Subject: Friday abstract: spectral subtractive color mixing
Date: 18 Nov 2016 11:36:44
Message: <582f2e1c@news.povray.org>
These four images are all rendered spectrally.
Image subtractive-arith.jpg uses straightforward arithmetic averaging of
4 colors. Clearly, arithmetic averaging is not the way to simulate the
mixing of pigments.
Images subtractive_blob-k.jpg and subtractive_blob-w.jpg use geometric
averaging of 4 colors.
Image subtractive_blob-cmy.jpg uses geometric averaging of 3 colors.
Download 'subtractive-arith.jpg' (34 KB)
Download 'subtractive_blob-k.jpg' (53 KB)
Download 'subtractive_blob-w.jpg' (56 KB)
Download 'subtractive_blob-cmy.jpg' (55 KB)
Preview of image 'subtractive-arith.jpg'
Preview of image 'subtractive_blob-k.jpg'
Preview of image 'subtractive_blob-w.jpg'
Preview of image 'subtractive_blob-cmy.jpg'
Subject: Re: Friday abstract: spectral subtractive color mixing
Date: 18 Nov 2016 12:11:50
Message: <582f3656$1@news.povray.org>
Am 18.11.2016 um 17:38 schrieb Cousin Ricky:
> mixing of pigments.
From my experience, you get the best results by applying the following
algorithm:
- For each colour involved, compute its luminance.
- For each colour, compute the lightness from the luminance.
- Compute the arithmetic average of all the lightness values.
- Compute the result luminance from the averaged lightness.
- For each colour involved, normalize it to unity luminance
by dividing each component by the colour's computed luminance.
- Compute the arithmetic average of the normalized colours.
- Renormalize the result colour to the result luminance
by multiplying each component with the result luminance.
POV-Ray 3.7.1 supports this type of averaging in pigment maps and colour
maps, using "blend_mode 3" (IIRC); by default, it uses Y=V^2.4 as the
formula to convert between luminance (Y) and lightness (V).
> algorithm:
Does this work with spectral rendering?
Date: 18 Nov 2016 13:27:46
Message: <582f4822$1@news.povray.org>
Am 18.11.2016 um 19:13 schrieb Cousin Ricky:
>> algorithm:
If you can compute the luminance of a colour across all channels that
will eventually be rendered, then yeah -- that should certainly work.
Date: 21 Nov 2016 07:32:18
Message: <5832e952$1@news.povray.org>
Cousin Ricky wrote on 18/11/2016 17:38:
> mixing of pigments.
Lovely!
Paolo
