on
> #if (NoLight)
> sphere {
> 0, 1
> hollow on
> interior {
> media {
//You probably need to crank this up, maybe a LOT!
// try emission <100, 50, 20>*250
> //scattering {1, 1}
> samples 20
> density {
> spherical
> density_map {
> [0 rgb 0]
> [1 rgb 1]
> scale 2
> #else
> light_source {
> <-5,5,-5>*2,
Here, 10,10 becomes 17,17 due to the way that adaptive work.
> #end
The emissive illumination fade out according to the square of the
distance. It can come from an emissive surface or media.
The net effect is proportional to the intensity of the emission, time,
the emissive surface area, divided by the square of the distance to the
illuminated surface.
For a normal light to behave like this, you need to add (in this case):
fade_power 2
fade_distance 2
and increase the light's intensity :
color <100, 50, 20>
When using adaptive, the number of sub lights can only take some values.
The first are : 2 (2^0+1), 3 (2^1+1), 5 (2^2+1), 9 (2^3+1), 17 (2^4+1),
33 (2^5+1), 65 (2^6+1), ...
In between values are bumped up to the next value in the list.
Formula : (2 ^MaxSubdivisionSteps)+1
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"And" <49341109@ntnu.edu.tw> wrote:
> subsurface material cloud:
(I meant to post earlier)
That is a BEAUTIFUL block of 'crunchy icy snow.' And thanks for making the code
available; I've been playing with it, my first real experiments with SSLT and
its parameters.
Well done!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> its parameters.
> Well done!
Good luck
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
