"[GDS|Entropy]" <nomail@nomail> wrote:
> Type [0,1].
> Note all these are scaled up to see the details, usually, for blocks, you
> wouldn't make them like this, but for terrain elements you might.
Those wavy dark features look suspiciously like isosurface artifacts. Are you
sure your max_gradient is high enough?
> > Type [0,1].
Oh it certainly isn't. :)
I will need to play with that value a bit.
Thanks!
Ian
Here is an "angry" media sky output from the Sky macro.
I will post the other settings as I get them where I want them to be.
Ian
Download 'clouds 2017.png' (1515 KB)
Preview of image 'clouds 2017.png'
Cecil B. DeMille worthy!
Thank you. :)
My goal is to build a fairly comprehensive "Environmentals" macro set that is
both simple to use and nice looking. Given that they are designed to work
together it should take a LOT of the work out of creating natural scenes, and
hopefully inspire some scenes.
The Rocks macro is coming close to completion, for version 1 at least, and the
Terrain macro is close behind it. Next in the set is the Skies and Fogs.
The Fog is being a little weird, because Media without a container is only
visible when looking at the plane below it, and it vanishes above the horizon.
?! Weeeird. Very counterintuitive.
Any idea why this is, and how to fix it? Is the only choice to bound the media?
I am guessing that this is because it is not reasonable to calculate media for
an infinite space, but I could be wrong.
Download 'mediafogtest.png' (248 KB)
Preview of image 'mediafogtest.png'
> Thank you. :)
You are correct on this point. Media sampling can only be computed
between two deffined points. When you reatch the background, the far
point is undefined, making the computation impossible.
Solution : Place a background plane behond the scene. Make it no_image,
no_shadow, no_refection and no_radiosity.
> > Thank you. :)
> Alain
When I tried that, the media disappeared entirely, here is the plane I used:
plane
z,
100
no_radiosity
no_image
no_shadow
no_reflection
Did I miss something?
Thanks!
Ian
>>> Thank you. :)
>> Alain
> plane
> z,
> 100
> no_radiosity
> no_image
> no_shadow
> no_reflection
> Thanks!
> Ian
Your plane is facing away from the camera, placing the camera /inside/
the plane.
Add hollow to your plane or reverse it's normal and offset.
plane{
-z, -100 // Makes the plane face the camera
no_radiosity no_image no_shadow no_reflection
OR
plane{
z, 100
hollow // allow media to exist "inside" the plane
You could also use inverse instead of hollow or revercing the plane
orientation.
> >>> Thank you. :)
> >> Alain
> > plane
> > z,
> > 100
> > no_radiosity
> > no_image
> > no_shadow
> > no_reflection
> > Thanks!
> > Ian
> the plane.
> plane{
> OR
> plane{
> z, 100
> orientation.
> Alain
That does make the media reappear [using either inverse or hollow], but also
retains the issue of the media vanishing above horizon. I must really be borking
this up lol! :)
Ian
Am 13.12.2016 um 22:15 schrieb [GDS|Entropy]:
Doesn't sound like something that should happen.
Care to share any details?
